How to downgrade?
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
21 Jul 2017 16:40 #96232 by Todd Zuercher
Replied by Todd Zuercher on topic How to downgrade?
You can usually use Synaptic to downgrade versions (within a release) easily enough.
Select the package you want to change, from the Package menu click Force Version (or Ctrl+E), select the version you want to run, then click Apply.
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Jul 2017 16:44 #96233 by tecno
Replied by tecno on topic How to downgrade?
Thanks Todd,
but I have already started to reinstall so I can get back to basics and see what is wrong with the box I have.
Cheers
Bengt
  • tecno
  • Platinum Member
  • Platinum Member
21 Jul 2017 18:41 - 21 Jul 2017 18:58 #96238 by tecno
Hmmm.
Obviously there is something wrong so I have to ditch that one.
I have another PC under latency test right now, www.jetwaycomputer.com/NC91.html
Servo thread Max jitter 8178916
Base thread Max jitter 302270
Is this a candidate (read usable) for 7i76E running AC Servos with Step/dir?
Debian Stretch, RT-PREEMPT, LinuxCNC 2.7.x still r1 no update no upgrade
Cheers
Bengt
Last edit: 21 Jul 2017 18:58 by tecno.
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
21 Jul 2017 19:41 #96244 by Todd Zuercher
Have you tried running a mem test or checking the HD. Perhaps it is a simple fix. Did you check the capacitors on the main board for obviously failing ones?
  • tecno
  • Platinum Member
  • Platinum Member
21 Jul 2017 19:47 #96245 by tecno
No, it is just too much work and it's an old box. It is over 12 years so I do not think it will cut for RT-PREEMT.
So I hope I can use the Jetway NC91 for my Mesa 7i76E boards.
26 Jul 2017 12:31 #96462 by andypugh
Replied by andypugh on topic How to downgrade?
No, that's terrible.
8mS jitter on a 1mS thread will never work.
Are you sure it is booted into the preempt-rt kernel? (uname -a will tell you)
Time to create page: 0.162 seconds
