LinuxCNC Uspace
6 years 9 months ago #153928 by Gene1934
Replied by Gene1934 on topic LinuxCNC Uspace
Nope, distance and natural causes, no "help" from me unless he was getting in my face.
Our last conversation on the phone at about 3AM was VERY explicit, Never bothered me again. My first wife's first husband, thought he still owned her 12 years later. She was a good woman, but had a stroke and died at 34 back in '68. I had her for 11 years, 3 children and 2 she came to me with, and I still miss that woman.
Warped? Just common sense.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
6 years 9 months ago #153964 by ytiuqibu
Replied by ytiuqibu on topic LinuxCNC Uspace
Thanks very much!
With a little persuasion I got the 4.9 kernel booting but had a few errors along the way principally due to the fact that the cache will not update while the debian repo is enabled -
GPG error: security.debian.org stretch/updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9D6D8F6BC857C906 NO_PUBKEY AA8E81B4331F7F50The repository ' security.debian.org stretch/updates InRelease' is not signed.
Are these keys related in any way to those included in your instructions?
6 years 9 months ago #153983 by ytiuqibu
Thanks to All!
LinuxCNC 2.7.15 now seems to be running happily on Mint 19.1 Cinnamon on 1 of 6 computers - now to reinstall the other training software hopefully without any conflicts.
5 years 3 months ago #214469 by yi2580
Replied by yi2580 on topic LinuxCNC Uspace
Hello, has your problem been solved? I also encountered the same problem. How did you solve it
Thank you.
5 years 3 months ago #214470 by yi2580
Hello, has your problem been solved? I also encountered the same problem. How did you solve it wrote: Hello, has your problem been solved? I also encountered the same problem. How did you solve it
Thank you.
Grotius wrote: @Jim,
MESA_GL_VERSION_OVERRIDE=4.5 MESA_GLSL_VERSION_OVERRIDE=450 ./linuxcnc
OK thanks, I will give it a try, but I must say this is well beyond my knowledge level of how this stuff works. I was a hardware engineer and only occasionally dabbled in software. At this point, it's really not that important as I will be replacing the computer anyway.
So that got rid of the OpenGL version complaint but there are other unrelated problems. I installed qtpyvcp exactly according to qtpyvcp.kcjengr.com/install/quick_start.html and get the following:
jim@LinuxCNC:~/linuxcnc/configs/sim.qtpyvcp$ MESA_GL_VERSION_OVERRIDE=4.5 MESA_GLSL_VERSION_OVERRIDE=450 linuxcnc xyz.ini
LINUXCNC - 2.9.0-pre0-222-g664bd969e
Machine configuration directory is '/home/jim/linuxcnc/configs/sim.qtpyvcp'
Machine configuration file is 'xyz.ini'
Starting LinuxCNC...
Unrecognized line skipped: ;Tool Pocket X Offset Y Offset Z Offset Diameter Remark
Found file(REL): ./hallib/core_sim_3.hal
Note: Using POSIX realtime
Found file(REL): ./hallib/spindle_sim.hal
Found file(REL): ./hallib/simulated_home.hal
QFileSystemWatcher::addPath: path is empty
/usr/bin/linuxcnc: line 896: 9641 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
task: 1037 cycles, min=0.000020, max=0.010445, avg=0.009785, 0 latency excursions (> 10x expected cycle time of 0.010000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/jim/linuxcnc_debug.txt
and
/home/jim/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
5 years 3 months ago #214565 by andypugh
Replied by andypugh on topic LinuxCNC Uspace
Can you paste the exact error report?
(And why are you installing on Stretch?)
Time to create page: 0.193 seconds
