Upgrading from Axis 2.3.1
- smorin
26 Feb 2019 16:30 #127171
by smorin
Upgrading from Axis 2.3.1 was created by smorin
Hello All-
I am running Axis 2.3.1 on an incredibly old PC (pentiumII) which seems to be ready to kick the bucket- I have been getting some errors and crashes lately and I figure it's time to update the PC.
I have built a new PC with the exact same interface card inside and I have installed LinuxCNC-2.7-wheezy.iso since I cannot find the ISO for the version running on the old PC.
I want to fully configure the new PC before I replace the old one but the person who did the configuring of the old version for us is not around anymore. Given that the hardware is the same, is it reasonable to expect that I can transfer all of the settings from the old configuration files to the new ones. I realize that the files are formatted differently but will it be possible to copy values from the old files and paste them into the appropriate locations in the new files?
26 Feb 2019 22:57 #127210
Replied by andypugh on topic Upgrading from Axis 2.3.1
Just copy the entire linuxcnc folder from the old to new machine.
Then fix the errors one by one.
There may only be a very few.
Just paste the error dumps here and we will explain what needs fixing.
The following user(s) said Thank You: smorin
- pl7i92
- Thank you received: 358
27 Feb 2019 10:42 #127237
by pl7i92
Replied by pl7i92 on topic Upgrading from Axis 2.3.1
you may join the Livechat on your mashine
it is a IRC Chatroom where they can help you LIVE with the weror message
so no Wait between the posts
- smorin
28 Feb 2019 19:21 #127348
by smorin
Replied by smorin on topic Upgrading from Axis 2.3.1
Thanks so much for the reply!
I'm going to try to be careful not to leave out any details so as not to waste your time, here goes:
1) I do not have the hardware installed in the NEW PC yet, in case this makes a difference
2) the card I will be installing is this one
www.vitalsystem.com/portal/purchase.php?id=7541
which is the exact same one that is in the OLD PC
3) the OLD PC (running ubuntu) does not have a "linuxCNC" folder- the config files were located in
/home/cnc/emc2/configs
4) I deleted the contents of the /linuxcnc/configs folder on the NEW PC and copied the contents of the configs folder from the OLD PC to the configs folder of the NEW PC
5) When I run the configuration picker, I navigate to My Configurations>motenc>motenc and add a shortcut to the desktop The shortcut that appears is called SD-850. This is the same name as the one on the desktop of the OLD PC.
6) when I try to launch the new shortcut, I am presented with a large text file:and the program will not run
thanks again
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/cnc/linuxcnc/configs/motenc'
Machine configuration file is 'motenc.ini'
INIFILE=/home/cnc/linuxcnc/configs/motenc/motenc.ini
PARAMETER_FILE=motenc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
libnml/buffer/physmem.cc 143: PHYSMEM_HANDLE: Can't write 6356 bytes at offset 60 from buffer of size 4064.
libnml/cms/cms_in.cc 1378: CMS:(toolSts) Error writing 6356 bytes to global memory at offset 0x8055824
(See libnml/cms/cms_in.cc line 1381.)
* Current Directory = /home/cnc/linuxcnc/configs/motenc
* BufferName = toolSts
* BufferType = 0
* ProcessName = tool
* Configuration File = emc.nml
* CMS Status = -3 (CMS_INTERNAL_ACCESS_ERROR: An error occurred during an internal access function. )
* Recent errors repeated:
* BufferLine: B toolSts SHMEM localhost 4096 0 0 5 16 1005 TCP=5005 xdr
* ProcessLine: P tool toolSts LOCAL localhost W 0 1.0 0 3
* error_type = 5 (NML_INTERNAL_CMS_ERROR)
too many tools. skipping tool 56
too many tools. skipping tool 57
Found file(REL): ./core_servo.hal
Found file(REL): ./motenc_driver.hal
Killing task linuxcncsvr, PID=5050
Debug file information:
Unrecognized line skipped: POCKET FMS LENGTH DIAMETER COMMENT
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_motenc.ko: No such device
./motenc_driver.hal:4: exit value: 1
./motenc_driver.hal:4: insmod for hal_motenc failed, returned -1
See the output of 'dmesg' for more information.
5050
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009e400 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000cfdffc00 (usable)
[ 0.000000] BIOS-e820: 00000000cfdffc00 - 00000000cfe53c00 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cfe53c00 - 00000000cfe55c00 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cfe55c00 - 00000000d0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000feda0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000128000000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 960 /0H634K, BIOS A04 04/29/2009
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xcfdff max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: write-back
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0CFF00000 mask FFFF00000 uncachable
[ 0.000000] 1 base 0D0000000 mask FF0000000 uncachable
[ 0.000000] 2 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36528000 - 3728c000
[ 0.000000] ACPI: RSDP 000fec00 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT 000fc7cb 0008C (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: FACP 000fc8fb 000F4 (v03 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: DSDT ffe9cff8 054AD (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS cfdffc00 00040
[ 0.000000] ACPI: SSDT ffea25c4 000AA (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 000fc9ef 00092 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fca81 00028 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: ASF! 000fcaa9 00096 (v32 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: MCFG 000fcb3f 0003E (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: HPET 000fcb7d 00038 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: TCPA 000fcdd9 00032 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: ____ 000fce0b 00030 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: SLIC 000fcbb5 00176 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: SSDT cfdffc40 0023B (v01 DpgPmm Cpu0Ist 00000011 INTL 20050624)
[ 0.000000] ACPI: SSDT cfe00049 0023B (v01 DpgPmm Cpu1Ist 00000011 INTL 20050624)
[ 0.000000] ACPI: SSDT cfe00452 00190 (v01 DpgPmm CpuPm 00000010 INTL 20050624)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2438MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000cfdff
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x000cfdff
[ 0.000000] On node 0 totalpages: 851341
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4b28200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3950 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4877 pages used for memmap
[ 0.000000] HighMem zone: 619252 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x05] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x07] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 6 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at d0000000 (gap: d0000000:10000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f7763000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 844688
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=2279d5c9-f605-471c-9847-8ee7bc540f27 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x3, cntxt size 0x240
[ 0.000000] allocated 6811512 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000cfdff)
[ 0.000000] Memory: 3351096k/3405820k available (3495k kernel code, 54268k reserved, 1237k data, 416k init, 2496516k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 3324.546 MHz processor.
[ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 6649.09 BogoMIPS (lpj=13298184)
[ 0.004005] pid_max: default: 32768 minimum: 301
[ 0.004037] Security Framework initialized
[ 0.004040] AppArmor: AppArmor disabled by boot time parameter
[ 0.004053] Mount-cache hash table entries: 512
[ 0.004209] Initializing cgroup subsys cpuacct
[ 0.004211] Initializing cgroup subsys memory
[ 0.004218] Initializing cgroup subsys devices
[ 0.004219] Initializing cgroup subsys freezer
[ 0.004221] Initializing cgroup subsys net_cls
[ 0.004222] Initializing cgroup subsys blkio
[ 0.004227] Initializing cgroup subsys perf_event
[ 0.004248] CPU: Physical Processor ID: 0
[ 0.004249] CPU: Processor Core ID: 0
[ 0.004251] mce: CPU supports 6 MCE banks
[ 0.004257] CPU0: Thermal monitoring enabled (TM2)
[ 0.004301] ACPI: Core revision 20120320
[ 0.155502] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.155857] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.195547] CPU0: Intel(R) Core(TM)2 Duo CPU E8600 @ 3.33GHz stepping 0a
[ 0.196011] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.196011] ... version: 2
[ 0.196011] ... bit width: 40
[ 0.196011] ... generic registers: 2
[ 0.196011] ... value mask: 000000ffffffffff
[ 0.196011] ... max period: 000000007fffffff
[ 0.196011] ... fixed-purpose events: 3
[ 0.196011] ... event mask: 0000000700000003
[ 0.204149] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.216030] CPU 1 irqstacks, hard=f4114000 soft=f4116000
[ 0.216033] Booting Node 0, Processors #1
[ 0.008000] Initializing CPU#1
[ 0.228041] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.228076] Brought up 2 CPUs
[ 0.228078] Total of 2 processors activated (13298.18 BogoMIPS).
[ 0.230330] devtmpfs: initialized
[ 0.230330] PM: Registering ACPI NVS region [mem 0xcfdffc00-0xcfe53bff] (344064 bytes)
[ 0.230330] dummy:
[ 0.230330] NET: Registered protocol family 16
[ 0.230330] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.230330] ACPI: bus type pci registered
[ 0.230330] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.232017] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.232018] PCI: Using MMCONFIG for extended config space
[ 0.232020] PCI: Using configuration type 1 for base access
[ 0.232029] dmi type 0xB1 record - unknown flag
[ 0.232403] bio: create slab <bio-0> at 0
[ 0.232403] ACPI: Added _OSI(Module Device)
[ 0.232403] ACPI: Added _OSI(Processor Device)
[ 0.232403] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.232403] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.232403] ACPI: EC: Look up EC in DSDT
[ 0.268503] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.298005] ACPI Warning: Incorrect checksum in table [TCPA] - 0x00, should be 0x7F (20120320/tbutils-323)
[ 0.298214] ACPI: Interpreter enabled
[ 0.298221] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.298243] ACPI: Using IOAPIC for interrupt routing
[ 0.431394] ACPI: ACPI Dock Station Driver: 1 docks/bays found
[ 0.431400] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.440358] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.456957] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
[ 0.456957] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
[ 0.456957] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.456957] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff]
[ 0.456957] pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff]
[ 0.456957] pci_root PNP0A03:00: host bridge window [mem 0xf0000000-0xfec00000]
[ 0.456957] pci_root PNP0A03:00: host bridge window [mem 0xcff00000-0xdfffffff]
[ 0.456957] pci_root PNP0A03:00: host bridge window [mem 0xff980000-0xff980fff]
[ 0.456957] pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff]
[ 0.456957] pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff]
[ 0.456957] pci_root PNP0A03:00: host bridge window [mem 0xfeda7000-0xfeda7fff]
[ 0.456957] PCI host bridge to bus 0000:00
[ 0.456957] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.456957] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.456957] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.456957] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff]
[ 0.456957] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff]
[ 0.456957] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfec00000]
[ 0.456957] pci_bus 0000:00: root bus resource [mem 0xcff00000-0xdfffffff]
[ 0.456957] pci_bus 0000:00: root bus resource [mem 0xff980000-0xff980fff]
[ 0.456957] pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff]
[ 0.456957] pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff]
[ 0.456957] pci_bus 0000:00: root bus resource [mem 0xfeda7000-0xfeda7fff]
[ 0.456957] pci 0000:00:00.0: [8086:2e10] type 00 class 0x060000
[ 0.456957] pci 0000:00:01.0: [8086:2e11] type 01 class 0x060400
[ 0.456957] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.456957] pci 0000:00:03.0: [8086:2e14] type 00 class 0x078000
[ 0.456957] pci 0000:00:03.0: reg 10: [mem 0xfeda6000-0xfeda600f 64bit]
[ 0.456957] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.456957] pci 0000:00:03.2: [8086:2e16] type 00 class 0x010185
[ 0.456957] pci 0000:00:03.2: reg 10: [io 0xfe80-0xfe87]
[ 0.456957] pci 0000:00:03.2: reg 14: [io 0xfe90-0xfe93]
[ 0.456957] pci 0000:00:03.2: reg 18: [io 0xfea0-0xfea7]
[ 0.456957] pci 0000:00:03.2: reg 1c: [io 0xfeb0-0xfeb3]
[ 0.456957] pci 0000:00:03.2: reg 20: [io 0xfef0-0xfeff]
[ 0.456957] pci 0000:00:03.3: [8086:2e17] type 00 class 0x070002
[ 0.456957] pci 0000:00:03.3: reg 10: [io 0xec98-0xec9f]
[ 0.456957] pci 0000:00:03.3: reg 14: [mem 0xfebd8000-0xfebd8fff]
[ 0.456957] pci 0000:00:19.0: [8086:10de] type 00 class 0x020000
[ 0.456957] pci 0000:00:19.0: reg 10: [mem 0xfebe0000-0xfebfffff]
[ 0.456957] pci 0000:00:19.0: reg 14: [mem 0xfebd9000-0xfebd9fff]
[ 0.456957] pci 0000:00:19.0: reg 18: [io 0xecc0-0xecdf]
[ 0.456957] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.456957] pci 0000:00:1a.0: [8086:3a67] type 00 class 0x0c0300
[ 0.456957] pci 0000:00:1a.0: reg 20: [io 0xff20-0xff3f]
[ 0.456957] pci 0000:00:1a.1: [8086:3a68] type 00 class 0x0c0300
[ 0.456957] pci 0000:00:1a.1: reg 20: [io 0xff00-0xff1f]
[ 0.456957] pci 0000:00:1a.2: [8086:3a69] type 00 class 0x0c0300
[ 0.456957] pci 0000:00:1a.2: reg 20: [io 0xfc00-0xfc1f]
[ 0.456957] pci 0000:00:1a.7: [8086:3a6c] type 00 class 0x0c0320
[ 0.456957] pci 0000:00:1a.7: reg 10: [mem 0xfebda000-0xfebda3ff]
[ 0.456957] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.456957] pci 0000:00:1b.0: [8086:3a6e] type 00 class 0x040300
[ 0.456957] pci 0000:00:1b.0: reg 10: [mem 0xfebdc000-0xfebdffff 64bit]
[ 0.456968] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.456987] pci 0000:00:1c.0: [8086:3a70] type 01 class 0x060400
[ 0.457034] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.457053] pci 0000:00:1c.1: [8086:3a72] type 01 class 0x060400
[ 0.457100] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.457125] pci 0000:00:1d.0: [8086:3a64] type 00 class 0x0c0300
[ 0.457161] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.457198] pci 0000:00:1d.1: [8086:3a65] type 00 class 0x0c0300
[ 0.457235] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.457273] pci 0000:00:1d.2: [8086:3a66] type 00 class 0x0c0300
[ 0.457310] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.457355] pci 0000:00:1d.7: [8086:3a6a] type 00 class 0x0c0320
[ 0.457373] pci 0000:00:1d.7: reg 10: [mem 0xff980000-0xff9803ff]
[ 0.457437] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.457456] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.457503] pci 0000:00:1f.0: [8086:3a14] type 00 class 0x060100
[ 0.460081] pci 0000:00:1f.2: [8086:3a02] type 00 class 0x010601
[ 0.460097] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.460104] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.460111] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.460117] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.460124] pci 0000:00:1f.2: reg 20: [io 0xfec0-0xfedf]
[ 0.460131] pci 0000:00:1f.2: reg 24: [mem 0xff970000-0xff9707ff]
[ 0.460159] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.460174] pci 0000:00:1f.3: [8086:3a60] type 00 class 0x0c0500
[ 0.460187] pci 0000:00:1f.3: reg 10: [mem 0xfebdb000-0xfebdb0ff 64bit]
[ 0.460205] pci 0000:00:1f.3: reg 20: [io 0xece0-0xecff]
[ 0.460253] pci 0000:01:00.0: [1002:5e4b] type 00 class 0x030000
[ 0.460265] pci 0000:01:00.0: reg 10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.460274] pci 0000:01:00.0: reg 18: [mem 0xfe9e0000-0xfe9effff 64bit]
[ 0.460280] pci 0000:01:00.0: reg 20: [io 0xdc00-0xdcff]
[ 0.460291] pci 0000:01:00.0: reg 30: [mem 0xfea00000-0xfea1ffff pref]
[ 0.460306] pci 0000:01:00.0: supports D1 D2
[ 0.460321] pci 0000:01:00.1: [1002:5e6b] type 00 class 0x038000
[ 0.460332] pci 0000:01:00.1: reg 10: [mem 0xfe9f0000-0xfe9fffff 64bit]
[ 0.460368] pci 0000:01:00.1: supports D1 D2
[ 0.460390] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.460393] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.460396] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfeafffff]
[ 0.460399] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.460432] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.460436] pci 0000:00:1c.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.460472] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.460477] pci 0000:00:1c.1: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.460532] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.460540] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.460542] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.460544] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.460546] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000effff] (subtractive decode)
[ 0.460548] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff] (subtractive decode)
[ 0.460550] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfec00000] (subtractive decode)
[ 0.460552] pci 0000:00:1e.0: bridge window [mem 0xcff00000-0xdfffffff] (subtractive decode)
[ 0.460554] pci 0000:00:1e.0: bridge window [mem 0xff980000-0xff980fff] (subtractive decode)
[ 0.460556] pci 0000:00:1e.0: bridge window [mem 0xff97c000-0xff97ffff] (subtractive decode)
[ 0.460558] pci 0000:00:1e.0: bridge window [mem 0xfed20000-0xfed9ffff] (subtractive decode)
[ 0.460560] pci 0000:00:1e.0: bridge window [mem 0xfeda7000-0xfeda7fff] (subtractive decode)
[ 0.460574] pci_bus 0000:00: on NUMA node 0
[ 0.460576] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.461266] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[ 0.461681] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.461987] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI3._PRT]
[ 0.462296] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.462676] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 1.720907] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 1.721666] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 1.722441] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 1.723200] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 1.724231] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 1.725005] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 1.725764] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 1.726522] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 1.726737] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 1.726737] vgaarb: loaded
[ 1.726737] vgaarb: bridge control possible 0000:01:00.0
[ 1.726737] PCI: Using ACPI for IRQ routing
[ 1.731845] PCI: pci_cache_line_size set to 64 bytes
[ 1.731853] pci 0000:00:03.0: no compatible bridge window for [mem 0xfeda6000-0xfeda600f 64bit]
[ 1.731882] pci 0000:00:1f.2: no compatible bridge window for [mem 0xff970000-0xff9707ff]
[ 1.731920] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 1.731922] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 1.731924] reserve RAM buffer: 000000000009e400 - 000000000009ffff
[ 1.731926] reserve RAM buffer: 00000000cfdffc00 - 00000000cfffffff
[ 1.732029] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 1.732037] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 1.733122] Switching to clocksource hpet
[ 1.733161] pnp: PnP ACPI init
[ 1.733169] ACPI: bus type pnp registered
[ 1.740199] pnp 00:00: [bus 00-ff]
[ 1.740202] pnp 00:00: [io 0x0cf8-0x0cff]
[ 1.740204] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 1.740206] pnp 00:00: [io 0x0d00-0xffff window]
[ 1.740208] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 1.740210] pnp 00:00: [mem 0x000c0000-0x000effff window]
[ 1.740211] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 1.740213] pnp 00:00: [mem 0xf0000000-0xfec00000 window]
[ 1.740216] pnp 00:00: [mem 0xcff00000-0xdfffffff window]
[ 1.740218] pnp 00:00: [mem 0xf0000000-0xefffffff window disabled]
[ 1.740220] pnp 00:00: [mem 0xff980000-0xff980fff window]
[ 1.740222] pnp 00:00: [mem 0xff97c000-0xff97ffff window]
[ 1.740224] pnp 00:00: [mem 0xfed20000-0xfed9ffff window]
[ 1.740226] pnp 00:00: [mem 0xfeda7000-0xfeda7fff window]
[ 1.740252] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 1.744895] pnp 00:01: [io 0x0060]
[ 1.744897] pnp 00:01: [io 0x0064]
[ 1.744899] pnp 00:01: [io 0x0062-0x0063]
[ 1.744900] pnp 00:01: [io 0x0065-0x006f]
[ 1.744902] pnp 00:01: [io 0x00e0-0x00ef]
[ 1.744903] pnp 00:01: [io 0x0800-0x085f]
[ 1.744905] pnp 00:01: [io 0x0c00-0x0c7f]
[ 1.744907] pnp 00:01: [io 0x0860-0x08ff]
[ 1.744945] system 00:01: [io 0x0800-0x085f] has been reserved
[ 1.744947] system 00:01: [io 0x0c00-0x0c7f] has been reserved
[ 1.744950] system 00:01: [io 0x0860-0x08ff] has been reserved
[ 1.744952] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.745230] pnp 00:02: [io 0x0080-0x009f]
[ 1.745232] pnp 00:02: [io 0x0000-0x001f]
[ 1.745234] pnp 00:02: [io 0x00c0-0x00df]
[ 1.745236] pnp 00:02: [dma 4]
[ 1.745256] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 1.745461] pnp 00:03: [io 0x00f0-0x00ff]
[ 1.745468] pnp 00:03: [irq 13]
[ 1.745487] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 1.745686] pnp 00:04: [io 0x0061]
[ 1.745708] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 1.745918] pnp 00:05: [io 0x0070-0x007f]
[ 1.745922] pnp 00:05: [irq 8]
[ 1.745942] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 1.762531] pnp 00:06: [io 0x0378-0x037f]
[ 1.762533] pnp 00:06: [io 0x0778-0x077f]
[ 1.762537] pnp 00:06: [irq 7]
[ 1.762539] pnp 00:06: [dma 0 disabled]
[ 1.763722] pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active)
[ 1.769286] pnp 00:07: [io 0x03f8-0x03ff]
[ 1.769290] pnp 00:07: [irq 4]
[ 1.769685] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 1.788831] pnp 00:08: [mem 0xfed00000-0xfed003ff]
[ 1.788857] pnp 00:08: Plug and Play ACPI device, IDs PNP0103 (active)
[ 1.788866] pnp: PnP ACPI: found 9 devices
[ 1.788867] ACPI: ACPI bus type pnp unregistered
[ 1.788869] PnPBIOS: Disabled by ACPI PNP
[ 1.825087] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 1.825090] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 1.825097] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 1.825100] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 1.825111] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 1.825113] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 1.825115] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 1.825117] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 1.825121] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf0000000-0xf01fffff 64bit pref]
[ 1.825124] pci 0000:00:1c.1: BAR 15: assigned [mem 0xf0200000-0xf03fffff 64bit pref]
[ 1.825126] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.825129] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 1.825131] pci 0000:00:1f.2: BAR 5: assigned [mem 0xf0400000-0xf04007ff]
[ 1.825135] pci 0000:00:03.0: BAR 0: assigned [mem 0xf0400800-0xf040080f 64bit]
[ 1.825143] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 1.825145] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 1.825148] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfeafffff]
[ 1.825151] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 1.825154] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 1.825157] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 1.825161] pci 0000:00:1c.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 1.825164] pci 0000:00:1c.0: bridge window [mem 0xf0000000-0xf01fffff 64bit pref]
[ 1.825169] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 1.825172] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 1.825176] pci 0000:00:1c.1: bridge window [mem 0xfe700000-0xfe7fffff]
[ 1.825179] pci 0000:00:1c.1: bridge window [mem 0xf0200000-0xf03fffff 64bit pref]
[ 1.825184] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 1.825215] pci 0000:00:1e.0: setting latency timer to 64
[ 1.825219] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 1.825220] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 1.825222] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 1.825224] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff]
[ 1.825226] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff]
[ 1.825228] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfec00000]
[ 1.825229] pci_bus 0000:00: resource 10 [mem 0xcff00000-0xdfffffff]
[ 1.825231] pci_bus 0000:00: resource 11 [mem 0xff980000-0xff980fff]
[ 1.825233] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff]
[ 1.825235] pci_bus 0000:00: resource 13 [mem 0xfed20000-0xfed9ffff]
[ 1.825237] pci_bus 0000:00: resource 14 [mem 0xfeda7000-0xfeda7fff]
[ 1.825239] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 1.825240] pci_bus 0000:01: resource 1 [mem 0xfe900000-0xfeafffff]
[ 1.825242] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 1.825244] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 1.825246] pci_bus 0000:02: resource 1 [mem 0xfe800000-0xfe8fffff]
[ 1.825248] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf01fffff 64bit pref]
[ 1.825250] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 1.825252] pci_bus 0000:03: resource 1 [mem 0xfe700000-0xfe7fffff]
[ 1.825253] pci_bus 0000:03: resource 2 [mem 0xf0200000-0xf03fffff 64bit pref]
[ 1.825255] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7]
[ 1.825257] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff]
[ 1.825259] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
[ 1.825261] pci_bus 0000:04: resource 7 [mem 0x000c0000-0x000effff]
[ 1.825263] pci_bus 0000:04: resource 8 [mem 0x000f0000-0x000fffff]
[ 1.825264] pci_bus 0000:04: resource 9 [mem 0xf0000000-0xfec00000]
[ 1.825266] pci_bus 0000:04: resource 10 [mem 0xcff00000-0xdfffffff]
[ 1.825268] pci_bus 0000:04: resource 11 [mem 0xff980000-0xff980fff]
[ 1.825270] pci_bus 0000:04: resource 12 [mem 0xff97c000-0xff97ffff]
[ 1.825272] pci_bus 0000:04: resource 13 [mem 0xfed20000-0xfed9ffff]
[ 1.825273] pci_bus 0000:04: resource 14 [mem 0xfeda7000-0xfeda7fff]
[ 1.825326] NET: Registered protocol family 2
[ 1.825377] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 1.825505] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.825731] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.825837] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.825839] TCP: reno registered
[ 1.825841] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.825846] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.825904] NET: Registered protocol family 1
[ 1.826087] pci 0000:01:00.0: Boot video device
[ 1.826091] PCI: CLS 64 bytes, default 64
[ 1.826120] Unpacking initramfs...
[ 2.026360] Freeing initrd memory: 13712k freed
[ 2.030317] Simple Boot Flag at 0x7a set to 0x1
[ 2.030720] audit: initializing netlink socket (disabled)
[ 2.030737] type=2000 audit(1551379310.024:1): initialized
[ 2.039026] highmem bounce pool size: 64 pages
[ 2.039029] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 2.039163] VFS: Disk quotas dquot_6.5.2
[ 2.039185] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.039247] msgmni has been set to 1695
[ 2.039377] alg: No test for stdrng (krng)
[ 2.039396] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 2.039400] io scheduler noop registered
[ 2.039401] io scheduler deadline registered
[ 2.039415] io scheduler cfq registered (default)
[ 2.039604] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 2.039618] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 2.039620] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 2.040139] GHES: HEST is not enabled!
[ 2.040149] isapnp: Scanning for PnP cards...
[ 2.392889] isapnp: No Plug & Play device found
[ 2.392928] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.413265] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.433818] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.453954] 0000:00:03.3: ttyS1 at I/O 0xec98 (irq = 17) is a 16550A
[ 2.454267] Linux agpgart interface v0.103
[ 2.454481] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 2.457370] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.457393] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.457465] mousedev: PS/2 mouse device common for all mice
[ 2.457502] rtc_cmos 00:05: RTC can wake from S4
[ 2.457598] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 2.457619] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 2.457710] TCP: cubic registered
[ 2.457749] NET: Registered protocol family 10
[ 2.457928] Mobile IPv6
[ 2.457931] NET: Registered protocol family 17
[ 2.457934] Registering the dns_resolver key type
[ 2.457969] Using IPI No-Shortcut mode
[ 2.458050] PM: Hibernation image not present or could not be loaded.
[ 2.458059] registered taskstats version 1
[ 2.458364] rtc_cmos 00:05: setting system clock to 2019-02-28 18:41:50 UTC (1551379310)
[ 2.458442] Freeing unused kernel memory: 416k freed
[ 2.458600] Write protecting the kernel text: 3496k
[ 2.458617] Write protecting the kernel read-only data: 984k
[ 2.466433] udevd[49]: starting version 175
[ 2.482197] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 2.482200] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 2.482244] e1000e 0000:00:19.0: setting latency timer to 64
[ 2.482291] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 2.483898] usbcore: registered new interface driver usbfs
[ 2.483917] usbcore: registered new interface driver hub
[ 2.489606] microcode: CPU0 sig=0x1067a, pf=0x1, revision=0xa07
[ 2.492497] SCSI subsystem initialized
[ 2.494770] usbcore: registered new device driver usb
[ 2.495073] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.495247] libata version 3.00 loaded.
[ 2.508399] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.524005] microcode: CPU0 updated to revision 0xa0b, date = 2010-09-28
[ 2.526168] microcode: CPU1 sig=0x1067a, pf=0x1, revision=0xa07
[ 2.532345] microcode: CPU1 updated to revision 0xa0b, date = 2010-09-28
[ 2.532644] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 2.684065] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:25:64:38:a7:70
[ 2.684068] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection
[ 2.684097] e1000e 0000:00:19.0: eth0: MAC: 8, PHY: 8, PBA No: 2021FF-0FF
[ 2.684136] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 2.684139] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 2.684157] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 2.684179] ehci_hcd 0000:00:1a.7: debug port 1
[ 2.688063] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 2.688081] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xfebda000
[ 2.700014] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 2.700041] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.700045] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.700048] usb usb1: Product: EHCI Host Controller
[ 2.700051] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 2.700053] usb usb1: SerialNumber: 0000:00:1a.7
[ 2.700192] hub 1-0:1.0: USB hub found
[ 2.700202] hub 1-0:1.0: 6 ports detected
[ 2.700706] ata_generic 0000:00:03.2: setting latency timer to 64
[ 2.700947] scsi0 : ata_generic
[ 2.701023] scsi1 : ata_generic
[ 2.701059] ata1: PATA max UDMA/100 cmd 0xfe80 ctl 0xfe90 bmdma 0xfef0 irq 18
[ 2.701061] ata2: PATA max UDMA/100 cmd 0xfea0 ctl 0xfeb0 bmdma 0xfef8 irq 18
[ 2.701116] ahci 0000:00:1f.2: version 3.0
[ 2.701182] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x2f impl SATA mode
[ 2.701185] ahci 0000:00:1f.2: flags: 64bit ncq sntf led clo pio ems sxs
[ 2.701188] ahci 0000:00:1f.2: setting latency timer to 64
[ 2.732520] scsi2 : ahci
[ 2.732577] scsi3 : ahci
[ 2.732625] scsi4 : ahci
[ 2.732676] scsi5 : ahci
[ 2.732727] scsi6 : ahci
[ 2.732781] scsi7 : ahci
[ 2.734318] ata3: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400100 irq 18
[ 2.734321] ata4: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400180 irq 18
[ 2.734323] ata5: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400200 irq 18
[ 2.734325] ata6: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400280 irq 18
[ 2.734327] ata7: DUMMY
[ 2.734329] ata8: SATA max UDMA/133 abar m2048@0xf0400000 port 0xf0400380 irq 18
[ 2.734352] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 2.734355] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 2.734362] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 2.734392] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 2.734419] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.734421] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.734423] usb usb2: Product: UHCI Host Controller
[ 2.734425] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 2.734426] usb usb2: SerialNumber: 0000:00:1a.0
[ 2.734500] hub 2-0:1.0: USB hub found
[ 2.734504] hub 2-0:1.0: 2 ports detected
[ 2.734570] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 2.734573] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 2.734581] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 3
[ 2.734607] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 2.734632] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.734634] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.734636] usb usb3: Product: UHCI Host Controller
[ 2.734638] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 2.734639] usb usb3: SerialNumber: 0000:00:1a.1
[ 2.734718] hub 3-0:1.0: USB hub found
[ 2.734722] hub 3-0:1.0: 2 ports detected
[ 2.734782] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 2.734785] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 2.734791] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 4
[ 2.734811] uhci_hcd 0000:00:1a.2: irq 22, io base 0x0000fc00
[ 2.734835] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.734837] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.734839] usb usb4: Product: UHCI Host Controller
[ 2.734841] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 2.734842] usb usb4: SerialNumber: 0000:00:1a.2
[ 2.735043] hub 4-0:1.0: USB hub found
[ 2.735047] hub 4-0:1.0: 2 ports detected
[ 2.735107] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 2.735110] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.735117] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 2.735143] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 2.735168] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.735170] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.735172] usb usb5: Product: UHCI Host Controller
[ 2.735173] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 2.735175] usb usb5: SerialNumber: 0000:00:1d.0
[ 2.735303] hub 5-0:1.0: USB hub found
[ 2.735308] hub 5-0:1.0: 2 ports detected
[ 2.735371] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 2.735373] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 2.735379] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 2.735399] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 2.735424] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.735426] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.735428] usb usb6: Product: UHCI Host Controller
[ 2.735429] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 2.735431] usb usb6: SerialNumber: 0000:00:1d.1
[ 2.735558] hub 6-0:1.0: USB hub found
[ 2.735561] hub 6-0:1.0: 2 ports detected
[ 2.735621] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 2.735624] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 2.735631] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 2.735652] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 2.735677] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.735679] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.735681] usb usb7: Product: UHCI Host Controller
[ 2.735682] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 2.735684] usb usb7: SerialNumber: 0000:00:1d.2
[ 2.735807] hub 7-0:1.0: USB hub found
[ 2.735810] hub 7-0:1.0: 2 ports detected
[ 2.736394] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 2.736397] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 2.736406] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 8
[ 2.736425] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.740713] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 2.740730] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xff980000
[ 2.752029] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 2.752054] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.752057] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.752060] usb usb8: Product: EHCI Host Controller
[ 2.752063] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 2.752066] usb usb8: SerialNumber: 0000:00:1d.7
[ 2.752201] hub 8-0:1.0: USB hub found
[ 2.752205] hub 8-0:1.0: 6 ports detected
[ 3.031083] Refined TSC clocksource calibration: 3324.589 MHz.
[ 3.031087] Switching to clocksource tsc
[ 3.052019] ata6: SATA link down (SStatus 4 SControl 300)
[ 3.052036] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.052052] ata8: SATA link down (SStatus 4 SControl 300)
[ 3.052065] ata5: SATA link down (SStatus 4 SControl 300)
[ 3.052080] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.053694] ata3.00: supports DRM functions and may not be fully accessible
[ 3.053738] ata3.00: ATA-9: Samsung SSD 850 EVO 250GB, EMT01B6Q, max UDMA/133
[ 3.053742] ata3.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 3.053995] ata3.00: supports DRM functions and may not be fully accessible
[ 3.054039] ata3.00: configured for UDMA/133
[ 3.054163] scsi 2:0:0:0: Direct-Access ATA Samsung SSD 850 EMT0 PQ: 0 ANSI: 5
[ 3.054982] ata4.00: ATAPI: HL-DT-ST DVD+/-RW GH50N, B100, max UDMA/100
[ 3.058763] ata4.00: configured for UDMA/100
[ 3.067358] scsi 3:0:0:0: CD-ROM HL-DT-ST DVD+-RW GH50N B100 PQ: 0 ANSI: 5
[ 3.072316] sd 2:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 3.072372] sd 2:0:0:0: [sda] Write Protect is off
[ 3.072374] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.072392] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.072902] sda: sda1 sda2 < sda5 >
[ 3.073121] sd 2:0:0:0: [sda] Attached SCSI disk
[ 3.074122] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 3.074204] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 3.082136] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.082140] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.082444] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 3.368013] usb 4-1: new full-speed USB device number 2 using uhci_hcd
[ 3.541844] usb 4-1: New USB device found, idVendor=413c, idProduct=1005
[ 3.541848] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.541851] usb 4-1: Product: Dell Multimedia Pro Keyboard Hub
[ 3.541854] usb 4-1: Manufacturer: Dell
[ 3.549865] hub 4-1:1.0: USB hub found
[ 3.550846] hub 4-1:1.0: 3 ports detected
[ 3.792012] usb 4-2: new low-speed USB device number 3 using uhci_hcd
[ 3.963844] usb 4-2: New USB device found, idVendor=046d, idProduct=c077
[ 3.963849] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.963852] usb 4-2: Product: USB Optical Mouse
[ 3.963854] usb 4-2: Manufacturer: Logitech
[ 3.983239] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1a.2/usb4/4-2/4-2:1.0/input/input0
[ 3.983298] generic-usb 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1a.2-2/input0
[ 3.983316] usbcore: registered new interface driver usbhid
[ 3.983317] usbhid: USB HID core driver
[ 4.041847] usb 4-1.1: new low-speed USB device number 4 using uhci_hcd
[ 4.183843] usb 4-1.1: New USB device found, idVendor=413c, idProduct=2011
[ 4.183847] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.183850] usb 4-1.1: Product: Dell Multimedia Pro Keyboard
[ 4.183853] usb 4-1.1: Manufacturer: Dell
[ 4.222232] input: Dell Dell Multimedia Pro Keyboard as /devices/pci0000:00/0000:00:1a.2/usb4/4-1/4-1.1/4-1.1:1.0/input/input1
[ 4.222268] generic-usb 0003:413C:2011.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell Multimedia Pro Keyboard] on usb-0000:00:1a.2-1.1/input0
[ 4.271906] input: Dell Dell Multimedia Pro Keyboard as /devices/pci0000:00/0000:00:1a.2/usb4/4-1/4-1.1/4-1.1:1.1/input/input2
[ 4.271969] generic-usb 0003:413C:2011.0003: input,hidraw2: USB HID v1.10 Device [Dell Dell Multimedia Pro Keyboard] on usb-0000:00:1a.2-1.1/input1
[ 8.161606] PM: Starting manual resume from disk
[ 8.161609] PM: Hibernation image partition 8:5 present
[ 8.161610] PM: Looking for hibernation image.
[ 8.161756] PM: Image not found (code -22)
[ 8.161759] PM: Hibernation image not present or could not be loaded.
[ 8.178409] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.316814] udevd[370]: starting version 175
[ 8.383110] iTCO_vendor_support: vendor-support=0
[ 8.383516] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 8.383582] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 8.399570] [drm] Initialized drm 1.1.0 20060810
[ 8.412726] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 8.414629] [drm] radeon kernel modesetting enabled.
[ 8.415422] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 8.415428] ACPI: Power Button [VBTN]
[ 8.415477] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 8.415480] ACPI: Power Button [PWRF]
[ 8.417076] wmi: Mapper loaded
[ 8.420726] [drm] initializing kernel modesetting (RV410 0x1002:0x5E4B 0x174B:0x0620).
[ 8.420742] [drm] register mmio base: 0xFE9E0000
[ 8.420744] [drm] register mmio size: 65536
[ 8.420924] ATOM BIOS: RV410
[ 8.420941] [drm] Generation 2 PCI interface, using max accessible memory
[ 8.420946] radeon 0000:01:00.0: VRAM: 256M 0x00000000D0000000 - 0x00000000DFFFFFFF (256M used)
[ 8.420948] radeon 0000:01:00.0: GTT: 512M 0x00000000B0000000 - 0x00000000CFFFFFFF
[ 8.423026] [drm] Detected VRAM RAM=256M, BAR=256M
[ 8.423029] [drm] RAM width 128bits DDR
[ 8.424222] [TTM] Zone kernel: Available graphics memory: 434354 kiB
[ 8.424224] [TTM] Zone highmem: Available graphics memory: 1682612 kiB
[ 8.424226] [TTM] Initializing pool allocator
[ 8.424245] [drm] radeon: 256M of VRAM memory ready
[ 8.424247] [drm] radeon: 512M of GTT memory ready.
[ 8.424260] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 8.424548] [drm] radeon: ib pool ready.
[ 8.425285] [drm] PCIE GART of 512M enabled (table at 0x00000000D0040000).
[ 8.425292] [drm] radeon: 2 quad pipes, 1 z pipes initialized.
[ 8.425306] radeon 0000:01:00.0: WB enabled
[ 8.425309] [drm] fence driver on ring 0 use gpu addr 0xb0000000 and cpu addr 0xff92a000
[ 8.425311] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 8.425313] [drm] Driver supports precise vblank timestamp query.
[ 8.425322] [drm] radeon: irq initialized.
[ 8.425355] [drm] Loading R400 Microcode
[ 8.433488] parport_pc 00:06: reported by Plug and Play ACPI
[ 8.433539] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 8.463773] input: Dell WMI hotkeys as /devices/virtual/input/input5
[ 8.465707] [drm] radeon: ring at 0x00000000B0001000
[ 8.465725] [drm] ring test succeeded in 1 usecs
[ 8.465831] [drm] ib test succeeded in 0 usecs
[ 8.466003] [drm] Radeon Display Connectors
[ 8.466005] [drm] Connector 0:
[ 8.466006] [drm] VGA
[ 8.466008] [drm] DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[ 8.466009] [drm] Encoders:
[ 8.466011] [drm] CRT1: INTERNAL_DAC1
[ 8.466012] [drm] Connector 1:
[ 8.466013] [drm] S-video
[ 8.466014] [drm] Encoders:
[ 8.466015] [drm] TV1: INTERNAL_DAC2
[ 8.466016] [drm] Connector 2:
[ 8.466018] [drm] DVI-I
[ 8.466019] [drm] HPD1
[ 8.466020] [drm] DDC: 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[ 8.466021] [drm] Encoders:
[ 8.466023] [drm] CRT2: INTERNAL_DAC2
[ 8.466024] [drm] DFP1: INTERNAL_TMDS1
[ 8.526155] [drm] fb mappable at 0xD00C0000
[ 8.526157] [drm] vram apper at 0xD0000000
[ 8.526159] [drm] size 7057408
[ 8.526160] [drm] fb depth is 24
[ 8.526161] [drm] pitch is 6720
[ 8.526206] fbcon: radeondrmfb (fb0) is primary device
[ 8.582514] Console: switching to colour frame buffer device 210x65
[ 8.588366] fb0: radeondrmfb frame buffer device
[ 8.588368] drm: registered panic notifier
[ 8.588372] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0
[ 8.847289] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
[ 9.033644] Adding 8120316k swap on /dev/sda5. Priority:-1 extents:1 across:8120316k SS
[ 9.042426] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 9.069868] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 9.089188] loop: module loaded
[ 9.489401] RPC: Registered named UNIX socket transport module.
[ 9.489403] RPC: Registered udp transport module.
[ 9.489405] RPC: Registered tcp transport module.
[ 9.489406] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 9.492868] FS-Cache: Loaded
[ 9.497682] NFS: Registering the id_resolver key type
[ 9.497693] FS-Cache: Netfs 'nfs' registered for caching
[ 9.501210] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 9.938248] Bluetooth: Core ver 2.16
[ 9.938260] NET: Registered protocol family 31
[ 9.938261] Bluetooth: HCI device and connection manager initialized
[ 9.938263] Bluetooth: HCI socket layer initialized
[ 9.938264] Bluetooth: L2CAP socket layer initialized
[ 9.938268] Bluetooth: SCO socket layer initialized
[ 9.945488] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.945490] Bluetooth: BNEP filters: protocol multicast
[ 9.949545] Bluetooth: RFCOMM TTY layer initialized
[ 9.949549] Bluetooth: RFCOMM socket layer initialized
[ 9.949550] Bluetooth: RFCOMM ver 1.11
[ 10.007576] lp0: using parport0 (interrupt-driven).
[ 10.013286] ppdev: user-space parallel port driver
[ 10.180336] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.800800] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input7
[ 13.552858] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 13.552951] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 24.160007] eth0: no IPv6 routers present
[ 69.564018] usb 8-4: new high-speed USB device number 2 using ehci_hcd
[ 69.698045] usb 8-4: New USB device found, idVendor=03f0, idProduct=5307
[ 69.698049] usb 8-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 69.698053] usb 8-4: Product: v165w
[ 69.698055] usb 8-4: Manufacturer: HP
[ 69.698058] usb 8-4: SerialNumber: AA220A0D00000094
[ 69.706164] Initializing USB Mass Storage driver...
[ 69.708113] scsi8 : usb-storage 8-4:1.0
[ 69.708344] usbcore: registered new interface driver usb-storage
[ 69.708346] USB Mass Storage support registered.
[ 71.375705] scsi 8:0:0:0: Direct-Access hp v165w 3276 PQ: 0 ANSI: 4
[ 71.376244] sd 8:0:0:0: Attached scsi generic sg2 type 0
[ 71.377692] sd 8:0:0:0: [sdb] 63406080 512-byte logical blocks: (32.4 GB/30.2 GiB)
[ 71.378546] sd 8:0:0:0: [sdb] Write Protect is off
[ 71.378549] sd 8:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 71.379305] sd 8:0:0:0: [sdb] No Caching mode page present
[ 71.379310] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 71.382425] sd 8:0:0:0: [sdb] No Caching mode page present
[ 71.382429] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 71.383614] sdb: sdb1
[ 71.387051] sd 8:0:0:0: [sdb] No Caching mode page present
[ 71.387055] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 71.387059] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[ 84.379198] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 437.536277] I-pipe: head domain RTAI registered.
[ 437.536281] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 437.536301] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 437.536304] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20777101, CLK_FREQ 3324546000, CPU_FREQ 3324546000
[ 437.536306] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 437.536308] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20777101, 20777101, 20757250
[ 437.548528] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 437.548546] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 437.548549] RTAI[sched]: hard timer type/freq = APIC/20777101(Hz); default timing: oneshot; linear timed lists.
[ 437.548551] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3324546000 hz.
[ 437.548553] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 437.555503] RTAI[math]: loaded.
[ 439.832908] RTAI[math]: unloaded.
[ 439.833973] SCHED releases registered named ALIEN PEDV$D
[ 439.837256] RTAI[malloc]: unloaded.
[ 439.936011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 439.937413] I-pipe: head domain RTAI unregistered.
[ 439.937442] RTAI[hal]: unmounted.
[ 874.548665] sdb: detected capacity change from 32463912960 to 0
[ 876.789224] usb 8-4: USB disconnect, device number 2
[ 1056.565104] I-pipe: head domain RTAI registered.
[ 1056.565108] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1056.565128] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1056.565130] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20777101, CLK_FREQ 3324546000, CPU_FREQ 3324546000
[ 1056.565132] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1056.565135] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20777101, 20777101, 20758750
[ 1056.571317] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1056.571335] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1056.571338] RTAI[sched]: hard timer type/freq = APIC/20777101(Hz); default timing: oneshot; linear timed lists.
[ 1056.571341] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3324546000 hz.
[ 1056.571342] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1056.578710] RTAI[math]: loaded.
[ 1058.940828] RTAI[math]: unloaded.
[ 1058.941847] SCHED releases registered named ALIEN PEDV$D
[ 1058.945541] RTAI[malloc]: unloaded.
[ 1059.044014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1059.045114] I-pipe: head domain RTAI unregistered.
[ 1059.045139] RTAI[hal]: unmounted.
[ 1998.155722] I-pipe: head domain RTAI registered.
[ 1998.155726] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1998.155752] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1998.155755] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20777101, CLK_FREQ 3324546000, CPU_FREQ 3324546000
[ 1998.155757] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1998.155759] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20777101, 20777101, 4322000
[ 1998.161981] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1998.162002] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1998.162005] RTAI[sched]: hard timer type/freq = APIC/20777101(Hz); default timing: oneshot; linear timed lists.
[ 1998.162008] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3324546000 hz.
[ 1998.162009] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1998.165320] RTAI[math]: loaded.
[ 2000.520753] RTAI[math]: unloaded.
[ 2000.521774] SCHED releases registered named ALIEN PEDV$D
[ 2000.533232] RTAI[malloc]: unloaded.
[ 2000.632010] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2000.633104] I-pipe: head domain RTAI unregistered.
[ 2000.633128] RTAI[hal]: unmounted.
[ 2130.813665] I-pipe: head domain RTAI registered.
[ 2130.813669] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 2130.813689] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2130.813692] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20777101, CLK_FREQ 3324546000, CPU_FREQ 3324546000
[ 2130.813694] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 2130.813697] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20777101, 20777101, 18907250
[ 2130.818668] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2130.818688] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 2130.818692] RTAI[sched]: hard timer type/freq = APIC/20777101(Hz); default timing: oneshot; linear timed lists.
[ 2130.818694] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3324546000 hz.
[ 2130.818696] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 2130.822883] RTAI[math]: loaded.
[ 2133.171137] RTAI[math]: unloaded.
[ 2133.172199] SCHED releases registered named ALIEN PEDV$D
[ 2133.174448] RTAI[malloc]: unloaded.
[ 2133.272013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2133.273141] I-pipe: head domain RTAI unregistered.
[ 2133.273166] RTAI[hal]: unmounted.
thanks again
28 Feb 2019 19:48 #127351
You appear to be loading a config called "motenc"
Are you using a motenc card?
- smorin
28 Feb 2019 20:21 #127355
by smorin
Yes, I will be installing this card:
www.vitalsystem.com/portal/motion/motenc/motenc_lite.php
MOTENC-Lite: 4-Axis Motion Control & Data Acquisition PCI Board (pn 7541). This is what I have in the OLD PC (which is currently running the milling machine). I have another one on the way for the NEW PC.
28 Feb 2019 20:26 #127357
The error you see is _probably_ because the card is not found by the driver. (Not really a surprise if it is in another PC....)
The following user(s) said Thank You: Leon82
- Leon82
- Thank you received: 79
28 Feb 2019 20:38 - 28 Feb 2019 20:40 #127358
by Leon82
Replied by Leon82 on topic Upgrading from Axis 2.3.1
I've gotten errors launching my machines from my other pic because it could not find the parallel port. You will need the card, or create a Sim to experiment with.
If the cabling is the same, like the SATA and power, put your new hard drive in the old PC and try to launch the machine.
Last edit: 28 Feb 2019 20:40 by Leon82.
- smorin
28 Feb 2019 20:44 #127359
by smorin
Replied by smorin on topic Upgrading from Axis 2.3.1
OK, since the card is on the way, I will table this thread until it's installed and ready to go.
Thanks so much for your help!
- smorin
10 Sep 2019 20:13 - 10 Sep 2019 20:14 #144739
by smorin
Hello!
I am finally ready to go. we have installed the same model of motenc card:
here
also added an add-on printer port (with 2 LPT ports)because the motherboard does no have one on it
i copied the contents of the linuxcnc folder from the old computer into the new one (i deleted the contens of the new one just in case)
I fired up linuxcnc and chose the old config from the MY CONFIGURATIONS section of the selector
It is now generating thr following error
thanks
Sam
here
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=halui
DISPLAY=axis
* BufferType = 0
Killing task linuxcncsvr, PID=3887
3887
[ 0.000000] BIOS-e820: 0000000000000000 - 0000000000091800 (usable)
[ 0.000000] BIOS-e820: 0000000000091800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000d1522000 (usable)
[ 0.000000] BIOS-e820: 00000000d1522000 - 00000000d1529000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000d1529000 - 00000000d195f000 (usable)
[ 0.000000] BIOS-e820: 00000000d195f000 - 00000000d1df4000 (reserved)
[ 0.000000] BIOS-e820: 00000000d1df4000 - 00000000d7eea000 (usable)
[ 0.000000] BIOS-e820: 00000000d7eea000 - 00000000d8000000 (reserved)
[ 0.000000] BIOS-e820: 00000000d8000000 - 00000000d875f000 (usable)
[ 0.000000] BIOS-e820: 00000000d875f000 - 00000000d8800000 (reserved)
[ 0.000000] BIOS-e820: 00000000d8800000 - 00000000d8fae000 (usable)
[ 0.000000] BIOS-e820: 00000000d8fae000 - 00000000d9000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000d9000000 - 00000000da71c000 (usable)
[ 0.000000] BIOS-e820: 00000000da71c000 - 00000000da800000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000da800000 - 00000000dbb0c000 (usable)
[ 0.000000] BIOS-e820: 00000000dbb0c000 - 00000000dc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000dd000000 - 00000000df200000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000081ee00000 (usable)
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 9020/0N4YC8, BIOS A16 05/18/2016
[ 0.000000] last_pfn = 0xdbb0c max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] C0000-E3FFF write-protect
[ 0.000000] E4000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] 0 base 0000000000 mask 7800000000 write-back
[ 0.000000] 1 base 0800000000 mask 7FE0000000 write-back
[ 0.000000] 2 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 3 base 00DE000000 mask 7FFE000000 uncachable
[ 0.000000] 4 base 00DD000000 mask 7FFF000000 uncachable
[ 0.000000] 5 base 081F000000 mask 7FFF000000 uncachable
[ 0.000000] 6 base 081EE00000 mask 7FFFE00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] e820 update range: 00000000dd000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd9b0] fd9b0
[ 0.000000] Base memory trampoline at [c008d000] 8d000 size 16384
[ 0.000000] RAMDISK: 36410000 - 37200000
[ 0.000000] ACPI: RSDP 000f0490 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT d8fee090 0009C (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP d8ff9b38 0010C (v05 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT d8fee1b8 0B97E (v02 DELL CBX3 00000014 INTL 20091112)
[ 0.000000] ACPI: FACS da7fe080 00040
[ 0.000000] ACPI: APIC d8ff9c48 00092 (v03 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT d8ff9ce0 00044 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: SLIC d8ff9d28 00176 (v03 DELL CBX3 01072009 MSFT 00010013)
[ 0.000000] ACPI: LPIT d8ff9ea0 0005C (v01 DELL CBX3 00000000 AMI. 00000005)
[ 0.000000] ACPI: SSDT d8ff9f00 00539 (v01 PmRef Cpu0Ist 00003000 INTL 20120711)
[ 0.000000] ACPI: SSDT d8ffa440 00AD8 (v01 PmRef CpuPm 00003000 INTL 20120711)
[ 0.000000] ACPI: SSDT d8ffaf18 001C7 (v01 PmRef LakeTiny 00003000 INTL 20120711)
[ 0.000000] ACPI: HPET d8ffb0e0 00038 (v01 DELL CBX3 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT d8ffb118 0036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[ 0.000000] ACPI: MCFG d8ffb488 0003C (v01 DELL CBX3 01072009 MSFT 00000097)
[ 0.000000] ACPI: SSDT d8ffb4c8 034D6 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
[ 0.000000] ACPI: ASF! d8ffe9a0 000A5 (v32 INTEL HCG 00000001 TFSM 000F4240)
[ 0.000000] ACPI: MSDM d8ffea48 00055 (v03 DELL CBX3 06222004 AMI 00010013)
[ 0.000000] ACPI: DMAR d8ffeaa0 000B8 (v01 INTEL HSW 00000001 INTL 00000001)
[ 0.000000] 2627MB HIGHMEM available.
[ 0.000000] HighMem 0x000377fe -> 0x000dbb0c
[ 0.000000] 0: 0x00000010 -> 0x00000091
[ 0.000000] 0: 0x00000100 -> 0x000d1522
[ 0.000000] 0: 0x000d1529 -> 0x000d195f
[ 0.000000] 0: 0x000d1df4 -> 0x000d7eea
[ 0.000000] 0: 0x000d8000 -> 0x000d875f
[ 0.000000] 0: 0x000d8800 -> 0x000d8fae
[ 0.000000] 0: 0x000d9000 -> 0x000da71c
[ 0.000000] 0: 0x000da800 -> 0x000dbb0c
[ 0.000000] On node 0 totalpages: 897796
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4898200
[ 0.000000] DMA zone: 3937 pages, LIFO batch:0
[ 0.000000] HighMem zone: 5255 pages used for memmap
[ 0.000000] HighMem zone: 665342 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x05] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x07] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] SMP: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: 0000000000091000 - 0000000000092000
[ 0.000000] PM: Registered nosave memory: 0000000000092000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at df200000 (gap: df200000:18e00000)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 890765
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=31f67616-0553-4fa1-84cb-329a88b91e8b ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 7198688 bytes of page_cgroup
[ 0.000000] Initializing HighMem for node 0 (000377fe:000dbb0c)
[ 0.000000] Memory: 3534468k/3599408k available (3495k kernel code, 56716k reserved, 1237k data, 416k init, 2682388k highmem)
[ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[ 0.000000] Extended CMOS year: 2000
[ 0.004000] Detected 3591.929 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 7183.85 BogoMIPS (lpj=14367716)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000023] Security Framework initialized
[ 0.000026] AppArmor: AppArmor disabled by boot time parameter
[ 0.000034] Mount-cache hash table entries: 512
[ 0.000130] Initializing cgroup subsys cpuacct
[ 0.000131] Initializing cgroup subsys memory
[ 0.000135] Initializing cgroup subsys devices
[ 0.000136] Initializing cgroup subsys freezer
[ 0.000137] Initializing cgroup subsys net_cls
[ 0.000138] Initializing cgroup subsys blkio
[ 0.000140] Initializing cgroup subsys perf_event
[ 0.000156] CPU: Physical Processor ID: 0
[ 0.000157] CPU: Processor Core ID: 0
[ 0.000160] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000160] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.001544] mce: CPU supports 9 MCE banks
[ 0.001553] CPU0: Thermal monitoring enabled (TM1)
[ 0.001611] ACPI: Core revision 20120320
[ 0.007527] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.007855] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.047528] CPU0: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz stepping 03
[ 0.154893] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver.
[ 0.154898] ... version: 3
[ 0.154899] ... bit width: 48
[ 0.154899] ... generic registers: 4
[ 0.154900] ... value mask: 0000ffffffffffff
[ 0.154901] ... max period: 000000007fffffff
[ 0.154902] ... fixed-purpose events: 3
[ 0.154903] ... event mask: 000000070000000f
[ 0.166938] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.178908] CPU 1 irqstacks, hard=f3d36000 soft=f3d38000
[ 0.178909] Booting Node 0, Processors #1
[ 0.189177] Initializing CPU#1
[ 0.193433] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.198903] CPU 2 irqstacks, hard=f3d48000 soft=f3d4a000
[ 0.198904] #2
[ 0.209171] Initializing CPU#2
[ 0.213424] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.218894] CPU 3 irqstacks, hard=f3d7c000 soft=f3d7e000
[ 0.218895] #3
[ 0.229162] Initializing CPU#3
[ 0.233415] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.238886] CPU 4 irqstacks, hard=f3d8e000 soft=f3d90000
[ 0.238887] #4
[ 0.249228] Initializing CPU#4
[ 0.253428] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.258878] CPU 5 irqstacks, hard=f3da0000 soft=f3da2000
[ 0.258879] #5
[ 0.269145] Initializing CPU#5
[ 0.273400] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.278870] CPU 6 irqstacks, hard=f3db4000 soft=f3db6000
[ 0.278872] #6
[ 0.289138] Initializing CPU#6
[ 0.293393] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.298861] CPU 7 irqstacks, hard=f3de2000 soft=f3de4000
[ 0.298862] #7 Ok.
[ 0.309129] Initializing CPU#7
[ 0.313383] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.313403] Brought up 8 CPUs
[ 0.313405] Total of 8 processors activated (57470.86 BogoMIPS).
[ 0.318912] devtmpfs: initialized
[ 0.319040] PM: Registering ACPI NVS region [mem 0xd1522000-0xd1528fff] (28672 bytes)
[ 0.319042] PM: Registering ACPI NVS region [mem 0xda71c000-0xda7fffff] (933888 bytes)
[ 0.319109] dummy:
[ 0.319143] NET: Registered protocol family 16
[ 0.319208] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.319210] ACPI: bus type pci registered
[ 0.319241] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.319243] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.319244] PCI: Using MMCONFIG for extended config space
[ 0.319245] PCI: Using configuration type 1 for base access
[ 0.319251] dmi type 0xB1 record - unknown flag
[ 0.319627] bio: create slab <bio-0> at 0
[ 0.319683] ACPI: Added _OSI(Module Device)
[ 0.319685] ACPI: Added _OSI(Processor Device)
[ 0.319686] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.319687] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.321426] ACPI: EC: Look up EC in DSDT
[ 0.323336] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.325968] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.326366] ACPI: SSDT dbff4c18 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20120711)
[ 0.326838] ACPI: Dynamic OEM Table Load:
[ 0.326840] ACPI: SSDT (null) 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20120711)
[ 0.327065] ACPI: SSDT dbff4618 005AA (v01 PmRef ApIst 00003000 INTL 20120711)
[ 0.327612] ACPI: Dynamic OEM Table Load:
[ 0.327614] ACPI: SSDT (null) 005AA (v01 PmRef ApIst 00003000 INTL 20120711)
[ 0.327716] ACPI: SSDT dbff3d98 00119 (v01 PmRef ApCst 00003000 INTL 20120711)
[ 0.328189] ACPI: Dynamic OEM Table Load:
[ 0.328191] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20120711)
[ 0.329187] ACPI: Interpreter enabled
[ 0.329192] ACPI: (supports S0 S3 S4 S5)
[ 0.329212] ACPI: Using IOAPIC for interrupt routing
[ 0.335022] ACPI: No dock devices found.
[ 0.335026] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.335286] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.335659] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.335660] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.335662] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.335663] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.335664] pci_root PNP0A08:00: host bridge window [mem 0xdf200000-0xfeafffff]
[ 0.335681] PCI host bridge to bus 0000:00
[ 0.335682] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.335683] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.335684] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.335686] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.335687] pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff]
[ 0.335692] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.335719] pci 0000:00:02.0: [8086:0412] type 00 class 0x030000
[ 0.335727] pci 0000:00:02.0: reg 10: [mem 0xf7800000-0xf7bfffff 64bit]
[ 0.335731] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.335735] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.335753] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
[ 0.335759] pci 0000:00:03.0: reg 10: [mem 0xf7f34000-0xf7f37fff 64bit]
[ 0.335804] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[ 0.335821] pci 0000:00:14.0: reg 10: [mem 0xf7f20000-0xf7f2ffff 64bit]
[ 0.335864] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.335881] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[ 0.335899] pci 0000:00:16.0: reg 10: [mem 0xf7f40000-0xf7f4000f 64bit]
[ 0.335945] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.335964] pci 0000:00:16.3: [8086:8c3d] type 00 class 0x070002
[ 0.335978] pci 0000:00:16.3: reg 10: [io 0xf0e0-0xf0e7]
[ 0.335985] pci 0000:00:16.3: reg 14: [mem 0xf7f3e000-0xf7f3efff]
[ 0.336050] pci 0000:00:19.0: [8086:153a] type 00 class 0x020000
[ 0.336065] pci 0000:00:19.0: reg 10: [mem 0xf7f00000-0xf7f1ffff]
[ 0.336073] pci 0000:00:19.0: reg 14: [mem 0xf7f3d000-0xf7f3dfff]
[ 0.336080] pci 0000:00:19.0: reg 18: [io 0xf080-0xf09f]
[ 0.336122] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.336144] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[ 0.336162] pci 0000:00:1a.0: reg 10: [mem 0xf7f3c000-0xf7f3c3ff]
[ 0.336226] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.336249] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[ 0.336261] pci 0000:00:1b.0: reg 10: [mem 0xf7f30000-0xf7f33fff 64bit]
[ 0.336307] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.336325] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[ 0.336369] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.336387] pci 0000:00:1c.1: [8086:8c12] type 01 class 0x060400
[ 0.336433] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.336452] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400
[ 0.336498] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.336517] pci 0000:00:1c.4: [8086:8c18] type 01 class 0x060400
[ 0.336565] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.336591] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[ 0.336610] pci 0000:00:1d.0: reg 10: [mem 0xf7f3b000-0xf7f3b3ff]
[ 0.336674] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.336695] pci 0000:00:1f.0: [8086:8c4e] type 00 class 0x060100
[ 0.336794] pci 0000:00:1f.2: [8086:2822] type 00 class 0x010400
[ 0.336808] pci 0000:00:1f.2: reg 10: [io 0xf0d0-0xf0d7]
[ 0.336814] pci 0000:00:1f.2: reg 14: [io 0xf0c0-0xf0c3]
[ 0.336821] pci 0000:00:1f.2: reg 18: [io 0xf0b0-0xf0b7]
[ 0.336828] pci 0000:00:1f.2: reg 1c: [io 0xf0a0-0xf0a3]
[ 0.336835] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.336841] pci 0000:00:1f.2: reg 24: [mem 0xf7f3a000-0xf7f3a7ff]
[ 0.336864] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.336877] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[ 0.336890] pci 0000:00:1f.3: reg 10: [mem 0xf7f39000-0xf7f390ff 64bit]
[ 0.336908] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.336959] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.337022] pci 0000:02:00.0: [104c:8240] type 01 class 0x060400
[ 0.337114] pci 0000:02:00.0: supports D1 D2
[ 0.345394] pci 0000:00:1c.1: PCI bridge to [bus 02-03]
[ 0.345398] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.345401] pci 0000:00:1c.1: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.345512] pci 0000:03:02.0: [10b5:3001] type 00 class 0x068000
[ 0.345553] pci 0000:03:02.0: reg 10: [mem 0xf7e01000-0xf7e0107f]
[ 0.345571] pci 0000:03:02.0: reg 14: [io 0xe000-0xe07f]
[ 0.345588] pci 0000:03:02.0: reg 18: [mem 0xf7e00000-0xf7e001ff]
[ 0.345707] pci 0000:03:02.0: PME# supported from D0 D3hot
[ 0.345795] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.345803] pci 0000:02:00.0: bridge window [io 0xe000-0xefff]
[ 0.345808] pci 0000:02:00.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.345878] pci 0000:04:00.0: [1b21:1080] type 01 class 0x060400
[ 0.345975] pci 0000:04:00.0: supports D1 D2
[ 0.345976] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.353388] pci 0000:00:1c.2: PCI bridge to [bus 04-05]
[ 0.353391] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.353394] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.353483] pci 0000:05:00.0: [9710:9865] type 00 class 0x070103
[ 0.353514] pci 0000:05:00.0: reg 10: [io 0xd030-0xd037]
[ 0.353531] pci 0000:05:00.0: reg 14: [io 0xd020-0xd027]
[ 0.353548] pci 0000:05:00.0: reg 18: [mem 0xf7d03000-0xf7d03fff]
[ 0.353581] pci 0000:05:00.0: reg 20: [mem 0xf7d02000-0xf7d02fff]
[ 0.353646] pci 0000:05:00.0: PME# supported from D0 D3cold
[ 0.353679] pci 0000:05:00.2: [9710:9865] type 00 class 0x070103
[ 0.353710] pci 0000:05:00.2: reg 10: [io 0xd010-0xd017]
[ 0.353727] pci 0000:05:00.2: reg 14: [io 0xd000-0xd007]
[ 0.353744] pci 0000:05:00.2: reg 18: [mem 0xf7d01000-0xf7d01fff]
[ 0.353776] pci 0000:05:00.2: reg 20: [mem 0xf7d00000-0xf7d00fff]
[ 0.353840] pci 0000:05:00.2: PME# supported from D0 D3cold
[ 0.353938] pci 0000:04:00.0: PCI bridge to [bus 05-05]
[ 0.353946] pci 0000:04:00.0: bridge window [io 0xd000-0xdfff]
[ 0.353950] pci 0000:04:00.0: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.354069] pci 0000:06:00.0: [14e4:165a] type 00 class 0x020000
[ 0.354133] pci 0000:06:00.0: reg 10: [mem 0xf7c40000-0xf7c4ffff 64bit]
[ 0.354285] pci 0000:06:00.0: reg 30: [mem 0xf7c00000-0xf7c3ffff pref]
[ 0.354412] pci 0000:06:00.0: PME# supported from D3hot D3cold
[ 0.361398] pci 0000:00:1c.4: PCI bridge to [bus 06-06]
[ 0.361403] pci 0000:00:1c.4: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.361421] pci_bus 0000:00: on NUMA node 0
[ 0.361423] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.361529] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.361559] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.361588] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.361617] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[ 0.361735] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.366372] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.366407] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.366439] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.366472] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.366503] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.366534] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.366567] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.366599] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.366642] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.366648] vgaarb: loaded
[ 0.366649] vgaarb: bridge control possible 0000:00:02.0
[ 0.366661] PCI: Using ACPI for IRQ routing
[ 0.367836] PCI: pci_cache_line_size set to 64 bytes
[ 0.367931] Expanded resource reserved due to conflict with Adapter ROM
[ 0.367934] reserve RAM buffer: 0000000000091800 - 000000000009ffff
[ 0.367935] reserve RAM buffer: 00000000d1522000 - 00000000d3ffffff
[ 0.367936] reserve RAM buffer: 00000000d195f000 - 00000000d3ffffff
[ 0.367937] reserve RAM buffer: 00000000d7eea000 - 00000000d7ffffff
[ 0.367938] reserve RAM buffer: 00000000d875f000 - 00000000dbffffff
[ 0.367940] reserve RAM buffer: 00000000d8fae000 - 00000000dbffffff
[ 0.367941] reserve RAM buffer: 00000000da71c000 - 00000000dbffffff
[ 0.367942] reserve RAM buffer: 00000000dbb0c000 - 00000000dbffffff
[ 0.368013] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.368018] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.370031] Switching to clocksource hpet
[ 0.370079] pnp: PnP ACPI init
[ 0.370084] ACPI: bus type pnp registered
[ 0.370287] pnp 00:00: [bus 00-3e]
[ 0.370288] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.370289] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.370290] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.370292] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.370293] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.370294] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.370295] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.370296] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.370297] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.370298] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.370299] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.370300] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.370301] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.370302] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.370303] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.370304] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.370305] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.370306] pnp 00:00: [mem 0xdf200000-0xfeafffff window]
[ 0.370336] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.370349] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.370369] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.370370] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.370377] pnp 00:02: [io 0x0000-0x001f]
[ 0.370378] pnp 00:02: [io 0x0081-0x0091]
[ 0.370379] pnp 00:02: [io 0x0093-0x009f]
[ 0.370379] pnp 00:02: [io 0x00c0-0x00df]
[ 0.370381] pnp 00:02: [dma 4]
[ 0.370391] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.370396] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.370406] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.370454] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.370464] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.370481] pnp 00:05: [io 0x00f0]
[ 0.370487] pnp 00:05: [irq 13]
[ 0.370498] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.370556] pnp 00:06: [io 0x002e-0x002f]
[ 0.370557] pnp 00:06: [io 0x004e-0x004f]
[ 0.370558] pnp 00:06: [io 0x0061]
[ 0.370558] pnp 00:06: [io 0x0063]
[ 0.370559] pnp 00:06: [io 0x0065]
[ 0.370560] pnp 00:06: [io 0x0067]
[ 0.370561] pnp 00:06: [io 0x0070]
[ 0.370563] pnp 00:06: [io 0x0080]
[ 0.370563] pnp 00:06: [io 0x0092]
[ 0.370564] pnp 00:06: [io 0x00b2-0x00b3]
[ 0.370565] pnp 00:06: [io 0x0680-0x069f]
[ 0.370566] pnp 00:06: [io 0xffff]
[ 0.370567] pnp 00:06: [io 0xffff]
[ 0.370568] pnp 00:06: [io 0xffff]
[ 0.370569] pnp 00:06: [io 0x1c00-0x1cfe]
[ 0.370570] pnp 00:06: [io 0x1d00-0x1dfe]
[ 0.370571] pnp 00:06: [io 0x1e00-0x1efe]
[ 0.370572] pnp 00:06: [io 0x1f00-0x1ffe]
[ 0.370573] pnp 00:06: [io 0x1800-0x18fe]
[ 0.370574] pnp 00:06: [io 0x164e-0x164f]
[ 0.370599] system 00:06: [io 0x0680-0x069f] has been reserved
[ 0.370600] system 00:06: [io 0xffff] has been reserved
[ 0.370601] system 00:06: [io 0xffff] has been reserved
[ 0.370602] system 00:06: [io 0xffff] has been reserved
[ 0.370604] system 00:06: [io 0x1c00-0x1cfe] has been reserved
[ 0.370605] system 00:06: [io 0x1d00-0x1dfe] has been reserved
[ 0.370606] system 00:06: [io 0x1e00-0x1efe] has been reserved
[ 0.370607] system 00:06: [io 0x1f00-0x1ffe] has been reserved
[ 0.370609] system 00:06: [io 0x1800-0x18fe] has been reserved
[ 0.370610] system 00:06: [io 0x164e-0x164f] has been reserved
[ 0.370611] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.370616] pnp 00:07: [io 0x0070-0x0077]
[ 0.370619] pnp 00:07: [irq 8]
[ 0.370630] pnp 00:07: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.370646] pnp 00:08: [io 0x1854-0x1857]
[ 0.370668] system 00:08: [io 0x1854-0x1857] has been reserved
[ 0.370670] system 00:08: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.370720] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.370721] pnp 00:09: [io 0x0a00-0x0a0f]
[ 0.370722] pnp 00:09: [io 0x0a40-0x0a3f disabled]
[ 0.370742] system 00:09: [io 0x0a00-0x0a0f] has been reserved
[ 0.370744] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.370757] pnp 00:0a: [io 0x0010-0x001f]
[ 0.370758] pnp 00:0a: [io 0x0022-0x003f]
[ 0.370758] pnp 00:0a: [io 0x0044-0x005f]
[ 0.370759] pnp 00:0a: [io 0x0062-0x0063]
[ 0.370760] pnp 00:0a: [io 0x0065-0x006f]
[ 0.370761] pnp 00:0a: [io 0x0072-0x007f]
[ 0.370762] pnp 00:0a: [io 0x0080]
[ 0.370763] pnp 00:0a: [io 0x0084-0x0086]
[ 0.370764] pnp 00:0a: [io 0x0088]
[ 0.370765] pnp 00:0a: [io 0x008c-0x008e]
[ 0.370766] pnp 00:0a: [io 0x0090-0x009f]
[ 0.370767] pnp 00:0a: [io 0x00a2-0x00bf]
[ 0.370768] pnp 00:0a: [io 0x00e0-0x00ef]
[ 0.370769] pnp 00:0a: [io 0x04d0-0x04d1]
[ 0.370791] system 00:0a: [io 0x04d0-0x04d1] has been reserved
[ 0.370793] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.371334] pnp 00:0b: [io 0x03f8-0x03ff]
[ 0.371338] pnp 00:0b: [irq 4]
[ 0.371339] pnp 00:0b: [dma 0 disabled]
[ 0.371365] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.371668] pnp 00:0c: [mem 0xfed1c000-0xfed1ffff]
[ 0.371670] pnp 00:0c: [mem 0xfed10000-0xfed17fff]
[ 0.371671] pnp 00:0c: [mem 0xfed18000-0xfed18fff]
[ 0.371672] pnp 00:0c: [mem 0xfed19000-0xfed19fff]
[ 0.371673] pnp 00:0c: [mem 0xf8000000-0xfbffffff]
[ 0.371674] pnp 00:0c: [mem 0xfed20000-0xfed3ffff]
[ 0.371675] pnp 00:0c: [mem 0xfed90000-0xfed93fff]
[ 0.371676] pnp 00:0c: [mem 0xfed45000-0xfed8ffff]
[ 0.371677] pnp 00:0c: [mem 0xff000000-0xffffffff]
[ 0.371679] pnp 00:0c: [mem 0xfee00000-0xfeefffff]
[ 0.371680] pnp 00:0c: [mem 0xf7fee000-0xf7feefff]
[ 0.371681] pnp 00:0c: [mem 0xf7fd0000-0xf7fdffff]
[ 0.371715] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.371717] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.371718] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.371719] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.371721] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.371722] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.371723] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.371725] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.371726] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[ 0.371728] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.371729] system 00:0c: [mem 0xf7fee000-0xf7feefff] has been reserved
[ 0.371731] system 00:0c: [mem 0xf7fd0000-0xf7fdffff] has been reserved
[ 0.371732] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.371892] pnp: PnP ACPI: found 13 devices
[ 0.371893] ACPI: ACPI bus type pnp unregistered
[ 0.371894] PnPBIOS: Disabled by ACPI PNP
[ 0.407508] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.407518] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.407521] pci 0000:02:00.0: bridge window [io 0xe000-0xefff]
[ 0.407528] pci 0000:02:00.0: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.407540] pci 0000:00:1c.1: PCI bridge to [bus 02-03]
[ 0.407542] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.407546] pci 0000:00:1c.1: bridge window [mem 0xf7e00000-0xf7efffff]
[ 0.407552] pci 0000:04:00.0: PCI bridge to [bus 05-05]
[ 0.407556] pci 0000:04:00.0: bridge window [io 0xd000-0xdfff]
[ 0.407562] pci 0000:04:00.0: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.407573] pci 0000:00:1c.2: PCI bridge to [bus 04-05]
[ 0.407576] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.407580] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.407586] pci 0000:00:1c.4: PCI bridge to [bus 06-06]
[ 0.407590] pci 0000:00:1c.4: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.407642] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.407643] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.407644] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.407646] pci_bus 0000:00: resource 7 [mem 0x000e4000-0x000e7fff]
[ 0.407647] pci_bus 0000:00: resource 8 [mem 0xdf200000-0xfeafffff]
[ 0.407648] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.407649] pci_bus 0000:02: resource 1 [mem 0xf7e00000-0xf7efffff]
[ 0.407650] pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
[ 0.407651] pci_bus 0000:03: resource 1 [mem 0xf7e00000-0xf7efffff]
[ 0.407652] pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
[ 0.407653] pci_bus 0000:04: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.407654] pci_bus 0000:05: resource 0 [io 0xd000-0xdfff]
[ 0.407655] pci_bus 0000:05: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.407657] pci_bus 0000:06: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.407735] NET: Registered protocol family 2
[ 0.407773] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.407903] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.408002] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.408051] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.408052] TCP: reno registered
[ 0.408054] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.408056] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.408117] NET: Registered protocol family 1
[ 0.408123] pci 0000:00:02.0: Boot video device
[ 0.408327] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.408335] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.446056] PCI: CLS 64 bytes, default 64
[ 0.446078] Unpacking initramfs...
[ 0.607144] Freeing initrd memory: 14272k freed
[ 0.608463] audit: initializing netlink socket (disabled)
[ 0.608473] type=2000 audit(1568144615.496:1): initialized
[ 0.615798] highmem bounce pool size: 64 pages
[ 0.615800] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.615990] VFS: Disk quotas dquot_6.5.2
[ 0.616010] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.616052] msgmni has been set to 1692
[ 0.616154] alg: No test for stdrng (krng)
[ 0.616175] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.616177] io scheduler noop registered
[ 0.616178] io scheduler deadline registered
[ 0.616200] io scheduler cfq registered (default)
[ 0.616382] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.616390] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.616391] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.616539] acpiphp: Slot [1] registered
[ 0.616661] GHES: HEST is not enabled!
[ 0.616667] isapnp: Scanning for PnP cards...
[ 0.970204] isapnp: No Plug & Play device found
[ 0.970228] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.990777] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.011482] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.031655] 0000:00:16.3: ttyS1 at I/O 0xf0e0 (irq = 19) is a 16550A
[ 1.031803] Linux agpgart interface v0.103
[ 1.031896] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.034762] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.034779] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.034838] mousedev: PS/2 mouse device common for all mice
[ 1.034866] rtc_cmos 00:07: RTC can wake from S4
[ 1.034961] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 1.034985] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.035063] TCP: cubic registered
[ 1.035141] NET: Registered protocol family 10
[ 1.035270] Mobile IPv6
[ 1.035272] NET: Registered protocol family 17
[ 1.035274] Registering the dns_resolver key type
[ 1.035301] Using IPI No-Shortcut mode
[ 1.035358] PM: Hibernation image not present or could not be loaded.
[ 1.035364] registered taskstats version 1
[ 1.035893] rtc_cmos 00:07: setting system clock to 2019-09-10 19:43:36 UTC (1568144616)
[ 1.035971] Freeing unused kernel memory: 416k freed
[ 1.036047] Write protecting the kernel text: 3496k
[ 1.036063] Write protecting the kernel read-only data: 984k
[ 1.042126] udevd[73]: starting version 175
[ 1.052683] usbcore: registered new interface driver usbfs
[ 1.052698] usbcore: registered new interface driver hub
[ 1.053160] usbcore: registered new device driver usb
[ 1.053374] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 1.053378] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 1.053402] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 1.053405] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.053417] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.053495] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.053532] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.053534] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.053535] usb usb1: Product: xHCI Host Controller
[ 1.053536] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.053537] usb usb1: SerialNumber: 0000:00:14.0
[ 1.053711] xHCI xhci_add_endpoint called for root hub
[ 1.053712] xHCI xhci_check_bandwidth called for root hub
[ 1.053728] hub 1-0:1.0: USB hub found
[ 1.053743] hub 1-0:1.0: 15 ports detected
[ 1.053858] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.053861] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.053878] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.053880] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.053882] usb usb2: Product: xHCI Host Controller
[ 1.053884] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.053886] usb usb2: SerialNumber: 0000:00:14.0
[ 1.054155] xHCI xhci_add_endpoint called for root hub
[ 1.054157] xHCI xhci_check_bandwidth called for root hub
[ 1.054190] hub 2-0:1.0: USB hub found
[ 1.054201] hub 2-0:1.0: 6 ports detected
[ 1.055581] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.056365] SCSI subsystem initialized
[ 1.057178] libata version 3.00 loaded.
[ 1.057720] tg3.c:v3.123 (March 21, 2012)
[ 1.057962] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x1c
[ 1.061919] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.061924] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.061931] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 1.061953] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.065834] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.065842] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7f3c000
[ 1.065862] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x1c
[ 1.067010] microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x1c
[ 1.068112] microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x1c
[ 1.069225] microcode: CPU4 sig=0x306c3, pf=0x2, revision=0x1c
[ 1.070475] microcode: CPU5 sig=0x306c3, pf=0x2, revision=0x1c
[ 1.071595] microcode: CPU6 sig=0x306c3, pf=0x2, revision=0x1c
[ 1.072707] microcode: CPU7 sig=0x306c3, pf=0x2, revision=0x1c
[ 1.073899] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.077829] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.077880] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.077882] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.077883] usb usb3: Product: EHCI Host Controller
[ 1.077885] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.077886] usb usb3: SerialNumber: 0000:00:1a.0
[ 1.077947] hub 3-0:1.0: USB hub found
[ 1.077950] hub 3-0:1.0: 3 ports detected
[ 1.078013] ahci 0000:00:1f.2: version 3.0
[ 1.078079] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl RAID mode
[ 1.078081] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[ 1.078085] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.079616] tg3 0000:06:00.0: eth0: Tigon3 [partno(BCM95722) rev a200] (PCI Express) MAC address 00:0a:f7:4c:39:48
[ 1.079619] tg3 0000:06:00.0: eth0: attached PHY is 5722/5756 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 1.079620] tg3 0000:06:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.079622] tg3 0000:06:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 1.086069] scsi0 : ahci
[ 1.086152] scsi1 : ahci
[ 1.086188] scsi2 : ahci
[ 1.086223] scsi3 : ahci
[ 1.086261] scsi4 : ahci
[ 1.086299] scsi5 : ahci
[ 1.086697] ata1: SATA max UDMA/133 abar m2048@0xf7f3a000 port 0xf7f3a100 irq 19
[ 1.086698] ata2: DUMMY
[ 1.086700] ata3: SATA max UDMA/133 abar m2048@0xf7f3a000 port 0xf7f3a200 irq 19
[ 1.086701] ata4: DUMMY
[ 1.086702] ata5: DUMMY
[ 1.086703] ata6: DUMMY
[ 1.086737] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.086743] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.086752] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 1.086776] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.090662] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.090673] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7f3b000
[ 1.101788] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.101798] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.101800] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.101801] usb usb4: Product: EHCI Host Controller
[ 1.101802] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.101803] usb usb4: SerialNumber: 0000:00:1d.0
[ 1.101871] hub 4-0:1.0: USB hub found
[ 1.101874] hub 4-0:1.0: 3 ports detected
[ 1.365689] usb 1-3: new low-speed USB device number 2 using xhci_hcd
[ 1.385338] usb 1-3: New USB device found, idVendor=03f0, idProduct=094a
[ 1.385339] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.385341] usb 1-3: Product: HP USB Optical Mouse
[ 1.385342] usb 1-3: Manufacturer: PixArt
[ 1.385383] usb 1-3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.405683] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.405698] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.407075] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.407077] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.407079] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.409035] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.409037] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.409039] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.411565] ata3.00: ATAPI: TSSTcorp DVD-ROM SH-116CB, D200, max UDMA/100
[ 1.415682] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.415684] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.415686] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.417476] ata1.00: ATA-9: INTEL SSDSC2CW480A3, 400i, max UDMA/133
[ 1.417477] ata1.00: 937703088 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.418212] ata3.00: configured for UDMA/100
[ 1.427024] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.427026] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.427027] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.437469] ata1.00: configured for UDMA/133
[ 1.437540] scsi 0:0:0:0: Direct-Access ATA INTEL SSDSC2CW48 400i PQ: 0 ANSI: 5
[ 1.443172] scsi 2:0:0:0: CD-ROM TSSTcorp DVD-ROM SH-116CB D200 PQ: 0 ANSI: 5
[ 1.444778] input: PixArt HP USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input0
[ 1.444838] generic-usb 0003:03F0:094A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt HP USB Optical Mouse] on usb-0000:00:14.0-3/input0
[ 1.444849] usbcore: registered new interface driver usbhid
[ 1.444851] usbhid: USB HID core driver
[ 1.445332] sd 0:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[ 1.445359] sd 0:0:0:0: [sda] Write Protect is off
[ 1.445360] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.445368] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.445709] sda: sda1 sda2 < sda5 >
[ 1.445876] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.446622] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.446650] sr 2:0:0:0: Attached scsi generic sg1 type 5
[ 1.453608] sr0: scsi3-mmc drive: 1x/48x cd/rw xa/form2 cdda tray
[ 1.453610] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.453703] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 1.497654] usb 1-4: new low-speed USB device number 3 using xhci_hcd
[ 1.519067] usb 1-4: New USB device found, idVendor=413c, idProduct=2107
[ 1.519068] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.519070] usb 1-4: Product: Dell USB Entry Keyboard
[ 1.519071] usb 1-4: Manufacturer: DELL
[ 1.519120] usb 1-4: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.521926] input: DELL Dell USB Entry Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/input/input1
[ 1.521959] generic-usb 0003:413C:2107.0002: input,hidraw1: USB HID v1.10 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:00:14.0-4/input0
[ 1.605602] Refined TSC clocksource calibration: 3591.682 MHz.
[ 1.605604] Switching to clocksource tsc
[ 1.633588] usb 3-1: new high-speed USB device number 2 using ehci_hcd
[ 1.765880] usb 3-1: New USB device found, idVendor=8087, idProduct=8008
[ 1.765881] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.766026] hub 3-1:1.0: USB hub found
[ 1.766129] hub 3-1:1.0: 6 ports detected
[ 1.877506] usb 4-1: new high-speed USB device number 2 using ehci_hcd
[ 2.009790] usb 4-1: New USB device found, idVendor=8087, idProduct=8000
[ 2.009792] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.009934] hub 4-1:1.0: USB hub found
[ 2.010040] hub 4-1:1.0: 8 ports detected
[ 6.499678] PM: Starting manual resume from disk
[ 6.499680] PM: Hibernation image partition 8:5 present
[ 6.499681] PM: Looking for hibernation image.
[ 6.499818] PM: Image not found (code -22)
[ 6.499820] PM: Hibernation image not present or could not be loaded.
[ 6.519129] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.635420] udevd[432]: starting version 175
[ 6.665025] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 6.665031] ACPI: Power Button [PWRB]
[ 6.665073] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 6.665077] ACPI: Power Button [PWRF]
[ 6.668957] wmi: Mapper loaded
[ 6.677625] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 6.677998] iTCO_vendor_support: vendor-support=0
[ 6.678667] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 6.678714] iTCO_wdt: Found a Lynx Point TCO device (Version=2, TCOBASE=0x1860)
[ 6.678760] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 6.690557] PCI parallel port detected: 14f2:0121, I/O at 0xd030(0x0), IRQ 18
[ 6.690591] parport0: PC-style at 0xd030, irq 18 [PCSPP,TRISTATE,EPP]
[ 6.690649] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 6.695845] udevd[482]: renamed network interface eth0 to eth1
[ 6.698799] input: Dell WMI hotkeys as /devices/virtual/input/input4
[ 6.787755] PCI parallel port detected: 14f2:0121, I/O at 0xd010(0x0), IRQ 16
[ 6.787795] parport1: PC-style at 0xd010, irq 16 [PCSPP,TRISTATE,EPP]
[ 9.706661] hda-intel: azx_get_response timeout, switching to polling mode: last cmd=0x000f0000
[ 10.710304] hda-intel: Codec #0 probe error; disabling it...
[ 11.729930] hda_intel: azx_get_response timeout, switching to single_cmd mode: last cmd=0x000f0001
[ 11.774778] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input5
[ 11.774815] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input6
[ 11.774845] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input7
[ 11.774875] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card1/input8
[ 11.774996] ACPI Warning: 0x0000f040-0x0000f05f SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120320/utaddress-251)
[ 11.775005] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 11.899653] Adding 18997244k swap on /dev/sda5. Priority:-1 extents:1 across:18997244k SS
[ 11.906293] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 11.923543] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 11.931961] loop: module loaded
[ 12.069583] [Hardware Error]: Machine check events logged
[ 12.196575] RPC: Registered named UNIX socket transport module.
[ 12.196577] RPC: Registered udp transport module.
[ 12.196578] RPC: Registered tcp transport module.
[ 12.196579] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 12.198885] FS-Cache: Loaded
[ 12.201658] NFS: Registering the id_resolver key type
[ 12.201666] FS-Cache: Netfs 'nfs' registered for caching
[ 12.203640] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 12.444083] Bluetooth: Core ver 2.16
[ 12.444093] NET: Registered protocol family 31
[ 12.444095] Bluetooth: HCI device and connection manager initialized
[ 12.444097] Bluetooth: HCI socket layer initialized
[ 12.444098] Bluetooth: L2CAP socket layer initialized
[ 12.444102] Bluetooth: SCO socket layer initialized
[ 12.445939] Bluetooth: RFCOMM TTY layer initialized
[ 12.445942] Bluetooth: RFCOMM socket layer initialized
[ 12.445943] Bluetooth: RFCOMM ver 1.11
[ 12.448760] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.448763] Bluetooth: BNEP filters: protocol multicast
[ 12.460426] lp0: using parport0 (interrupt-driven).
[ 12.460494] lp1: using parport1 (interrupt-driven).
[ 12.462293] ppdev: user-space parallel port driver
[ 12.522588] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 13.377553] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input9
[ 16.057636] tg3 0000:06:00.0: eth1: Link is up at 1000 Mbps, full duplex
[ 16.057638] tg3 0000:06:00.0: eth1: Flow control is on for TX and on for RX
[ 16.057697] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 1294.685952] I-pipe: head domain RTAI registered.
[ 1294.685956] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1294.686034] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1294.686036] SYSINFO: CPUs 8, LINUX APIC IRQ 2312, TIM_FREQ 6235080, CLK_FREQ 3591929000, CPU_FREQ 3591929000
[ 1294.686037] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1294.686039] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235080, 6235080, 5980500
[ 1294.692942] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1294.692962] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1294.692964] RTAI[sched]: hard timer type/freq = APIC/6235080(Hz); default timing: oneshot; linear timed lists.
[ 1294.692966] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591929000 hz.
[ 1294.692967] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1294.696435] RTAI[math]: loaded.
[ 1294.743862] MOTENC: ERROR, unknown card detected
[ 1296.899812] RTAI[math]: unloaded.
[ 1296.900604] SCHED releases registered named ALIEN PEDV$D
[ 1296.901851] RTAI[malloc]: unloaded.
[ 1297.000476] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1297.001292] I-pipe: head domain RTAI unregistered.
[ 1297.001376] RTAI[hal]: unmounted.thanks
Sam
Last edit: 10 Sep 2019 20:14 by smorin.
Time to create page: 0.153 seconds
