(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
  • BeagleBrainz
  • New Member
  • New Member
6 years 6 days ago - 6 years 6 days ago #187362 by BeagleBrainz
Not completely out of the woods yet.
What we need to do is stop those modules from loading every time you boot.
The file that I have attached needs to be renamed blacklist-linuxcnc-ppdev.conf and then copied using sudo to /etc/modprode.d/
mv blacklist-linuxcnc-ppdev.conf.txt blacklist-linuxcnc-ppdev.conf
cp sudo blacklist-linuxcnc-ppdev.conf /etc/modprobe.d
Then reboot and see if linuxcnc runs. If not we will have to try some thing else.
Last edit: 6 years 6 days ago by BeagleBrainz.
5 years 11 months ago #189739 by aparecido
Hello everyone, everything good? I'm trying to run the autoleveller software, but it is giving me an error with the installed java, I couldn't solve it, the author of the software suggests installing the JRE version 11 or earlier, I followed tutorials that found and it didn't work with any.
can you help me? Thanks.
5 years 11 months ago #189741 by tommylight
Did you set the permissions for the file to be executable ?
And start a new topic for software questions and issues not related to this tutorial.
The following user(s) said Thank You: aparecido
5 years 11 months ago - 5 years 11 months ago #189743 by aparecido
Yes, I gave the permissions.
Just explaining to me that I posted here .. I posted on this topic, because I am not using the installation of the main page, I am using Mint 19.3 and I thought the post here would be more appropriate, as there must be differences between it and Debian.
I created the topic , thanks again tommylight.
Last edit: 5 years 11 months ago by aparecido.
5 years 11 months ago #189745 by tommylight
Yup i thought you are using this, but that is a Linux issue and this is for installation of LinuxCNC issues.
You are welcomed, always.
5 years 9 months ago - 5 years 9 months ago #194586 by Fiury
Hello,
i intalled Mint 19.3 and linuxcnc , but i cannt run VDF via terminal:
a) PC - intell NUC
b) board - mesa7i76ed
i have warning in setup of mesa (by spindle): You are using a simulated-realtime version of LinuxCNC, so testing / tuning of hardware is unavailable.
Have i problem with system or VDF setup ? (is the warning ok ? probably not i think so..)
Thank you for support
Last edit: 5 years 9 months ago by Fiury.
Time to create page: 0.317 seconds
