(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
5 years 4 months ago #211200 by rodw
BeagleBrainz wrote: Fly us over and I'll come help......hahahaha
They'll never let you back in so be careful!
5 years 4 months ago #213236 by aparecido
I'm having trouble machining on my CNC with Mint 19.3 and Linuxcnc 2.8.0, can I post what's happening here or open a new topic?
I'm lost on where to post here on the forum to get help, apparently the machine loses pace at times and from what I've noticed/tested, it's not a mechanical problem.
  • BeagleBrainz
  • New Member
  • New Member
5 years 4 months ago #213238 by BeagleBrainz
A new topic in the General area would be the best place to start.
Remember to give your PC specs, your OS, as not all may have read this thread and the hardware you are using Mesa card or parallel port.
Including you Hal and ini files to begin will save time.
A description of your machine, eg steppers or servos ball screw or plain lead screws and the like.
And finally a good description of the issue, any photos that may highlight the issue.
Be prepared for a few other questions.
And hopefully before you know it you’ll be making chips.
5 years 3 months ago #213626 by tommylight
Updated the how to to use the Buster LinuxCNC repo since Stretch is not being built any more, requires downloading and installing additional 5 files.
The following user(s) said Thank You: JohnnyCNC
5 years 3 months ago #215535 by tommylight
5 years 3 months ago #216221 by mjones@welfab.ca
Hi How are things. I installed Linux Mint 19.3 as recently advised, and copied and pasted all the lines on page one of this topic.
Mint 19.3 installs quite well, no errors, both networks are up and running, but after reboot Linuxcnc still doesn't seem to be on the system. I can't find a link anywhere. should i try doing the copy past all the lines again.
Time to create page: 0.396 seconds
