Upgrading from Axis 2.3.1
20 Sep 2019 19:42 #145706 by smorin
Replied by smorin on topic Upgrading from Axis 2.3.1
yes, that's what it says
cnc@cnc:~$ dmesg
[12133.814670] I-pipe: head domain RTAI registered.
[12133.814673] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[12133.814749] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[12133.814751] SYSINFO: CPUs 8, LINUX APIC IRQ 2312, TIM_FREQ 6235080, CLK_FREQ 3592032000, CPU_FREQ 3592032000
[12133.814752] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[12133.814754] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235080, 6235080, 6132750
[12133.817628] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[12133.817649] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[12133.817652] RTAI[sched]: hard timer type/freq = APIC/6235080(Hz); default timing: oneshot; linear timed lists.
[12133.817653] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3592032000 hz.
[12133.817654] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[12133.821057] RTAI[math]: loaded.
[12149.653088] MOTENC: ERROR, unknown card detected
[12154.518172] RTAI[math]: unloaded.
[12154.518987] SCHED releases registered named ALIEN PEDV$D
[12154.520330] RTAI[malloc]: unloaded.
[12154.617575] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[12154.618407] I-pipe: head domain RTAI unregistered.
[12154.618491] RTAI[hal]: unmounted.
cnc@cnc:~$
20 Sep 2019 21:43 #145714 by andypugh
Replied by andypugh on topic Upgrading from Axis 2.3.1
buildbot.linuxcnc.org/buildbot/waterfall
It looks like the version with my changes has finished compiling, if you update now you should get a bit more info about what is going on (and the driver might even work)
20 Sep 2019 22:27 #145717 by smorin
I've left the office for the weekend, will try this on monday morning
cheers
20 Sep 2019 22:50 #145718 by andypugh
Sorry I was too slow :-)
To explain what I have done, I have made it so that when it finds an unknown card type it tells us what it found, and (at the moment) it assumes a Motenc-lite and carries on regardless....
The following user(s) said Thank You: smorin
20 Sep 2019 23:16 #145721 by dgarrett
Replied by dgarrett on topic Upgrading from Axis 2.3.1
finished compiling, if you update now ...
But note the buildbot had a problem (purple color):
retry
compile
exception
slave
lost
And no debs (including your commit 0044b8caf) will be made
until the buildbot offline slave is revived
Ref: buildbot.linuxcnc.org/buildbot/grid
Ref: current wheezy debs for rtai,i386:
buildbot.linuxcnc.org/dists/wheezy/master-rt/binary-i386/
21 Sep 2019 00:17 #145726 by andypugh
I hadn't realised that the failure in a different OS / Realtime would prevent debs being made.
And as far as I can see this is nothing to do with my changes?
Hopefully things will be back in order by monday.
21 Sep 2019 00:27 - 21 Sep 2019 00:37 #145727 by dgarrett
i think the reasoning is we expect any commit to 1) successfully
build a deb on all supported platforms and 2) pass runtests on all supported platforms before making the commit changes available
as a deb to any supported platform.
The criteria apply to both normal and 'scratch' debs. 'Scratch' debs disappear
after some time or space limitation occurs.
correct (slave lost seems to happen now and then -- no idea why)
Last edit: 21 Sep 2019 00:37 by dgarrett.
25 Sep 2019 22:34 #146198 by andypugh
smorin: Anything to report?
03 Oct 2019 15:40 #146987 by smorin
Andy-
I have taken a job at another company so I no longer have access to that set of hardware. thanks for your help, though-
04 Oct 2019 01:50 #147068 by andypugh
Andy-
I hope that isn't because you were fired for taking too long to get the Motenc working?
Time to create page: 0.114 seconds
