(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
6 years 4 months ago #172158 by wdcnc
New here and have a question.
I have followed the instruction on the first post in this thread and have successfully installed as described.
Is there any reason that I should not let the system perform updates?
6 years 4 months ago #172160 by tommylight
You can do:
sudo apt update
sudo apt dist-upgrade
as much as you like and it will update everything.
But will not allow new kernels and new Mint version that would render LinuxCNC non functional.
The following user(s) said Thank You: wdcnc
6 years 4 months ago - 6 years 4 months ago #172230 by seuchato
Wanted to try out the o so widely praised mint, so I dug out this thread.
tommylight wrote: ...
sudo apt update - wget [color=red]http://http.us.debian.org/debian/pool/main/l/linux-signed-amd64/linux-image-5.4.0-0.bpo.4-rt-amd64_5.4.19-1~bpo10+1_amd64.deb[/color] ....
wgetting the mentioned kernel failed, as "http.us.debian.org/" could not be found. I searched for a similar kernel here , downloaded ist and installed it.
I got this
gdebi linux-image-5.6.0-0.bpo.2-rt-amd64_5.6.14-2~bpo10+1_amd64.deb Reading package lists... Done Building dependency tree Reading state information... Done Reading state information... Done Linux 5.6 for 64-bit PCs, PREEMPT_RT (signed) The Linux kernel 5.6 and modules for use on PCs with AMD64, Intel 64 or VIA Nano processors. . This kernel includes the PREEMPT_RT realtime patch set. . The kernel image and modules are signed for use with Secure Boot. Wollen Sie das Software-Paket installieren? [j/N]:j Vormals nicht ausgewähltes Paket linux-image-5.6.0-0.bpo.2-rt-amd64 wird gewählt. dpkg: Dekonfiguration von wireless-regdb wird in Betracht gezogen, welches durch Installation von »linux-image-5.6.0-0.bpo.2-rt-amd64« beschädigt würde ... dpkg: Ja, wireless-regdb wird dekonfiguriert (beschädigt durch linux-image-5.6.0-0.bpo.2-rt-amd64) (Lese Datenbank ... 293464 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von linux-image-5.6.0-0.bpo.2-rt-amd64_5.6.14-2~bpo10+1_amd64.deb ... wireless-regdb (2018.05.09-0ubuntu1~18.04.1) wird de-konfiguriert ... Entpacken von linux-image-5.6.0-0.bpo.2-rt-amd64 (5.6.14-2~bpo10+1) ... linux-image-5.6.0-0.bpo.2-rt-amd64 (5.6.14-2~bpo10+1) wird eingerichtet ... I: /vmlinuz.old is now a symlink to boot/vmlinuz-5.0.0-32-generic I: /vmlinuz is now a symlink to boot/vmlinuz-5.6.0-0.bpo.2-rt-amd64 I: /initrd.img is now a symlink to boot/initrd.img-5.6.0-0.bpo.2-rt-amd64 /etc/kernel/postinst.d/dkms: * dkms: running auto installation service for kernel 5.6.0-0.bpo.2-rt-amd64 ...done. /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-5.6.0-0.bpo.2-rt-amd64 W: Possible missing firmware /lib/firmware/i915/icl_dmc_ver1_09.bin for module i915 W: Possible missing firmware /lib/firmware/i915/tgl_dmc_ver2_04.bin for module i915 W: Possible missing firmware /lib/firmware/i915/skl_huc_2.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/skl_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/bxt_huc_2.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/bxt_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/kbl_huc_4.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/kbl_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/glk_huc_4.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/glk_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/kbl_huc_4.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/kbl_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/cml_huc_4.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/cml_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/icl_huc_9.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/icl_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/ehl_huc_9.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/ehl_guc_33.0.4.bin for module i915 W: Possible missing firmware /lib/firmware/i915/tgl_huc_7.0.3.bin for module i915 W: Possible missing firmware /lib/firmware/i915/tgl_guc_35.2.0.bin for module i915 /etc/kernel/postinst.d/zz-update-grub:
and I get the following messages:
apt-get -y install linuxcnc-uspace Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Probieren Sie »apt --fix-broken install«, um dies zu korrigieren. Die folgenden Pakete haben unerfüllte Abhängigkeiten: linux-image-5.6.0-0.bpo.2-rt-amd64 : Beschädigt: wireless-regdb (< 2019.06.03-1~) aber 2018.05.09-0ubuntu1~18.04.1 soll installiert werden Beschädigt: wireless-regdb:i386 (< 2019.06.03-1~) linuxcnc-uspace : Hängt ab von: libboost-python1.62.0 soll aber nicht installiert werden Hängt ab von: libmodbus5 (>= 3.0.2) soll aber nicht installiert werden Hängt ab von: libtk8.6 (>= 8.6.0) soll aber nicht installiert werden Hängt ab von: libudev-dev soll aber nicht installiert werden
So I guess, that kernel and source is no good. Which one then?
greez
chris
Last edit: 6 years 4 months ago by seuchato. Reason: closed quote
6 years 4 months ago - 6 years 4 months ago #172231 by tommylight
It works here:
And the source code and unstable packages need to be enabled in the software sources from the main menu>administartion
Edit:
I did manage to install and run the 5.6 kernel, but the latency was terrible.
Last edit: 6 years 4 months ago by tommylight. Reason: More info
6 years 4 months ago #172234 by seuchato
worked now here too, maight have been a temprary name resolver problem.
However I still got some warning:
... dkms: running auto installation service for kernel 5.4.0-0.bpo.4-rt-amd64 ...done. /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-5.4.0-0.bpo.4-rt-amd64 W: Possible missing firmware /lib/firmware/i915/tgl_dmc_ver2_04.bin for module i915 W: Possible missing firmware /lib/firmware/i915/skl_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/bxt_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/kbl_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/glk_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/kbl_guc_33.0.0.bin for module i915 W: Possible missing firmware /lib/firmware/i915/icl_guc_33.0.0.bin for module i915 /etc/kernel/postinst.d/zz-update-grub: ...
I guess these can be disregarded.
Greez
chris
6 years 4 months ago #172236 by tommylight
i915 was an Intel chipset with built in graphics in the 2000's so it has no more support in recent kernels. Good, as it had plenty of issues and needed to be blacklisted often for Linux to work.
It is safe to ignore those warnings.
Time to create page: 0.303 seconds
