(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
6 years 4 months ago #172426 by seuchato
Tom, do you think the what you have given for Debian Buster could/should work for mint 19.3 too?
greez
chris
6 years 4 months ago #172428 by seuchato
Tried it, does not work, next will be a try to add a buster repo
6 years 4 months ago #172435 by seuchato
this works:
download kernel 4.9.0-12-rt-amd64 from herehere
gdebi linux-image-4.9.0-12-rt-amd64_4.9.210-1+deb9u1_amd64.deb
edit /etc/default/grubthe line "GRUB_TIMEOUT=5" (lets you choose which kernel you like to boot)
reboot
select the newly installed kernel
hth
chris
6 years 4 months ago #172436 by tommylight
The same kernel for Buster will work on Mint but has to be manually downloaded and installed.And the 5.4 kernel will also work on Buster.
6 years 4 months ago #172440 by seuchato
Got 4.9.0-12-rt-amd64 installed, rebooted into it and am running lcnc-hw now for more than 35 minutes. So far no realtime delay. Hope it stays so.
6 years 4 months ago #172443 by tommylight
With or without base thread ?
You do not need base thread if you do not plan to use software stepping/parallel port, so base thread is useless in that case and might cause worse servo latency.
Time to create page: 0.212 seconds
