- Thank you received: 173
tommylight wrote:
Are you in Kosovo ? We had hail storms yesterday, the roads were full of water that driving at 20 KMH was hard !dvn4life1972 wrote: We had some storms roll through and lost power. I'll try probably tomorrow when we have power again. Thanks.
Did you try both sides of the keyboard ? I have two PCS that require that on a USB keyboard.dvn4life1972 wrote: Ok now I tried cntrl+shift 3 times on reboot and it doesn't go to grub at all. It just boots into the desktop as normal.
so both CTRL and both Shifts
tommylight wrote:
Go to Menu > Administration > Grub Customizer > select the kernel with RT in the name > click the up arrow untill that is the top most choice > Save and close, reboot.Code:sudo add-apt-repository ppa:danielrichter2007/grub-customizer sudo apt-get update sudo apt-get install grub-customizer
