- LinuxCNC
- Installing LinuxCNC
- Linuxcnc 2.7 is "bricking" my computer, any way to rollback update to 2.6?
- punking
14 May 2018 13:16 #110728
by punking
Replied by punking on topic Linuxcnc 2.7 is "bricking" my computer, any way to rollback update to 2.6?
No,
stops at the same spot in terminal
- Thank you received: 5328
14 May 2018 17:19 #110732
Replied by PCW on topic Linuxcnc 2.7 is "bricking" my computer, any way to rollback update to 2.6?
Thats pretty odd, how did you upgrade to 2.7?
- punking
14 May 2018 19:14 - 14 May 2018 19:17 #110736
by punking
since I haev the computer connected to the internet , I used update manager and updated with that.
how can i do a clean uninstall of everything linuxcnc?
then i can reinstall linuxcnc.
Last edit: 14 May 2018 19:17 by punking.
- ozzyrob
- Visitor
14 May 2018 20:14 #110739
by ozzyrob
Replied by ozzyrob on topic Linuxcnc 2.7 is "bricking" my computer, any way to rollback update to 2.6?
Can you run the latency-test from a terminal ?
- Grotius
- Thank you received: 2349
14 May 2018 20:24 #110740
by Grotius
Replied by Grotius on topic Linuxcnc 2.7 is "bricking" my computer, any way to rollback update to 2.6?
Punking has not shown the picture of the terminal when linux is stopping.
If Punking is not able to do that because of speed of starting and closing. Punking has to type in terminal : linuxcnc
Then he will be able to make picture of fault message.
- punking
14 May 2018 22:56 #110747
by punking
There is a picture of the terminal earlier in the thread
- punking
15 May 2018 11:42 #110754
by punking
the error I'm experiencing is a graphics issue.
I got linuxcnc working.
But it is with a workaround, that i need help with.
When i boot up the computer, it is running ubuntu 12.4
i have to boot into a previous version kernal like I always did. But,,.... now i have to boot into recovery mode of that kernal and choose tyhe fail-safe graphics mode.
once booted up, linuxcnc works fine. how can I make the graphics work without all of the bootup procedures? and have it work in limited graphics mode automatically?
- Thank you received: 1476
15 May 2018 13:24 #110764
Replied by Todd Zuercher on topic Linuxcnc 2.7 is "bricking" my computer, any way to rollback update to 2.6?
Sounds like an OpenGL problem. As a test, try running one of the simulations that don't use it, like TKLinuxcnc.
You might have to change your driver for your graphics, or one of it's settings (related to OpenGL).
- LinuxCNC
Time to create page: 0.142 seconds
