not so easy to do!
you must add:
deb http://old-releases.ubuntu.com/ubuntu/ precise main universe restricted multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ precise main universe restricted multiverse
deb http://old-releases.ubuntu.com/ubuntu/ precise-security main universe restricted multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ precise-security main universe restricted multiverse
deb http://old-releases.ubuntu.com/ubuntu/ precise-updates main universe restricted multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ precise-updates main universe restricted multiverse
deb http://old-releases.ubuntu.com/ubuntu/ precise-backports main restricted universe multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ precise-backports main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ precise-proposed main restricted universe multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ precise-proposed main restricted universe multiverse
in your source.list, because precise is now old releases ... + you need to solve no_public key issue with old release so:
sudo apt-get install debian-archive-keyring
Than tcl8.4-dev package required is possible to install only in new releases tcl8.5-dev. But these is quite simple to do:
sudo apt-get install tcl8.5-dev tk8.5-dev
+ printui support is no more avaiable so i use these link:
https://www.ubuntuupdates.org/package/core/precise/universe/base/libgnomeprintui2.2-dev
after these ... without any type of latency issue trik and max abuse of pc (glx 4 windows, youtube 3 video, install multiple addictional package during running latency test) and after 2 hour the result is in these pic.
During upload of the image latency base max-jitter go to 100.000 .... asusB250M, I5 7500 ... I try with isol-cpu and fix smi if i have these issue. But probabily not because the result is after 2 hour of work.
