Installing LinuxCNC on Debian 9
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
10 Jul 2018 18:00 - 07 Feb 2019 15:36 #113960 by BigJohnT
Installing LinuxCNC on Debian 9 was created by BigJohnT
Here is the method I use to install LinuxCNC on Debian 9 and setup for using an Ethernet Mesa card.
gnipsel.com/linuxcnc/uspace/debian9-rt.html
gnipsel.com/linuxcnc/uspace/debian9-emc.html
gnipsel.com/linuxcnc/uspace/debian9-eth.html
I've gathered all my instructions into one place for Uspace and various OS's
JT
Last edit: 07 Feb 2019 15:36 by BigJohnT.
The following user(s) said Thank You: trilobyte, tommylight, rodw, ikkuh, Grotius, spma, JetForMe
11 Jul 2018 19:56 #114024 by Grotius
Replied by Grotius on topic Installing LinuxCNC on Debian 9
Hi John,
Why not cloning a pre configured debian 9 with clonezilla server? clonezilla.org/clonezilla-SE
This saves time.... I only tried the cd clonezilla, this works perfect. 15 minutes ready.
Is this an idea to use?
  • BigJohnT
  • Administrator
  • Administrator
11 Jul 2018 22:20 #114035 by BigJohnT
Replied by BigJohnT on topic Installing LinuxCNC on Debian 9
I guess once you setup the drive cloning it might be a good thing.
JT
12 Jul 2018 05:20 #114044 by tommylight
Replied by tommylight on topic Installing LinuxCNC on Debian 9
Or use "SystemBack" that is very friendly and easy to use.
In some cases you have to uninstall casper and install liveboot, but otherwise it works nicely and can also make an ISO that can be booted from a USB.
04 Aug 2018 02:00 #115574 by Vitran
Replied by Vitran on topic Installing LinuxCNC on Debian 9
cdimage.debian.org/cdimage/unofficial/no....0-amd64-netinst.iso
This link you provided is only a few days old, but it is giving a 404 Not Found. Where can one find where the disk images are?
  • AnnoyingMutt
  • AnnoyingMutt's Avatar
  • Visitor
  • Visitor
04 Aug 2018 07:45 #115593 by AnnoyingMutt
04 Aug 2018 12:31 #115599 by Vitran
That works, thank you. Yesterday it was providing a 404 when I copied BigJohnT's link no matter what I tried, but I was doing it on a different computer.
  • BigJohnT
  • Administrator
  • Administrator
04 Aug 2018 15:10 #115605 by BigJohnT
I should have known better than to put the file name in the link... it will change.
JT
20 Nov 2018 17:59 #121076 by Mya2k
Hello,
The link seems to be broken as of 11/20/18. Please refer to attached image. Also, is it expected that the www.linuxcnc.org domain is down?
Thanks,
Mya
21 Nov 2018 17:04 #121136 by andypugh
Looks like a problem at your end, both linuxcnc.org and cdimage.debian.org/cdimage/unofficial/no...-including-firmware/ are working for me.
downforeveryoneorjustme.com can be a useful way to check.
Time to create page: 0.165 seconds
