(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
6 years 2 months ago #179746 by aparecido
tommylight wrote:
aparecido wrote:
tommylight wrote: I was about to say that Clive uses it ....... to late ! :)
Sorry Tommy, I don't understand ...
Oh sorry, that was meant for Beagle.
Ok, no problem :laugh:
6 years 2 months ago #179799 by seuchato
aparecido wrote: I'm not able to find Kingston or Markvision memories, I just found Digitron, Smart and Microware, but I don't know if they are good ... I don't know these brands.
In the case of RAM: more helps more!
Taken from your test results here :
RAM related data: Maximum Memory Module Size: 4096 MB Maximum Total Memory Size: 8192 MB Maximum Capacity: 16 GB Maximum Memory Module Size: 4096 MB Maximum Total Memory Size: 8192 MB
[Obs: need to work on my script again, seems confusing]
If your MoBo has two slots, you can go up to 8GiB. With 4GiB, there should not be any change in swap usage, while running the script.
greez
chris
The following user(s) said Thank You: aparecido
6 years 2 months ago - 6 years 2 months ago #179808 by aparecido
greez
chris
It supports up to 4gb, I managed to find markvision, I am going to get it soon.
Will an offboard video card help you too?
Last edit: 6 years 2 months ago by aparecido.
6 years 2 months ago #179822 by tommylight
It does not matter as long as they work properly. Try a local shop for used ones, they are usually very cheap.
6 years 2 months ago - 6 years 2 months ago #179845 by aparecido
I got two ddr2 800mhz 2gb each, so now I have 4gb installed.
I will already post the results file of the script.
I just posted the test result with 4gb of ram.
6 years 1 month ago #180682 by Mud
I'm getting a 'No name' error when I try the keyserver line:
Executing: /tmp/apt-key-gpghome.NNEGawpkaU/gpg.1.sh --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E gpg: keyserver receive failed: No name
Time to create page: 0.107 seconds
