- Thank you received: 5
On the View menu click on "show offsets"jferguson wrote:
One change I would like to make which is apparently an improvement with LinuCNC 2.8 is the display showing the work-piece and the tool paths is now covered with G-Code status. I had liked having only X,Y, Z and velocity. How can I fix this?
jferguson wrote: I did the installation on the machine at the shop, had the problem with screen resolution and fixed that with a grub modification.
