(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
  • BeagleBrainz
  • New Member
  • New Member
6 years 8 months ago - 6 years 8 months ago #156781 by BeagleBrainz
freddie wrote: Everything is loaded and ready. If only I could get to the grub menu to load the kernel. Ctrl-shift won't work and I don't know anything else. About ready to continue using Debian Wheezy!
[strike]Ok go back to the previous page, look for my post regarding the iso with Linuxcnc on the LinuxMint iso, download the image. Pay attention to the bits in red, boot from you chosen media, install as if it were a standard LinuxMint disc, reboot and you’ll have LinuxMint 19.2 with Linuxcnc and the correct kernel installed.
If you are going to use a windows machine to put the image onto a USB stick, please, please use the utility I suggest. It will work, I have tested it many many times. Just follow all the instructions in my post and you will be good to go.
Any issues I am only too happy to help.[/strike]
Last edit: 6 years 8 months ago by BeagleBrainz.
6 years 8 months ago #156787 by freddie
I have installed it now. Didn't work at first but then realized it was an apt. I looked at my apts and there it was, Grub customizer. I set it up to boot the rt kernel first and now I am rolling. It will be simple from now on! Never could have done it without your help. Thank you so much!
6 years 8 months ago #156798 by WhyMe1
All is working Now ! Re-download fresh copy LinuxMint 19.3 Burn to DVD - format/reload HD -- redone step one of post -- so far so good. Latency test is super high on this Dell D620 with docking station with parallel port ..
Just my luck .
Thank You for all the Help !
  • BeagleBrainz
  • New Member
  • New Member
6 years 8 months ago - 6 years 8 months ago #156803 by BeagleBrainz
[strike]So you didn't give my iso a go ?[/strike]
6 years 8 months ago #156804 by tommylight
WhyMe1 wrote: Latency test is super high on this Dell D620 with docking station with parallel port ..
Just my luck .
Nope, you need the RTAI kernel and Linuxcnc version from here:
linuxcnc.org/temp
That is an old laptop so RTAI should be much better regarding latency.
Time to create page: 0.145 seconds
