Trying to get Debian Squeeze to run my router
- aaron
11 May 2019 20:42 #133481
by aaron
Trying to get Debian Squeeze to run my router was created by aaron
Hello
I suspect I have broken my Debian Wheezy Configuration so Am trying to get Squeeze on a usb stick to run my router. The router has two steppers running the X axis. I am faced with the error message below which I can't make head or tail of.
Can someone help please.
Thank you
Aaron
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/user/linuxcnc/configs/foam_xxyz'
Machine configuration file is 'foam_xxyz.ini'
INIFILE=/home/user/linuxcnc/configs/foam_xxyz/foam_xxyz.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./foam_xxyz.hal
Killing task linuxcncsvr, PID=2272
Debug file information:
Note: Using POSIX realtime
Unknown parameter `coordinates=XYZX'
./foam_xxyz.hal:4: waitpid failed /usr/bin/rtapi_app trivkins
./foam_xxyz.hal:4: /usr/bin/rtapi_app exited without becoming ready
./foam_xxyz.hal:4: insmod for trivkins failed, returned -1
2272
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Linux version 4.9.0-8-rt-686-pae (This email address is being protected from spambots. You need JavaScript enabled to view it.) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u5 (2018-09-30)
[ 0.000000] x86/fpu: Legacy x87 FPU detected.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007d4ff7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007d4ff800-0x000000007d553bff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007d553c00-0x000000007d555bff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000007d555c00-0x000000007dffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fed003ff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed9ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 755 /0DR845, BIOS A10 04/30/2008
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x7d4ff max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask 000000000 write-back
[ 0.000000] 1 base 07D700000 mask FFFF00000 uncachable
[ 0.000000] 2 base 07D800000 mask FFF800000 uncachable
[ 0.000000] 3 base 07E000000 mask FFE000000 uncachable
[ 0.000000] 4 base 07D600000 mask FFFF00000 uncachable
[ 0.000000] 5 base 080000000 mask F80000000 uncachable
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] e820: update [mem 0x7d600000-0xffffffff] usable ==> reserved
[ 0.000000] found SMP MP-table at [mem 0x000fe710-0x000fe71f] mapped at [c00fe710]
[ 0.000000] initial memory mapped: [mem 0x00000000-0x08ffffff]
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] BRK [0x08a29000, 0x08a29fff] PGTABLE
[ 0.000000] BRK [0x08a2a000, 0x08a2bfff] PGTABLE
[ 0.000000] BRK [0x08a2c000, 0x08a2cfff] PGTABLE
[ 0.000000] BRK [0x08a2d000, 0x08a2dfff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x7b75f000-0x7d4fefff]
[ 0.000000] Allocated new RAMDISK: [mem 0x35c5e000-0x379fd43c]
[ 0.000000] Move RAMDISK from [mem 0x7b75f000-0x7d4fe43c] to [mem 0x35c5e000-0x379fd43c]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FEC00 000024 (v02 DELL )
[ 0.000000] ACPI: XSDT 0x00000000000FC5B3 00008C (v01 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI: FACP 0x00000000000FC6E3 0000F4 (v03 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 128/64 (20160831/tbfadt-603)
[ 0.000000] ACPI: DSDT 0x00000000FFF76B39 004596 (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS 0x000000007D4FF800 000040
[ 0.000000] ACPI: SSDT 0x00000000FFF7B1EE 0000AA (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 0x00000000000FC7D7 000092 (v01 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI: BOOT 0x00000000000FC869 000028 (v01 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI: ASF! 0x00000000000FC891 000096 (v32 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI: MCFG 0x00000000000FC927 00003E (v01 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI: HPET 0x00000000000FC965 000038 (v01 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI: TCPA 0x00000000000FCBC1 000032 (v01 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI: ____ 0x00000000000FCBF3 000030 (v01 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI: SLIC 0x00000000000FC99D 000176 (v01 DELL B9K 00000015 ASL 00000061)
[ 0.000000] ACPI: SSDT 0x000000007D4FF840 0001B7 (v01 DpgPmm Cpu0Ist 00000011 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x000000007D4FFC49 0001B7 (v01 DpgPmm Cpu1Ist 00000011 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x000000007D500052 000140 (v01 DpgPmm CpuPm 00000010 INTL 20050624)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1115MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] Normal [mem 0x0000000001000000-0x00000000379fdfff]
[ 0.000000] HighMem [mem 0x00000000379fe000-0x000000007d4fefff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x000000007d4fefff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000007d4fefff]
[ 0.000000] On node 0 totalpages: 513181
[ 0.000000] free_area_init_node: node 0, pgdat c8829780, node_mem_map f48c2028
[ 0.000000] DMA zone: 40 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] Normal zone: 2185 pages used for memmap
[ 0.000000] Normal zone: 223742 pages, LIFO batch:31
[ 0.000000] HighMem zone: 285441 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] Reserving Intel graphics memory at 0x000000007d800000-0x000000007dffffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[ 0.000000] smpboot: Allowing 8 CPUs, 6 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x000effff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
[ 0.000000] e820: [mem 0x7e000000-0xdfffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] percpu: Embedded 101 pages/cpu @f4597000 s381472 r0 d32224 u413696
[ 0.000000] pcpu-alloc: s381472 r0 d32224 u413696 alloc=101*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 510956
[ 0.000000] Kernel command line: BOOT_IMAGE=/live/vmlinuz-4.9.0-8-rt-686-pae initrd=/live/initrd.img-4.9.0-8-rt-686-pae boot=live components persistence
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:0007d4ff)
[ 0.000000] Initializing Movable for node 0 (00000000:00000000)
[ 0.000000] Memory: 1987268K/2052724K available (6035K kernel code, 628K rwdata, 1756K rodata, 1060K init, 592K bss, 65456K reserved, 0K cma-reserved, 1141764K highmem)
[ 0.000000] virtual kernel memory layout:
fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
.init : 0xc883d000 - 0xc8946000 (1060 kB)
.data : 0xc85e51f4 - 0xc883b280 (2392 kB)
.text : 0xc8000000 - 0xc85e51f4 (6036 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=8.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS:2304 nr_irqs:488 16
[ 0.000000] CPU 0 irqstacks, hard=f4082000 soft=f4084000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 1994.859 MHz processor
[ 0.004005] Calibrating delay loop (skipped), value calculated using timer frequency.. 3989.71 BogoMIPS (lpj=7979436)
[ 0.004007] pid_max: default: 32768 minimum: 301
[ 0.004027] ACPI: Core revision 20160831
[ 0.074489] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.074528] Security Framework initialized
[ 0.074529] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.074537] AppArmor: AppArmor disabled by boot time parameter
[ 0.074554] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.074556] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.074958] mce: CPU supports 6 MCE banks
[ 0.074967] CPU0: Thermal monitoring enabled (TM2)
[ 0.074972] process: using mwait in idle threads
[ 0.074979] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[ 0.074980] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[ 0.074982] Spectre V2 : Mitigation: Full generic retpoline
[ 0.074983] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.074984] Speculative Store Bypass: Vulnerable
[ 0.075274] Freeing SMP alternatives memory: 24K
[ 0.076514] ftrace: allocating 24078 entries in 48 pages
[ 0.096150] smpboot: Max logical packages: 4
[ 0.101038] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.101503] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.144000] smpboot: CPU0: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz (family: 0x6, model: 0xf, stepping: 0xd)
[ 0.144000] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[ 0.144000] core: PEBS disabled due to CPU errata
[ 0.144000] ... version: 2
[ 0.144000] ... bit width: 40
[ 0.144000] ... generic registers: 2
[ 0.144000] ... value mask: 000000ffffffffff
[ 0.144000] ... max period: 000000007fffffff
[ 0.144000] ... fixed-purpose events: 3
[ 0.144000] ... event mask: 0000000700000003
[ 0.196361] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.248047] CPU 1 irqstacks, hard=f4216000 soft=f4218000
[ 0.248050] x86: Booting SMP configuration:
[ 0.248131] .... node #0, CPUs: #1
[ 0.008000] Initializing CPU#1
[ 0.250505] x86: Booted up 1 node, 2 CPUs
[ 0.250505] smpboot: Total of 2 processors activated (7979.43 BogoMIPS)
[ 0.252154] devtmpfs: initialized
[ 0.252440] PM: Registering ACPI NVS region [mem 0x7d4ff800-0x7d553bff] (345088 bytes)
[ 0.252440] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.252440] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.252583] pinctrl core: initialized pinctrl subsystem
[ 0.252880] NET: Registered protocol family 16
[ 0.256039] cpuidle: using governor ladder
[ 0.260028] cpuidle: using governor menu
[ 0.260169] Simple Boot Flag at 0x7a set to 0x1
[ 0.260253] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.260354] ACPI: bus type PCI registered
[ 0.260425] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.260602] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.260710] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.260787] PCI: Using MMCONFIG for extended config space
[ 0.260859] PCI: Using configuration type 1 for base access
[ 0.264980] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.264980] ACPI: Added _OSI(Module Device)
[ 0.264980] ACPI: Added _OSI(Processor Device)
[ 0.264980] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.264980] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.320827] ACPI: Interpreter enabled
[ 0.320928] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.320992] ACPI: Using IOAPIC for interrupt routing
[ 0.321190] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.331934] acpi LNXIOBAY:00: ACPI dock station (docks/bays count: 1)
[ 0.462541] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.462619] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.462715] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.471764] PCI host bridge to bus 0000:00
[ 0.471831] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.471902] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.471972] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.472075] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff window]
[ 0.472164] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[ 0.472254] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfec00000 window]
[ 0.472343] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.472431] pci_bus 0000:00: root bus resource [mem 0xff980800-0xff980bff window]
[ 0.472521] pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff window]
[ 0.472610] pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff window]
[ 0.472699] pci_bus 0000:00: root bus resource [mem 0xfedad800-0xfedadfff window]
[ 0.472788] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.472867] pci 0000:00:00.0: [8086:29b0] type 00 class 0x060000
[ 0.473344] pci 0000:00:01.0: [8086:29b1] type 01 class 0x060400
[ 0.473405] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.473781] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.473922] pci 0000:00:02.0: [8086:29b2] type 00 class 0x030000
[ 0.473935] pci 0000:00:02.0: reg 0x10: [mem 0xfea00000-0xfea7ffff]
[ 0.473943] pci 0000:00:02.0: reg 0x14: [io 0xec90-0xec97]
[ 0.473950] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff pref]
[ 0.473957] pci 0000:00:02.0: reg 0x1c: [mem 0xfeb00000-0xfebfffff]
[ 0.474427] pci 0000:00:02.1: [8086:29b3] type 00 class 0x038000
[ 0.474438] pci 0000:00:02.1: reg 0x10: [mem 0xfea80000-0xfeafffff]
[ 0.474911] pci 0000:00:03.0: [8086:29b4] type 00 class 0x078000
[ 0.474928] pci 0000:00:03.0: reg 0x10: [mem 0xfedad000-0xfedad00f 64bit]
[ 0.474982] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.475412] pci 0000:00:03.2: [8086:29b6] type 00 class 0x010185
[ 0.475425] pci 0000:00:03.2: reg 0x10: [io 0xfe80-0xfe87]
[ 0.475433] pci 0000:00:03.2: reg 0x14: [io 0xfe90-0xfe93]
[ 0.475440] pci 0000:00:03.2: reg 0x18: [io 0xfea0-0xfea7]
[ 0.475447] pci 0000:00:03.2: reg 0x1c: [io 0xfeb0-0xfeb3]
[ 0.475455] pci 0000:00:03.2: reg 0x20: [io 0xfef0-0xfeff]
[ 0.475908] pci 0000:00:03.3: [8086:29b7] type 00 class 0x070002
[ 0.475921] pci 0000:00:03.3: reg 0x10: [io 0xec98-0xec9f]
[ 0.475929] pci 0000:00:03.3: reg 0x14: [mem 0xfe9da000-0xfe9dafff]
[ 0.476438] pci 0000:00:19.0: [8086:10bd] type 00 class 0x020000
[ 0.476457] pci 0000:00:19.0: reg 0x10: [mem 0xfe9e0000-0xfe9fffff]
[ 0.476466] pci 0000:00:19.0: reg 0x14: [mem 0xfe9db000-0xfe9dbfff]
[ 0.476476] pci 0000:00:19.0: reg 0x18: [io 0xecc0-0xecdf]
[ 0.476547] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.476978] pci 0000:00:1a.0: [8086:2937] type 00 class 0x0c0300
[ 0.477027] pci 0000:00:1a.0: reg 0x20: [io 0xff20-0xff3f]
[ 0.477439] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.477585] pci 0000:00:1a.1: [8086:2938] type 00 class 0x0c0300
[ 0.477633] pci 0000:00:1a.1: reg 0x20: [io 0xff00-0xff1f]
[ 0.478045] pci 0000:00:1a.1: System wakeup disabled by ACPI
[ 0.478196] pci 0000:00:1a.7: [8086:293c] type 00 class 0x0c0320
[ 0.478217] pci 0000:00:1a.7: reg 0x10: [mem 0xfe9d9c00-0xfe9d9fff]
[ 0.478313] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.478753] pci 0000:00:1b.0: [8086:293e] type 00 class 0x040300
[ 0.478774] pci 0000:00:1b.0: reg 0x10: [mem 0xfe9dc000-0xfe9dffff 64bit]
[ 0.478858] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.479298] pci 0000:00:1c.0: [8086:2940] type 01 class 0x060400
[ 0.479381] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.479761] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.479912] pci 0000:00:1d.0: [8086:2934] type 00 class 0x0c0300
[ 0.479960] pci 0000:00:1d.0: reg 0x20: [io 0xff80-0xff9f]
[ 0.480393] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.480537] pci 0000:00:1d.1: [8086:2935] type 00 class 0x0c0300
[ 0.480585] pci 0000:00:1d.1: reg 0x20: [io 0xff60-0xff7f]
[ 0.480998] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.481141] pci 0000:00:1d.2: [8086:2936] type 00 class 0x0c0300
[ 0.481188] pci 0000:00:1d.2: reg 0x20: [io 0xff40-0xff5f]
[ 0.481599] pci 0000:00:1d.2: System wakeup disabled by ACPI
[ 0.481750] pci 0000:00:1d.7: [8086:293a] type 00 class 0x0c0320
[ 0.481771] pci 0000:00:1d.7: reg 0x10: [mem 0xff980800-0xff980bff]
[ 0.481867] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.482300] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.482723] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.482868] pci 0000:00:1f.0: [8086:2914] type 00 class 0x060100
[ 0.482957] pci 0000:00:1f.0: quirk: [io 0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.483052] pci 0000:00:1f.0: quirk: [io 0x0880-0x08bf] claimed by ICH6 GPIO
[ 0.483125] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0c00 (mask 007f)
[ 0.483216] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 00e0 (mask 0007)
[ 0.483769] pci 0000:00:1f.2: [8086:2920] type 00 class 0x01018f
[ 0.483786] pci 0000:00:1f.2: reg 0x10: [io 0xfe00-0xfe07]
[ 0.483795] pci 0000:00:1f.2: reg 0x14: [io 0xfe10-0xfe13]
[ 0.483805] pci 0000:00:1f.2: reg 0x18: [io 0xfe20-0xfe27]
[ 0.483814] pci 0000:00:1f.2: reg 0x1c: [io 0xfe30-0xfe33]
[ 0.483823] pci 0000:00:1f.2: reg 0x20: [io 0xfec0-0xfecf]
[ 0.483832] pci 0000:00:1f.2: reg 0x24: [io 0xeca0-0xecaf]
[ 0.484312] pci 0000:00:1f.3: [8086:2930] type 00 class 0x0c0500
[ 0.484330] pci 0000:00:1f.3: reg 0x10: [mem 0xfe9d9b00-0xfe9d9bff 64bit]
[ 0.484354] pci 0000:00:1f.3: reg 0x20: [io 0xece0-0xecff]
[ 0.484801] pci 0000:00:1f.5: [8086:2926] type 00 class 0x010185
[ 0.484817] pci 0000:00:1f.5: reg 0x10: [io 0xfe40-0xfe47]
[ 0.484827] pci 0000:00:1f.5: reg 0x14: [io 0xfe50-0xfe53]
[ 0.484836] pci 0000:00:1f.5: reg 0x18: [io 0xfe60-0xfe67]
[ 0.484845] pci 0000:00:1f.5: reg 0x1c: [io 0xfe70-0xfe73]
[ 0.484854] pci 0000:00:1f.5: reg 0x20: [io 0xfed0-0xfedf]
[ 0.484863] pci 0000:00:1f.5: reg 0x24: [io 0xecb0-0xecbf]
[ 0.485370] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.485442] pci 0000:00:01.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.485511] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.485581] pci 0000:00:1c.0: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.485684] pci 0000:00:1e.0: PCI bridge to [bus 03] (subtractive decode)
[ 0.485763] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.485766] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.485768] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.485770] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000effff window] (subtractive decode)
[ 0.485773] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff window] (subtractive decode)
[ 0.485775] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfec00000 window] (subtractive decode)
[ 0.485777] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xdfffffff window] (subtractive decode)
[ 0.485780] pci 0000:00:1e.0: bridge window [mem 0xff980800-0xff980bff window] (subtractive decode)
[ 0.485782] pci 0000:00:1e.0: bridge window [mem 0xff97c000-0xff97ffff window] (subtractive decode)
[ 0.485785] pci 0000:00:1e.0: bridge window [mem 0xfed20000-0xfed9ffff window] (subtractive decode)
[ 0.485787] pci 0000:00:1e.0: bridge window [mem 0xfedad800-0xfedadfff window] (subtractive decode)
[ 0.485805] pci_bus 0000:00: on NUMA node 0
[ 0.515046] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 0.516451] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.517848] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.519252] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.520678] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.522161] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 0.523561] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.524965] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.526177] ACPI: Enabled 3 GPEs in block 00 to 3F
[ 0.526479] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.526479] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.526479] vgaarb: loaded
[ 0.526479] vgaarb: bridge control possible 0000:00:02.0
[ 0.526479] PCI: Using ACPI for IRQ routing
[ 0.533649] PCI: pci_cache_line_size set to 64 bytes
[ 0.533664] pci 0000:00:03.0: can't claim BAR 0 [mem 0xfedad000-0xfedad00f 64bit]: no compatible bridge window
[ 0.533817] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 0.533888] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 0.533891] e820: reserve RAM buffer [mem 0x7d4ff800-0x7fffffff]
[ 0.534107] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
[ 0.534107] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.534107] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.536041] clocksource: Switched to clocksource hpet
[ 0.554887] VFS: Disk quotas dquot_6.6.0
[ 0.554992] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.555219] pnp: PnP ACPI init
[ 0.560761] pnp 00:00: disabling [io 0x0800-0x085f] because it overlaps 0000:00:1f.0 BAR 13 [io 0x0800-0x087f]
[ 0.560861] pnp 00:00: disabling [io 0x0860-0x08ff] because it overlaps 0000:00:1f.0 BAR 13 [io 0x0800-0x087f]
[ 0.561023] system 00:00: [io 0x0c00-0x0c7f] has been reserved
[ 0.561097] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.561368] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.579426] pnp 00:02: [dma 0 disabled]
[ 0.580702] pnp 00:02: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.586943] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.607539] pnp: PnP ACPI: found 4 devices
[ 0.607606] PnPBIOS: Disabled by ACPI PNP
[ 0.645952] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.646074] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.646078] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.646095] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.646098] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.646101] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.646104] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.646121] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf0000000-0xf01fffff 64bit pref]
[ 0.646214] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.646291] pci 0000:00:03.0: BAR 0: assigned [mem 0xf0200000-0xf020000f 64bit]
[ 0.646386] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.646455] pci 0000:00:01.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.646530] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.646597] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.646668] pci 0000:00:1c.0: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.646740] pci 0000:00:1c.0: bridge window [mem 0xf0000000-0xf01fffff 64bit pref]
[ 0.646834] pci 0000:00:1e.0: PCI bridge to [bus 03]
[ 0.646910] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.646913] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.646915] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.646917] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff window]
[ 0.646920] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff window]
[ 0.646922] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfec00000 window]
[ 0.646925] pci_bus 0000:00: resource 10 [mem 0x80000000-0xdfffffff window]
[ 0.646927] pci_bus 0000:00: resource 11 [mem 0xff980800-0xff980bff window]
[ 0.646929] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff window]
[ 0.646932] pci_bus 0000:00: resource 13 [mem 0xfed20000-0xfed9ffff window]
[ 0.646934] pci_bus 0000:00: resource 14 [mem 0xfedad800-0xfedadfff window]
[ 0.646937] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe8fffff]
[ 0.646940] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 0.646942] pci_bus 0000:02: resource 1 [mem 0xfe700000-0xfe7fffff]
[ 0.646944] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf01fffff 64bit pref]
[ 0.646947] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7 window]
[ 0.646949] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff window]
[ 0.646952] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.646954] pci_bus 0000:03: resource 7 [mem 0x000c0000-0x000effff window]
[ 0.646957] pci_bus 0000:03: resource 8 [mem 0x000f0000-0x000fffff window]
[ 0.646959] pci_bus 0000:03: resource 9 [mem 0xf0000000-0xfec00000 window]
[ 0.646961] pci_bus 0000:03: resource 10 [mem 0x80000000-0xdfffffff window]
[ 0.646964] pci_bus 0000:03: resource 11 [mem 0xff980800-0xff980bff window]
[ 0.646966] pci_bus 0000:03: resource 12 [mem 0xff97c000-0xff97ffff window]
[ 0.646969] pci_bus 0000:03: resource 13 [mem 0xfed20000-0xfed9ffff window]
[ 0.646971] pci_bus 0000:03: resource 14 [mem 0xfedad800-0xfedadfff window]
[ 0.647065] NET: Registered protocol family 2
[ 0.647399] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.647489] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[ 0.647660] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.647765] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.647850] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.648050] NET: Registered protocol family 1
[ 0.648141] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.655525] PCI: CLS 64 bytes, default 64
[ 0.655614] Unpacking initramfs...
[ 1.399318] Freeing initrd memory: 30336K
[ 1.400332] audit: initializing netlink subsys (disabled)
[ 1.400425] audit: type=2000 audit(1557604508.400:1): initialized
[ 1.401251] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 1.404832] zbud: loaded
[ 1.405970] bounce: pool size: 64 pages
[ 1.406105] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 1.406246] io scheduler noop registered
[ 1.406309] io scheduler deadline registered
[ 1.406431] io scheduler cfq registered (default)
[ 1.408060] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.408140] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.408238] intel_idle: does not run on family 6 model 15
[ 1.408405] GHES: HEST is not enabled!
[ 1.408491] isapnp: Scanning for PnP cards...
[ 1.761577] isapnp: No Plug & Play device found
[ 1.761772] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.782322] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.803604] 0000:00:03.3: ttyS1 at I/O 0xec98 (irq = 17, base_baud = 115200) is a 16550A
[ 1.804229] Linux agpgart interface v0.103
[ 1.804994] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.807873] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.808012] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.808308] mousedev: PS/2 mouse device common for all mice
[ 1.808450] rtc_cmos 00:01: RTC can wake from S4
[ 1.808669] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.808799] rtc_cmos 00:01: alarms up to one day, 242 bytes nvram, hpet irqs
[ 1.810104] NET: Registered protocol family 10
[ 1.810588] mip6: Mobile IPv6
[ 1.810652] NET: Registered protocol family 17
[ 1.810718] mpls_gso: MPLS GSO support
[ 1.811104] microcode: sig=0x6fd, pf=0x1, revision=0xa3
[ 1.811173] microcode: Microcode Update Driver: v2.01 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.811335] Using IPI No-Shortcut mode
[ 1.811627] registered taskstats version 1
[ 1.811723] zswap: loaded using pool lzo/zbud
[ 1.811845] ima: No TPM chip found, activating TPM-bypass!
[ 1.811913] ima: Allocated hash algorithm: sha256
[ 1.812428] rtc_cmos 00:01: setting system clock to 2019-05-11 19:55:09 UTC (1557604509)
[ 1.812589] PM: Hibernation image not present or could not be loaded.
[ 1.813154] Freeing unused kernel memory: 1060K
[ 1.813373] Write protecting the kernel text: 6040k
[ 1.813552] Write protecting the kernel read-only data: 1760k
[ 1.813619] NX-protecting the kernel data: 4200k
[ 1.813982] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.838830] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.839064] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.839159] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.907729] [drm] Initialized
[ 1.909686] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 1.909799] ACPI: Power Button [VBTN]
[ 1.910010] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 1.910110] ACPI: Power Button [PWRF]
[ 1.910508] SCSI subsystem initialized
[ 1.914287] pps_core: LinuxPPS API ver. 1 registered
[ 1.914372] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 1.924097] PTP clock support registered
[ 1.924547] libata version 3.00 loaded.
[ 1.925279] ACPI: bus type USB registered
[ 1.925412] usbcore: registered new interface driver usbfs
[ 1.925515] usbcore: registered new interface driver hub
[ 1.925857] usbcore: registered new device driver usb
[ 1.941374] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.944122] scsi host0: ata_generic
[ 1.944318] ehci-pci: EHCI PCI platform driver
[ 1.946249] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.946323] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.947317] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.958244] scsi host1: ata_generic
[ 1.958433] ata1: PATA max UDMA/100 cmd 0xfe80 ctl 0xfe90 bmdma 0xfef0 irq 18
[ 1.959595] ata2: PATA max UDMA/100 cmd 0xfea0 ctl 0xfeb0 bmdma 0xfef8 irq 18
[ 1.959743] ata_piix 0000:00:1f.2: version 2.13
[ 1.960360] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 2.125439] scsi host2: ata_piix
[ 2.130990] scsi host3: ata_piix
[ 2.131171] ata3: SATA max UDMA/133 cmd 0xfe00 ctl 0xfe10 bmdma 0xfec0 irq 18
[ 2.131247] ata4: SATA max UDMA/133 cmd 0xfe20 ctl 0xfe30 bmdma 0xfec8 irq 18
[ 2.132754] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 2.135663] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 2.135754] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 2.135874] ehci-pci 0000:00:1a.7: debug port 1
[ 2.139863] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[ 2.139932] ehci-pci 0000:00:1a.7: irq 22, io mem 0xfe9d9c00
[ 2.156047] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 2.156245] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.156317] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.156406] usb usb1: Product: EHCI Host Controller
[ 2.156471] usb usb1: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd
[ 2.156540] usb usb1: SerialNumber: 0000:00:1a.7
[ 2.156866] hub 1-0:1.0: USB hub found
[ 2.156949] hub 1-0:1.0: 6 ports detected
[ 2.158010] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 2.428041] tsc: Refined TSC clocksource calibration: 1994.987 MHz
[ 2.428129] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x39835e0b5ce, max_idle_ns: 881590714106 ns
[ 2.474271] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:21:9b:3e:1a:7a
[ 2.474369] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 2.474459] e1000e 0000:00:19.0 eth0: MAC: 7, PHY: 6, PBA No: 1041FF-0FF
[ 2.475111] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 2.475189] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 2.475285] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 2.475890] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 2.476113] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.476188] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.476282] usb usb2: Product: UHCI Host Controller
[ 2.476357] usb usb2: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 2.476427] usb usb2: SerialNumber: 0000:00:1a.0
[ 2.476753] hub 2-0:1.0: USB hub found
[ 2.476831] hub 2-0:1.0: 2 ports detected
[ 2.477901] pci 0000:00:00.0: Intel Q35 Chipset
[ 2.477999] pci 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 2.478332] pci 0000:00:00.0: detected 8192K stolen memory
[ 2.478452] [drm] Memory usable by graphics device = 512M
[ 2.478525] [drm] Replacing VGA console driver
[ 2.479469] Console: switching to colour dummy device 80x25
[ 2.514139] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.514153] [drm] Driver supports precise vblank timestamp query.
[ 2.528824] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 2.532215] [drm] RC6 disabled, disabling runtime PM support
[ 2.532247] [drm] initialized overlay support
[ 2.534784] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[ 2.535408] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 2.552819] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[ 2.592482] fbcon: inteldrmfb (fb0) is primary device
[ 2.686321] Console: switching to colour frame buffer device 160x64
[ 2.692666] scsi host4: ata_piix
[ 2.696847] scsi host5: ata_piix
[ 2.696977] ata5: SATA max UDMA/133 cmd 0xfe40 ctl 0xfe50 bmdma 0xfed0 irq 18
[ 2.696980] ata6: SATA max UDMA/133 cmd 0xfe60 ctl 0xfe70 bmdma 0xfed8 irq 18
[ 2.697692] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 2.697703] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 3
[ 2.697717] ehci-pci 0000:00:1d.7: debug port 1
[ 2.701619] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 2.701692] ehci-pci 0000:00:1d.7: irq 23, io mem 0xff980800
[ 2.706829] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 2.804049] usb 2-1: new low-speed USB device number 2 using uhci_hcd
[ 2.920105] ata4.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.920213] ata4.01: SATA link down (SStatus 4 SControl 300)
[ 2.920273] ata4.01: link offline, clearing class 3 to NONE
[ 2.922585] ata4.00: ATAPI: Optiarc DVD+/-RW AD-7200S, 101A, max UDMA/100
[ 2.924112] ata3.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.924213] ata3.01: SATA link down (SStatus 4 SControl 300)
[ 2.927217] ata4.00: configured for UDMA/100
[ 2.970631] ata3.00: ATA-7: ST380815AS, 4.ADA, max UDMA/133
[ 2.970722] ata3.00: 156250000 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 2.991024] usb 2-1: New USB device found, idVendor=413c, idProduct=2003
[ 2.991127] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.991206] usb 2-1: Product: Dell USB Keyboard
[ 2.991247] usb 2-1: Manufacturer: Dell
[ 3.021482] ata5: SATA link down (SStatus 4 SControl 300)
[ 3.021600] ata6: SATA link down (SStatus 4 SControl 300)
[ 3.045615] ata3.00: configured for UDMA/133
[ 3.045972] scsi 2:0:0:0: Direct-Access ATA ST380815AS A PQ: 0 ANSI: 5
[ 3.098277] scsi 3:0:0:0: CD-ROM Optiarc DVD+-RW AD-7200S 101A PQ: 0 ANSI: 5
[ 3.124067] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 3.124465] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.124531] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.124596] usb usb3: Product: EHCI Host Controller
[ 3.124640] usb usb3: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd
[ 3.124696] usb usb3: SerialNumber: 0000:00:1d.7
[ 3.125000] hub 3-0:1.0: USB hub found
[ 3.125063] hub 3-0:1.0: 6 ports detected
[ 3.126048] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 3.126142] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 3.126230] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 3.129027] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 3.131564] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.134034] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.136496] usb usb4: Product: UHCI Host Controller
[ 3.138909] usb usb4: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 3.141384] usb usb4: SerialNumber: 0000:00:1a.1
[ 3.144102] hub 4-0:1.0: USB hub found
[ 3.146561] hub 4-0:1.0: 2 ports detected
[ 3.149843] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 3.152432] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 3.154926] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 3.158159] sd 2:0:0:0: [sda] 156250000 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 3.158240] sd 2:0:0:0: [sda] Write Protect is off
[ 3.158244] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.158277] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.160833] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 3.170853] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.173440] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.173759] sr 3:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.173762] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.174414] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 3.181409] usb usb5: Product: UHCI Host Controller
[ 3.183880] usb usb5: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 3.186570] usb usb5: SerialNumber: 0000:00:1d.0
[ 3.189433] hub 5-0:1.0: USB hub found
[ 3.189827] sda: sda1 sda2 < sda5 sda6 >
[ 3.190556] sd 2:0:0:0: [sda] Attached SCSI disk
[ 3.197361] hub 5-0:1.0: 2 ports detected
[ 3.200696] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.203326] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 3.205876] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 3.208418] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 3.210927] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.213400] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.215842] usb usb6: Product: UHCI Host Controller
[ 3.218384] usb usb6: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 3.220860] usb usb6: SerialNumber: 0000:00:1d.1
[ 3.223646] hub 6-0:1.0: USB hub found
[ 3.226176] hub 6-0:1.0: 2 ports detected
[ 3.229584] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.232102] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 3.234565] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 3.237061] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 3.240059] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.243450] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.244050] usb 1-3: new high-speed USB device number 3 using ehci-pci
[ 3.248435] usb usb7: Product: UHCI Host Controller
[ 3.249510] random: fast init done
[ 3.254334] usb usb7: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 3.256790] usb usb7: SerialNumber: 0000:00:1d.2
[ 3.259473] hub 7-0:1.0: USB hub found
[ 3.263812] hub 7-0:1.0: 2 ports detected
[ 3.280102] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.299645] usbcore: registered new interface driver usbhid
[ 3.302193] usbhid: USB HID core driver
[ 3.306187] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1:1.0/0003:413C:2003.0001/input/input5
[ 3.368445] hid-generic 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1a.0-1/input0
[ 3.395080] usb 1-3: New USB device found, idVendor=0951, idProduct=1607
[ 3.397645] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.400215] usb 1-3: Product: DataTraveler 2.0
[ 3.402727] usb 1-3: Manufacturer: Kingston
[ 3.405275] usb 1-3: SerialNumber: 001372982D2AF92196370083
[ 3.452056] usb 3-2: new high-speed USB device number 2 using ehci-pci
[ 3.452131] clocksource: Switched to clocksource tsc
[ 3.559279] usb-storage 1-3:1.0: USB Mass Storage device detected
[ 3.562132] scsi host6: usb-storage 1-3:1.0
[ 3.564881] usbcore: registered new interface driver usb-storage
[ 3.568154] usbcore: registered new interface driver uas
[ 3.662507] usb 3-2: New USB device found, idVendor=0644, idProduct=0200
[ 3.665247] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.667788] usb 3-2: Product: CA-200
[ 3.670343] usb 3-2: Manufacturer: TEAC
[ 3.672864] usb 3-2: SerialNumber: 000006063B17
[ 3.675827] usb-storage 3-2:1.0: USB Mass Storage device detected
[ 3.678527] scsi host7: usb-storage 3-2:1.0
[ 3.800063] usb 3-3: new high-speed USB device number 3 using ehci-pci
[ 3.969003] usb 3-3: New USB device found, idVendor=0cf3, idProduct=9271
[ 3.971712] usb 3-3: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[ 3.974426] usb 3-3: Product: USB2.0 WLAN
[ 3.977102] usb 3-3: Manufacturer: ATHEROS
[ 3.979640] usb 3-3: SerialNumber: 12345
[ 4.444112] usb 7-1: new low-speed USB device number 2 using uhci_hcd
[ 4.562384] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.572741] scsi 6:0:0:0: Direct-Access Kingston DataTraveler 2.0 1.00 PQ: 0 ANSI: 2
[ 4.597114] sd 6:0:0:0: [sdb] 3903578 512-byte logical blocks: (2.00 GB/1.86 GiB)
[ 4.597729] sd 6:0:0:0: [sdb] Write Protect is off
[ 4.597733] sd 6:0:0:0: [sdb] Mode Sense: 16 07 09 51
[ 4.598542] sd 6:0:0:0: [sdb] Incomplete mode parameter data
[ 4.598545] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 4.604227] sdb: sdb1 sdb2
[ 4.631988] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 4.634091] usb 7-1: New USB device found, idVendor=0461, idProduct=4d22
[ 4.634094] usb 7-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.634096] usb 7-1: Product: USB Optical Mouse
[ 4.651254] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1d.2/usb7/7-1/7-1:1.0/0003:0461:4D22.0002/input/input6
[ 4.655177] hid-generic 0003:0461:4D22.0002: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1d.2-1/input0
[ 4.710536] scsi 7:0:0:0: Direct-Access TEAC USB HS-CF Card 4.08 PQ: 0 ANSI: 0
[ 4.714407] scsi 7:0:0:1: Direct-Access TEAC USB HS-xD/SM 4.08 PQ: 0 ANSI: 0
[ 4.718149] scsi 7:0:0:2: Direct-Access TEAC USB HS-MS Card 4.08 PQ: 0 ANSI: 0
[ 4.721523] scsi 7:0:0:3: Direct-Access TEAC USB HS-SD Card 4.08 PQ: 0 ANSI: 0
[ 4.770530] sd 7:0:0:1: [sdd] Attached SCSI removable disk
[ 4.779129] sd 7:0:0:3: [sdf] Attached SCSI removable disk
[ 4.860382] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 4.949830] random: crng init done
[ 4.952651] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.986898] sd 7:0:0:2: [sde] Attached SCSI removable disk
[ 4.995284] sd 7:0:0:0: [sdc] Attached SCSI removable disk
[ 6.289586] ISO 9660 Extensions: RRIP_1991A
[ 6.331579] loop: module loaded
[ 6.378462] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 6.409479] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 12.519728] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.920069] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 15.813145] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 15.837175] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 15.842701] systemd[1]: Detected architecture x86.
[ 15.891218] systemd[1]: Set hostname to <debian>.
[ 15.956669] systemd-fstab-generator[1023]: Failed to create mount unit file /run/systemd/generator/-.mount, as it already exists. Duplicate entry in /etc/fstab?
[ 16.138047] systemd[1019]: /lib/systemd/system-generators/systemd-fstab-generator failed with error code 1.
[ 16.273073] systemd[1]: Listening on Journal Audit Socket.
[ 16.280475] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 16.287629] systemd[1]: Reached target Remote File Systems.
[ 16.294953] systemd[1]: Listening on Syslog Socket.
[ 16.302196] systemd[1]: Listening on udev Control Socket.
[ 16.309608] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 16.643508] systemd-journald[1049]: Received request to flush runtime journal from PID 1
[ 16.649164] lp: driver loaded but no devices found
[ 16.699676] ppdev: user-space parallel port driver
[ 16.718043] parport_pc 00:02: reported by Plug and Play ACPI
[ 16.732143] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[ 16.830586] lp0: using parport0 (interrupt-driven).
[ 26.232132] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 26.475701] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x000000000000082D (\GLBC) (20160831/utaddress-247)
[ 26.481144] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x000000000000082A-0x000000000000082A (\SACT) (20160831/utaddress-247)
[ 26.486577] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x0000000000000828 (\SSTS) (20160831/utaddress-247)
[ 26.492326] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 26.496294] ACPI Warning:
[ 26.496362] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 26.496617] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 26.496720] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 26.496840] sd 7:0:0:0: Attached scsi generic sg3 type 0
[ 26.496969] sd 7:0:0:1: Attached scsi generic sg4 type 0
[ 26.497599] sd 7:0:0:2: Attached scsi generic sg5 type 0
[ 26.497725] sd 7:0:0:3: Attached scsi generic sg6 type 0
[ 26.519394] SystemIO range 0x00000000000008B0-0x00000000000008BF conflicts with OpRegion 0x00000000000008B8-0x00000000000008BB (\GIC2)
[ 26.519528] (20160831/utaddress-247)
[ 26.525494] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 26.529671] ACPI Warning: SystemIO range 0x0000000000000880-0x00000000000008AF conflicts with OpRegion 0x000000000000088C-0x000000000000088F (\GIC1) (20160831/utaddress-247)
[ 26.536255] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 26.539491] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 26.821198] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 26.906885] coretemp coretemp.0: Using relative temperature scale!
[ 26.910352] coretemp coretemp.0: Using relative temperature scale!
[ 26.931769] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 26.960655] snd_hda_codec_analog hdaudioC0D0: autoconfig for AD1984: line_outs=1 (0x12/0x0/0x0/0x0/0x0) type:line
[ 26.967202] snd_hda_codec_analog hdaudioC0D0: speaker_outs=1 (0x13/0x0/0x0/0x0/0x0)
[ 26.971299] snd_hda_codec_analog hdaudioC0D0: hp_outs=1 (0x11/0x0/0x0/0x0/0x0)
[ 26.975033] snd_hda_codec_analog hdaudioC0D0: mono: mono_out=0x0
[ 26.978319] snd_hda_codec_analog hdaudioC0D0: inputs:
[ 26.982220] snd_hda_codec_analog hdaudioC0D0: Mic=0x14
[ 26.987143] snd_hda_codec_analog hdaudioC0D0: Line=0x15
[ 27.005849] intel_powerclamp: No package C-state available
[ 27.025918] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 27.033789] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 27.038114] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 27.043504] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 27.080173] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 27.235161] iTCO_vendor_support: vendor-support=0
[ 27.286145] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 27.333712] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 28.306178] usb 3-3: ath9k_htc: Firmware ath9k_htc/htc_9271-1.4.0.fw requested
[ 28.309736] usbcore: registered new interface driver ath9k_htc
[ 28.436727] usb 3-3: firmware: direct-loading firmware ath9k_htc/htc_9271-1.4.0.fw
[ 28.722261] usb 3-3: ath9k_htc: Transferred FW: ath9k_htc/htc_9271-1.4.0.fw, size: 51008
[ 28.974501] ath9k_htc 3-3:1.0: ath9k_htc: HTC initialized with 33 credits
[ 29.264396] ath9k_htc 3-3:1.0: ath9k_htc: FW Version: 1.4
[ 29.268844] ath9k_htc 3-3:1.0: FW RMW support: On
[ 29.273244] ath: EEPROM regdomain: 0x809c
[ 29.273246] ath: EEPROM indicates we should expect a country code
[ 29.273248] ath: doing EEPROM country->regdmn map search
[ 29.273249] ath: country maps to regdmn code: 0x52
[ 29.273251] ath: Country alpha2 being used: CN
[ 29.273253] ath: Regpair used: 0x52
[ 29.372494] ieee80211 phy0: Atheros AR9271 Rev:1
[ 29.926351] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[ 30.396350] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[ 30.499507] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 30.702459] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 30.995087] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 31.605975] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 179.833853] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
Thank you
Aaron
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=
DISPLAY=axis
2272
- InMyDarkestHour
- Visitor
12 May 2019 00:23 #133492
by InMyDarkestHour
Replied by InMyDarkestHour on topic Trying to get Debian Squeeze to run my router
Since it's the same unknown parameter message as your previous thread you need to look through your ini files for any syntax errors.
- Thank you received: 5334
12 May 2019 01:20 #133497
Replied by PCW on topic Trying to get Debian Squeeze to run my router
Also if using Preempt-RT, unlike RTAI, there are no LinuxCNC messages in the kernel log, so dmesg provides no useful information here.
On the other hand, posting you hal and ini files may allow someone to spot the problem
- aaron
12 May 2019 08:39 #133527
by aaron
Replied by aaron on topic Trying to get Debian Squeeze to run my router
Hi and Thanks for reply
Attached are my ini and hal files. This configurations has worked well for over a year from the wheezy computer.
best wishes
Aaron
best wishes
Aaron
- aaron
12 May 2019 08:45 #133529
by aaron
Ooops
Sorry, I forgot the ini file
Here are the files again.
Best
Aaron
Best
Aaron
- pl7i92
- Thank you received: 358
12 May 2019 08:47 #133530
by pl7i92
Replied by pl7i92 on topic Trying to get Debian Squeeze to run my router
same file 2Times
The error says no rt loaded
did you use the iso
or what kernal did you compile
i atache the files for Foam i got
did you use the iso
- aaron
12 May 2019 09:13 #133534
by aaron
I downloaded this iso:
linuxcnc-stretch-uspace-i386-r12.iso
from
www.linuxcnc.org/testing-stretch-rtpreempt/
from
- Thank you received: 4151
12 May 2019 10:28 - 12 May 2019 10:33 #133541
Replied by rodw on topic Trying to get Debian Squeeze to run my router
What I saw in your messages was this:
This is an ini file setting (in the [DISPLAY] section from memory) It should beThis tells LinuxCNC what DRO's to display.
It is the [KINS] section that tells linuxcnc which joint belongs to which axis.
Its always best to run from the command line and look for the error message until you get it loading!
Unknown parameter `coordinates=XYZX'This is an ini file setting (in the [DISPLAY] section from memory) It should be
`coordinates=XYZ'It is the [KINS] section that tells linuxcnc which joint belongs to which axis.
Last edit: 12 May 2019 10:33 by rodw.
12 May 2019 12:15 #133554
As a data point, you config runs fine on my test machine (LinuxCNC 2.8, Ubuntu 18.04)
What LinuxCNC version are you running? (the configuration is for 2.8)
- aaron
12 May 2019 16:22 #133572
by aaron
Thanks for replies
I have tried to edit coordinates=XYZ in the .ini file, it didn't seem to make a difference.
I can't find 'linuxcnc_debug.txt'
I am trying to get it going on 2.7 (I am not sure what it was before I broke it) Can you point me to instructions to upgrade to 2.8 if that is what is needed.
Respectfully......
Here is the output from starting LCNC from command line:
aaron@#####:~/Desktop$ linuxcnc
LINUXCNC - 2.7.14
Machine configuration directory is '/home/aaron/linuxcnc/configs/foam_xxyz'
LinuxCNC terminated with an error. You can find more information in the log:
/home/aaron/linuxcnc_debug.txt
and
/home/aaron/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
aaron@########:~/Desktop$
Respectfully......
LINUXCNC - 2.7.14
and
Time to create page: 0.413 seconds
