- Thank you received: 3
(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
6 years 3 months ago #175983
by riversvic
Replied by riversvic on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
That was it! thank you
6 years 3 months ago #175984
Replied by tommylight on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
You are welcomed, always.
The following user(s) said Thank You: bevins
6 years 2 months ago #177629
by bevins
Replied by bevins on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Thanks Tommy,
LinuxMint 19.3 installed with linuxcnc master......
Easiest install to date....
6 years 2 months ago #177633
You are welcomed.
6 years 2 months ago #179577
by aparecido
Replied by aparecido on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
I am testing Mint 19.3 following the tutorial in the first post, I checked the kernel and it is the same as in the initial post of the topic.
IPM31 v1.03 motherboard (Pcware / Pegatron) with onboard video
Core2duo E7500 2.93GHz-FSB 1066Mhz-L2 cache 3MB
1GB Kingston DDR2
Hd sata
I opened several programs and some windows with glxgears, the Jitter is around 40000ns and then jumps to 166640ns and stays at that value.
What can I do to lower the jitter value?
Thank you.
1GB Kingston DDR2
Hd sata
Thank you.
6 years 2 months ago #179580
Add more memory, 4GB works fine, sometimes even 2GB are ok.
Time to create page: 0.158 seconds
