(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
6 years 8 months ago #156535 by tommylight
Might be, never considered that before, thank you.
6 years 8 months ago #156717 by freddie
I am trying this on Linux mint mate 19.1 and downloaded all the files as per your instructions but don't know how to load the rt kernel. boot menu shows it is there but when I select it I get error saying I need to load kernel first. I have to select the regular kernel to boot. Don't know what to do. New to this even though I have been using linuxcnc on my router for over a year. Thought in would be nice to enjoy mint out in my work shed when not running cnc. Help!
  • BeagleBrainz
  • New Member
  • New Member
6 years 8 months ago #156724 by BeagleBrainz
Ok will need a picture of the boot menu message you are getting, the way you are describing is a little confusing to me.
Will need you to post the contents of /boot/grub/grub.cfg
6 years 8 months ago #156725 by tommylight
You need to install 2 files with "kona" in their name, installing just linux-headers-kona will result in the error you are getting. You must all install Linux-image-kona........
6 years 8 months ago #156729 by WhyMe1
Download 4.16.12-rt5-kona-rt_amd64.deb used gdebi to install ,Reboot shift/ctrl grub2 menu ,Not showing it only see 5.3.8.28 generic .I also did the the three sudo line, reboot same thing NO 4.16.12rt5Kona rt amd64 again only shows Linux 5.3.8.28 generic.
What am I doing wrong ?? Not a happy camper right now with this .
6 years 8 months ago #156730 by freddie
I did that, both image and headers, 4.16.12rt5-kona-rt amd64.deb and then the rt kernel. Same message at boot, you need to load kernel first. I am going to recheck again but no luck yet. I am sure I got the right files.
Time to create page: 0.288 seconds
