Cannot get Linuxcnc to run Mint LMDE 3 Cindy
  • thefabricator03
  • thefabricator03's Avatar Topic Author
  • Visitor
  • Visitor
19 Jun 2019 02:03 - 20 Jun 2019 00:57 #137262 by thefabricator03
Cannot get Linuxcnc to run Mint LMDE 3 Cindy was created by thefabricator03
Hi Guys,
I am having trouble getting Linuxcnc to run on my hardware,
I am using the following,
Mint LMDE 3 Cindy
4.9.0-7rt-amd64 install with synaptic packet manager
Plasmac Branch
Mesa 7i76e connect directly to computer,
I can ping the mesa card but when I try to open the Linuxcnc shortcut created by Pnccof I get the following error report,
Error report created by /home/plasma/plasmac/tcl/show_errors.tcl:
Print file information:
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/plasma/plasmac/bin
LINUXCNC_TCL_DIR=/home/plasma/plasmac/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/plasma/plasmac/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/plasma/plasmac/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/plasma/linuxcnc/configs/SWS_Plasma'
Machine configuration file is 'SWS_Plasma.ini'
INIFILE=/home/plasma/linuxcnc/configs/SWS_Plasma/SWS_Plasma.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYYZ
Starting LinuxCNC...
Found file(REL): ./SWS_Plasma.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:42:f0
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0:     IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 006 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 007 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 008 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i76e.0:     IO Pin 009 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i76e.0:     IO Pin 010 (P1-07): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i76e.0:     IO Pin 011 (P1-08): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i76e.0:     IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0:     IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0:     IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0:     IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0:     IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0:     IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0:     IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0:     IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0:     IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0:     IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0:     IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0:     IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0:     IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0:     IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0:     IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0:     IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0:     IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0:     IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0:     IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0:     IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0:     IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0:     IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0:     IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0:     IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0:     IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0:     IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0:     IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0:     IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0:     IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0:     IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0:     IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
iptables: No chain/target/match by that name.
./SWS_Plasma.hal:128: parameter or pin 'pid.y1.Pgain' not found
1350
Stopping realtime threads
Unloading hal components
Kernel message information:
[    0.000000] Linux version 4.9.0-7-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u2 (2018-08-13)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-7-rt-amd64 root=UUID=de4746eb-d690-4a1e-af7b-1ffe032038bf ro quiet splash
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000020200000-0x000000003fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000401fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040200000-0x00000000cabdbfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000cabdc000-0x00000000cac24fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cac25000-0x00000000cac32fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000cac33000-0x00000000cac41fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cac42000-0x00000000cac46fff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000cac47000-0x00000000cac52fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cac53000-0x00000000cac74fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cac75000-0x00000000cacf5fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cacf6000-0x00000000cacfafff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000cacfb000-0x00000000cacfbfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cacfc000-0x00000000cacfcfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cacfd000-0x00000000cad0efff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cad0f000-0x00000000cad1cfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cad1d000-0x00000000cad1ffff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000cad20000-0x00000000cad21fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cad22000-0x00000000cad2bfff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000cad2c000-0x00000000cad2efff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cad2f000-0x00000000cad71fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cad72000-0x00000000caffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000cb800000-0x00000000cf9fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed3ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000012e5fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.10 by American Megatrends
[    0.000000] efi:  SMBIOS=0xcad2db98  ACPI=0xcac25000  ACPI 2.0=0xcac25000  MPS=0xf4ca0
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Hewlett-Packard HP Compaq 8200 Elite SFF PC/1495, BIOS J01 v02.21 06/20/2012
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x12e600 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: write-back
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0CB800000 mask FFF800000 uncachable
[    0.000000]   1 base 0CC000000 mask FFC000000 uncachable
[    0.000000]   2 base 0D0000000 mask FF0000000 uncachable
[    0.000000]   3 base 0E0000000 mask FE0000000 uncachable
[    0.000000]   4 base 12E600000 mask FFFE00000 uncachable
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: last_pfn = 0xcb000 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000f4c90-0x000f4c9f] mapped at [ffff8ff5c00f4c90]
[    0.000000] Base memory trampoline at [ffff8ff5c0095000] 95000 size 24576
[    0.000000] reserving inaccessible SNB gfx pages
[    0.000000] BRK [0x1133c0000, 0x1133c0fff] PGTABLE
[    0.000000] BRK [0x1133c1000, 0x1133c1fff] PGTABLE
[    0.000000] BRK [0x1133c2000, 0x1133c2fff] PGTABLE
[    0.000000] BRK [0x1133c3000, 0x1133c3fff] PGTABLE
[    0.000000] BRK [0x1133c4000, 0x1133c4fff] PGTABLE
[    0.000000] BRK [0x1133c5000, 0x1133c5fff] PGTABLE
[    0.000000] BRK [0x1133c6000, 0x1133c6fff] PGTABLE
[    0.000000] BRK [0x1133c7000, 0x1133c7fff] PGTABLE
[    0.000000] BRK [0x1133c8000, 0x1133c8fff] PGTABLE
[    0.000000] BRK [0x1133c9000, 0x1133c9fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x33bcb000-0x35ddcfff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000CAC25000 000024 (v02 HPQOEM)
[    0.000000] ACPI: XSDT 0x00000000CAC25078 00006C (v01 HPQOEM SLIC-BPC 01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x00000000CAC2CC30 0000F4 (v04 HPQOEM SLIC-BPC 01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x00000000CAC25170 007AC0 (v02 HPQOEM SLIC-BPC 00000008 INTL 20051117)
[    0.000000] ACPI: FACS 0x00000000CAD14F80 000040
[    0.000000] ACPI: APIC 0x00000000CAC2CD28 000072 (v03 HPQOEM SLIC-BPC 01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000CAC2CDA0 000102 (v01 AMICPU PROC     00000001 MSFT 03000001)
[    0.000000] ACPI: MCFG 0x00000000CAC2CEA8 00003C (v01 HPQOEM SLIC-BPC 01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 0x00000000CAC2CEE8 000038 (v01 HPQOEM SLIC-BPC 01072009 AMI. 00000004)
[    0.000000] ACPI: SSDT 0x00000000CAC2CF20 005270 (v01 COMPAQ WMI      00000001 MSFT 03000001)
[    0.000000] ACPI: SLIC 0x00000000CAC32190 000176 (v01 HPQOEM SLIC-BPC 00000001      00000000)
[    0.000000] ACPI: TCPA 0x00000000CAC32308 000032 (v02 APTIO4 NAPAASF  00000001 MSFT 01000013)
[    0.000000] ACPI: DMAR 0x00000000CAC32340 0000E8 (v01 ALASKA A M I    00000001 INTL 00000001)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000012e5fffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x12e5fb000-0x12e5fffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000012e5fffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009ffff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000001fffffff]
[    0.000000]   node   0: [mem 0x0000000020200000-0x000000003fffffff]
[    0.000000]   node   0: [mem 0x0000000040200000-0x00000000cabdbfff]
[    0.000000]   node   0: [mem 0x00000000cad72000-0x00000000caffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000012e5fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000012e5fffff]
[    0.000000] On node 0 totalpages: 1019913
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 175 pages reserved
[    0.000000]   DMA zone: 3999 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 12906 pages used for memmap
[    0.000000]   DMA32 zone: 825962 pages, LIFO batch:31
[    0.000000]   Normal zone: 2968 pages used for memmap
[    0.000000]   Normal zone: 189952 pages, LIFO batch:31
[    0.000000] Reserving Intel graphics memory at 0x00000000cba00000-0x00000000cf9fffff
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x20000000-0x201fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x40000000-0x401fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xcabdc000-0xcac24fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcac25000-0xcac32fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcac33000-0xcac41fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcac42000-0xcac46fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcac47000-0xcac52fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcac53000-0xcac74fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcac75000-0xcacf5fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcacf6000-0xcacfafff]
[    0.000000] PM: Registered nosave memory: [mem 0xcacfb000-0xcacfbfff]
[    0.000000] PM: Registered nosave memory: [mem 0xcacfc000-0xcacfcfff]
[    0.000000] PM: Registered nosave memory: [mem 0xcacfd000-0xcad0efff]
[    0.000000] PM: Registered nosave memory: [mem 0xcad0f000-0xcad1cfff]
[    0.000000] PM: Registered nosave memory: [mem 0xcad1d000-0xcad1ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xcad20000-0xcad21fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcad22000-0xcad2bfff]
[    0.000000] PM: Registered nosave memory: [mem 0xcad2c000-0xcad2efff]
[    0.000000] PM: Registered nosave memory: [mem 0xcad2f000-0xcad71fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcb000000-0xcb7fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xcb800000-0xcf9fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xcfa00000-0xfed1bfff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed3ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed40000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0xcfa00000-0xfed1bfff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] percpu: Embedded 116 pages/cpu @ffff8ff6ee200000 s437952 r8192 d28992 u524288
[    0.000000] pcpu-alloc: s437952 r8192 d28992 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 1003800
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-7-rt-amd64 root=UUID=de4746eb-d690-4a1e-af7b-1ffe032038bf ro quiet splash
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 3863824K/4079652K available (6386K kernel code, 1152K rwdata, 2908K rodata, 1680K init, 968K bss, 215828K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS:33024 nr_irqs:456 16
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: PIT calibration matches HPET. 1 loops
[    0.000000] tsc: Detected 3092.951 MHz processor
[    0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 6185.90 BogoMIPS (lpj=12371804)
[    0.000004] pid_max: default: 32768 minimum: 301
[    0.000010] ACPI: Core revision 20160831
[    0.003057] ACPI: 3 ACPI AML tables successfully acquired and loaded
[    0.003465] Security Framework initialized
[    0.003466] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.003469] AppArmor: AppArmor disabled by boot time parameter
[    0.003909] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes)
[    0.004902] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.005172] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.005176] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.005374] CPU: Physical Processor ID: 0
[    0.005375] CPU: Processor Core ID: 0
[    0.005378] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.005378] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.005380] mce: CPU supports 9 MCE banks
[    0.005387] CPU0: Thermal monitoring enabled (TM1)
[    0.005397] process: using mwait in idle threads
[    0.005400] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[    0.005400] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.005401] Spectre V2 : Mitigation: Full generic retpoline
[    0.005402] Speculative Store Bypass: Vulnerable
[    0.005814] Freeing SMP alternatives memory: 24K
[    0.007853] ftrace: allocating 25215 entries in 99 pages
[    0.027016] smpboot: Max logical packages: 1
[    0.027021] DMAR: Host address width 36
[    0.027022] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.027028] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c0000020e60262 ecap f0101a
[    0.027029] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.027033] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap c9008020660262 ecap f0105a
[    0.027034] DMAR: RMRR base: 0x000000cac33000 end: 0x000000cac41fff
[    0.027035] DMAR: RMRR base: 0x000000cb800000 end: 0x000000cf9fffff
[    0.027036] DMAR-IR: IOAPIC id 0 under DRHD base  0xfed91000 IOMMU 1
[    0.027037] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.027038] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.027435] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.027436] x2apic enabled
[    0.027445] Switched APIC routing to cluster x2apic.
[    0.028196] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.067888] TSC deadline timer enabled
[    0.067892] smpboot: CPU0: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz (family: 0x6, model: 0x2a, stepping: 0x7)
[    0.067896] Performance Events: PEBS fmt1+, SandyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.067912] core: PEBS disabled due to CPU errata, please upgrade microcode
[    0.067915] ... version:                3
[    0.067916] ... bit width:              48
[    0.067916] ... generic registers:      8
[    0.067917] ... value mask:             0000ffffffffffff
[    0.067918] ... max period:             00007fffffffffff
[    0.067918] ... fixed-purpose events:   3
[    0.067919] ... event mask:             00000007000000ff
[    0.124061] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.176015] x86: Booting SMP configuration:
[    0.176016] .... node  #0, CPUs:      #1 #2 #3
[    0.266491] x86: Booted up 1 node, 4 CPUs
[    0.266493] smpboot: Total of 4 processors activated (24743.60 BogoMIPS)
[    0.269091] devtmpfs: initialized
[    0.269152] x86/mm: Memory block size: 128MB
[    0.271015] PM: Registering ACPI NVS region [mem 0xcabdc000-0xcac24fff] (299008 bytes)
[    0.271020] PM: Registering ACPI NVS region [mem 0xcac53000-0xcac74fff] (139264 bytes)
[    0.271023] PM: Registering ACPI NVS region [mem 0xcacfc000-0xcacfcfff] (4096 bytes)
[    0.271024] PM: Registering ACPI NVS region [mem 0xcad0f000-0xcad1cfff] (57344 bytes)
[    0.271025] PM: Registering ACPI NVS region [mem 0xcad2f000-0xcad71fff] (274432 bytes)
[    0.271032] reboot: HP Compaq Laptop series board detected. Selecting BIOS-method for reboots.
[    0.271072] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.271088] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.271129] pinctrl core: initialized pinctrl subsystem
[    0.271234] NET: Registered protocol family 16
[    0.271424] cpuidle: using governor ladder
[    0.271463] cpuidle: using governor menu
[    0.271493] ACPI: bus type PCI registered
[    0.271495] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.271561] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.271563] PCI: not using MMCONFIG
[    0.271564] PCI: Using configuration type 1 for base access
[    0.271655] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.271703] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.272547] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.272696] ACPI: Added _OSI(Module Device)
[    0.272697] ACPI: Added _OSI(Processor Device)
[    0.272697] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.272698] ACPI: Added _OSI(Processor Aggregator Device)
[    0.272888] ACPI: Executed 1 blocks of module-level executable AML code
[    0.276163] ACPI: Dynamic OEM Table Load:
[    0.276168] ACPI: SSDT 0xFFFF8FF6E87E3C00 00038C (v01 AMI    IST      00000001 MSFT 03000001)
[    0.276312] ACPI: Dynamic OEM Table Load:
[    0.276314] ACPI: SSDT 0xFFFF8FF6E87F0840 000084 (v01 AMI    CST      00000001 MSFT 03000001)
[    0.276955] ACPI: Interpreter enabled
[    0.276968] ACPI: (supports S0 S3 S4 S5)
[    0.276969] ACPI: Using IOAPIC for interrupt routing
[    0.276992] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.277040] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[    0.277051] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.277279] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.282214] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.282218] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.282376] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.282697] PCI host bridge to bus 0000:00
[    0.282699] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.282701] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.282702] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.282703] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.282704] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.282707] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.282708] pci_bus 0000:00: root bus resource [mem 0xcfa00000-0xffffffff window]
[    0.282710] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.282717] pci 0000:00:00.0: [8086:0100] type 00 class 0x060000
[    0.282807] pci 0000:00:02.0: [8086:0102] type 00 class 0x030000
[    0.282815] pci 0000:00:02.0: reg 0x10: [mem 0xfe000000-0xfe3fffff 64bit]
[    0.282820] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.282824] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.282931] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000
[    0.282951] pci 0000:00:19.0: reg 0x10: [mem 0xfe400000-0xfe41ffff]
[    0.282960] pci 0000:00:19.0: reg 0x14: [mem 0xfe428000-0xfe428fff]
[    0.282970] pci 0000:00:19.0: reg 0x18: [io  0xf080-0xf09f]
[    0.283034] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[    0.283076] pci 0000:00:19.0: System wakeup disabled by ACPI
[    0.283121] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
[    0.283143] pci 0000:00:1a.0: reg 0x10: [mem 0xfe427000-0xfe4273ff]
[    0.283230] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.283273] pci 0000:00:1a.0: System wakeup disabled by ACPI
[    0.283317] pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
[    0.283335] pci 0000:00:1b.0: reg 0x10: [mem 0xfe420000-0xfe423fff 64bit]
[    0.283403] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.283494] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[    0.283665] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.283730] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.283782] pci 0000:00:1c.4: [8086:1c18] type 01 class 0x060400
[    0.283957] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.284018] pci 0000:00:1c.4: System wakeup disabled by ACPI
[    0.284077] pci 0000:00:1c.6: [8086:1c1c] type 01 class 0x060400
[    0.284249] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[    0.284310] pci 0000:00:1c.6: System wakeup disabled by ACPI
[    0.284362] pci 0000:00:1c.7: [8086:1c1e] type 01 class 0x060400
[    0.284533] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[    0.284591] pci 0000:00:1c.7: System wakeup disabled by ACPI
[    0.284633] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
[    0.284654] pci 0000:00:1d.0: reg 0x10: [mem 0xfe426000-0xfe4263ff]
[    0.284739] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.284781] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.284824] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.284910] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.284962] pci 0000:00:1f.0: [8086:1c4e] type 00 class 0x060100
[    0.285185] pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601
[    0.285201] pci 0000:00:1f.2: reg 0x10: [io  0xf0d0-0xf0d7]
[    0.285210] pci 0000:00:1f.2: reg 0x14: [io  0xf0c0-0xf0c3]
[    0.285219] pci 0000:00:1f.2: reg 0x18: [io  0xf0b0-0xf0b7]
[    0.285228] pci 0000:00:1f.2: reg 0x1c: [io  0xf0a0-0xf0a3]
[    0.285236] pci 0000:00:1f.2: reg 0x20: [io  0xf060-0xf07f]
[    0.285245] pci 0000:00:1f.2: reg 0x24: [mem 0xfe425000-0xfe4257ff]
[    0.285288] pci 0000:00:1f.2: PME# supported from D3hot
[    0.285362] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[    0.285380] pci 0000:00:1f.3: reg 0x10: [mem 0xfe424000-0xfe4240ff 64bit]
[    0.285401] pci 0000:00:1f.3: reg 0x20: [io  0xf040-0xf05f]
[    0.285571] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.285677] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.285780] pci 0000:00:1c.6: PCI bridge to [bus 03]
[    0.285880] pci 0000:00:1c.7: PCI bridge to [bus 04]
[    0.285971] pci 0000:00:1e.0: PCI bridge to [bus 05] (subtractive decode)
[    0.285981] pci 0000:00:1e.0:   bridge window [io  0x0000-0x03af window] (subtractive decode)
[    0.285982] pci 0000:00:1e.0:   bridge window [io  0x03e0-0x0cf7 window] (subtractive decode)
[    0.285983] pci 0000:00:1e.0:   bridge window [io  0x03b0-0x03df window] (subtractive decode)
[    0.285984] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.285986] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.285987] pci 0000:00:1e.0:   bridge window [mem 0x000c0000-0x000dffff window] (subtractive decode)
[    0.285988] pci 0000:00:1e.0:   bridge window [mem 0xcfa00000-0xffffffff window] (subtractive decode)
[    0.286648] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.286697] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 10 11 12 14 15)
[    0.286752] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.286805] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.286855] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[    0.286906] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0
[    0.286961] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[    0.287013] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[    0.287097] ACPI: Enabled 3 GPEs in block 00 to 3F
[    0.287187] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.287188] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.287191] vgaarb: loaded
[    0.287192] vgaarb: bridge control possible 0000:00:02.0
[    0.287229] Registered efivars operations
[    0.304232] PCI: Using ACPI for IRQ routing
[    0.310396] PCI: pci_cache_line_size set to 64 bytes
[    0.310458] e820: reserve RAM buffer [mem 0xcabdc000-0xcbffffff]
[    0.310460] e820: reserve RAM buffer [mem 0xcb000000-0xcbffffff]
[    0.310462] e820: reserve RAM buffer [mem 0x12e600000-0x12fffffff]
[    0.310601] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.310607] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.312628] clocksource: Switched to clocksource hpet
[    0.320821] VFS: Disk quotas dquot_6.6.0
[    0.320842] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.320925] pnp: PnP ACPI init
[    0.321043] system 00:00: [mem 0xfed10000-0xfed19fff] has been reserved
[    0.321044] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[    0.321046] system 00:00: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.321048] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.321049] system 00:00: [mem 0xfee00000-0xfee0ffff] has been reserved
[    0.321053] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.321162] system 00:01: [io  0x0620-0x063f] has been reserved
[    0.321164] system 00:01: [io  0x0610-0x061f] has been reserved
[    0.321166] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.321210] pnp 00:02: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[    0.321253] pnp 00:03: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[    0.321278] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.321324] system 00:05: [io  0x04d0-0x04d1] has been reserved
[    0.321326] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.321527] pnp 00:06: [dma 0 disabled]
[    0.321546] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.321747] pnp 00:07: Plug and Play ACPI device, IDs IFX0102 PNP0c31 (active)
[    0.321886] system 00:08: [io  0x0400-0x0453] has been reserved
[    0.321887] system 00:08: [io  0x0458-0x047f] has been reserved
[    0.321889] system 00:08: [io  0x1180-0x119f] has been reserved
[    0.321890] system 00:08: [io  0x0500-0x057f] has been reserved
[    0.321892] system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.321894] system 00:08: [mem 0xfec00000-0xfecfffff] could not be reserved
[    0.321895] system 00:08: [mem 0xfed08000-0xfed08fff] has been reserved
[    0.321897] system 00:08: [mem 0xff000000-0xffffffff] has been reserved
[    0.321899] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.321955] system 00:09: [io  0x0454-0x0457] has been reserved
[    0.321958] system 00:09: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.322172] pnp: PnP ACPI: found 10 devices
[    0.328917] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.328995] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.329022] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.329048] pci 0000:00:1c.6: PCI bridge to [bus 03]
[    0.329073] pci 0000:00:1c.7: PCI bridge to [bus 04]
[    0.329096] pci 0000:00:1e.0: PCI bridge to [bus 05]
[    0.329108] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    0.329109] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.329110] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    0.329111] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.329113] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.329114] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.329115] pci_bus 0000:00: resource 10 [mem 0xcfa00000-0xffffffff window]
[    0.329117] pci_bus 0000:05: resource 4 [io  0x0000-0x03af window]
[    0.329118] pci_bus 0000:05: resource 5 [io  0x03e0-0x0cf7 window]
[    0.329119] pci_bus 0000:05: resource 6 [io  0x03b0-0x03df window]
[    0.329120] pci_bus 0000:05: resource 7 [io  0x0d00-0xffff window]
[    0.329121] pci_bus 0000:05: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.329122] pci_bus 0000:05: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.329124] pci_bus 0000:05: resource 10 [mem 0xcfa00000-0xffffffff window]
[    0.329189] NET: Registered protocol family 2
[    0.329339] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.329507] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes)
[    0.329792] TCP: Hash tables configured (established 32768 bind 32768)
[    0.329829] UDP hash table entries: 2048 (order: 6, 262144 bytes)
[    0.329894] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
[    0.329978] NET: Registered protocol family 1
[    0.329993] pci 0000:00:02.0: BIOS left Intel GPU interrupts enabled; disabling
[    0.329998] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.592789] PCI: CLS 64 bytes, default 64
[    0.592845] Unpacking initramfs...
[    1.082346] Freeing initrd memory: 34888K
[    1.082386] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.082388] software IO TLB [mem 0xc6bdc000-0xcabdc000] (64MB) mapped at [ffff8ff686bdc000-ffff8ff68abdbfff]
[    1.082722] audit: initializing netlink subsys (disabled)
[    1.082736] audit: type=2000 audit(1560908945.076:1): initialized
[    1.083148] workingset: timestamp_bits=40 max_order=20 bucket_order=0
[    1.084732] zbud: loaded
[    1.085679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.085712] io scheduler noop registered
[    1.085713] io scheduler deadline registered
[    1.085739] io scheduler cfq registered (default)
[    1.086840] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt
[    1.086846] pcie_pme 0000:00:1c.0:pcie001: service driver pcie_pme loaded
[    1.086901] pcieport 0000:00:1c.4: Signaling PME through PCIe PME interrupt
[    1.086909] pcie_pme 0000:00:1c.4:pcie001: service driver pcie_pme loaded
[    1.086964] pcieport 0000:00:1c.6: Signaling PME through PCIe PME interrupt
[    1.086970] pcie_pme 0000:00:1c.6:pcie001: service driver pcie_pme loaded
[    1.087021] pcieport 0000:00:1c.7: Signaling PME through PCIe PME interrupt
[    1.087029] pcie_pme 0000:00:1c.7:pcie001: service driver pcie_pme loaded
[    1.087040] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.087047] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.087057] efifb: probing for efifb
[    1.087067] efifb: framebuffer at 0xd0000000, using 1920k, total 1920k
[    1.087068] efifb: mode is 800x600x32, linelength=3200, pages=1
[    1.087068] efifb: scrolling: redraw
[    1.087070] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.088010] Console: switching to colour frame buffer device 100x37
[    1.088874] fb0: EFI VGA frame buffer device
[    1.088880] intel_idle: MWAIT substates: 0x1120
[    1.088881] intel_idle: v0.4.1 model 0x2A
[    1.089006] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.089373] GHES: HEST is not enabled!
[    1.089421] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.110664] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    1.111166] Linux agpgart interface v0.103
[    1.140801] tpm_tis 00:07: 1.2 TPM (device-id 0xB, rev-id 16)
[    1.412819] tpm tpm0: A TPM error (7) occurred attempting to read a pcr value
[    1.412847] tpm tpm0: TPM is disabled/deactivated (0x7)
[    1.413043] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.413045] AMD IOMMUv2 functionality not available on this system
[    1.413452] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[    1.417149] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.417188] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.417383] mousedev: PS/2 mouse device common for all mice
[    1.417436] rtc_cmos 00:04: RTC can wake from S4
[    1.417696] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[    1.417843] rtc_cmos 00:04: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    1.417854] intel_pstate: Intel P-state driver initializing
[    1.418944] NET: Registered protocol family 10
[    1.419352] mip6: Mobile IPv6
[    1.419355] NET: Registered protocol family 17
[    1.419358] mpls_gso: MPLS GSO support
[    1.419725] microcode: sig=0x206a7, pf=0x2, revision=0x1b
[    1.419862] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.420161] registered taskstats version 1
[    1.420195] zswap: loaded using pool lzo/zbud
[    1.448827] tpm tpm0: A TPM error (7) occurred attempting to read a pcr value
[    1.448874] ima: No TPM chip found, activating TPM-bypass!
[    1.448877] ima: Allocated hash algorithm: sha256
[    1.449431] rtc_cmos 00:04: setting system clock to 2019-06-19 01:49:05 UTC (1560908945)
[    1.449554] PM: Hibernation image not present or could not be loaded.
[    1.451156] Freeing unused kernel memory: 1680K
[    1.451158] Write protecting the kernel read-only data: 12288k
[    1.452243] Freeing unused kernel memory: 1788K
[    1.456301] Freeing unused kernel memory: 1188K
[    1.464386] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.538048] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.538171] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.538186] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.570890] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[    1.570895] ACPI: Power Button [PWRB]
[    1.578338] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    1.578341] ACPI: Power Button [PWRF]
[    1.600629] pps_core: LinuxPPS API ver. 1 registered
[    1.600636] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.606353] [drm] Initialized
[    1.608525] PTP clock support registered
[    1.613238] ACPI: bus type USB registered
[    1.614011] SCSI subsystem initialized
[    1.615885] usbcore: registered new interface driver usbfs
[    1.617032] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.617033] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.617505] usbcore: registered new interface driver hub
[    1.618581] usbcore: registered new device driver usb
[    1.618876] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    1.625196] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.625748] libata version 3.00 loaded.
[    1.629922] ehci-pci: EHCI PCI platform driver
[    1.632834] wmi: Mapper loaded
[    1.645718] AVX version of gcm_enc/dec engaged.
[    1.645719] AES CTR mode by8 optimization enabled
[    1.763243] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
[    1.891780] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) e8:39:35:37:ad:9d
[    1.891782] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    1.891831] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: 0100FF-0FF
[    1.891907] i801_smbus 0000:00:1f.3: enabling device (0101 -> 0103)
[    1.892147] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    1.893306] e1000e 0000:00:19.0 eno1: renamed from eth0
[    1.893594] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    1.893601] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    1.893617] ehci-pci 0000:00:1a.0: debug port 2
[    1.897528] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    1.897609] ehci-pci 0000:00:1a.0: irq 16, io mem 0xfe427000
[    1.912726] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    1.912822] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.912824] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.912825] usb usb1: Product: EHCI Host Controller
[    1.912827] usb usb1: Manufacturer: Linux 4.9.0-7-rt-amd64 ehci_hcd
[    1.912828] usb usb1: SerialNumber: 0000:00:1a.0
[    1.913101] hub 1-0:1.0: USB hub found
[    1.913110] hub 1-0:1.0: 2 ports detected
[    1.913318] ahci 0000:00:1f.2: version 3.0
[    1.923652] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x17 impl SATA mode
[    1.923656] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems sxs apst
[    1.958256] scsi host0: ahci
[    1.958732] scsi host1: ahci
[    1.959042] scsi host2: ahci
[    1.959287] scsi host3: ahci
[    1.959661] scsi host4: ahci
[    1.960080] scsi host5: ahci
[    1.960183] ata1: SATA max UDMA/133 abar m2048@0xfe425000 port 0xfe425100 irq 31
[    1.960188] ata2: SATA max UDMA/133 abar m2048@0xfe425000 port 0xfe425180 irq 31
[    1.960192] ata3: SATA max UDMA/133 abar m2048@0xfe425000 port 0xfe425200 irq 31
[    1.960193] ata4: DUMMY
[    1.960198] ata5: SATA max UDMA/133 abar m2048@0xfe425000 port 0xfe425300 irq 31
[    1.960199] ata6: DUMMY
[    1.960814] [drm] Memory usable by graphics device = 2048M
[    1.960817] checking generic (d0000000 1e0000) vs hw (d0000000 10000000)
[    1.960819] fb: switching to inteldrmfb from EFI VGA
[    1.960844] Console: switching to colour dummy device 80x25
[    1.960924] [drm] Replacing VGA console driver
[    1.961111] i801_smbus 0000:00:1f.3: BIOS is accessing SMBus registers
[    1.961113] i801_smbus 0000:00:1f.3: Driver SMBus register access inhibited
[    1.966785] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.966787] [drm] Driver supports precise vblank timestamp query.
[    1.999356] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    2.005387] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[    2.005626] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    2.005633] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    2.005655] ehci-pci 0000:00:1d.0: debug port 2
[    2.009589] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    2.009770] ehci-pci 0000:00:1d.0: irq 23, io mem 0xfe426000
[    2.024694] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    2.024758] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.024760] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.024762] usb usb2: Product: EHCI Host Controller
[    2.024775] usb usb2: Manufacturer: Linux 4.9.0-7-rt-amd64 ehci_hcd
[    2.024776] usb usb2: SerialNumber: 0000:00:1d.0
[    2.025096] hub 2-0:1.0: USB hub found
[    2.025118] hub 2-0:1.0: 2 ports detected
[    2.032910] fbcon: inteldrmfb (fb0) is primary device
[    2.084727] tsc: Refined TSC clocksource calibration: 3092.975 MHz
[    2.084745] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2c955bbc01b, max_idle_ns: 440795312352 ns
[    2.108970] Console: switching to colour frame buffer device 240x67
[    2.132227] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    2.240691] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    2.276323] ata5: SATA link down (SStatus 0 SControl 300)
[    2.276410] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.276489] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.276573] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.276864] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    2.277185] ata1.00: ATA-10: Patriot Torch, S9FM02.9, max UDMA/133
[    2.277189] ata1.00: 117231408 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    2.277367] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    2.277646] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    2.277942] ata1.00: configured for UDMA/133
[    2.278426] scsi 0:0:0:0: Direct-Access     ATA      Patriot Torch    02.9 PQ: 0 ANSI: 5
[    2.278905] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    2.278909] ata3.00: ATAPI: hp      DVD A  DH16ACSH, JHD5, max UDMA/100
[    2.279887] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    2.279891] ata3.00: configured for UDMA/100
[    2.287363] ata2.00: ATA-7: Hitachi HDS721680PLA380, P21OAB6A, max UDMA/100
[    2.287366] ata2.00: 156301488 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    2.288357] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    2.288584] ata2.00: configured for UDMA/100
[    2.333650] scsi 1:0:0:0: Direct-Access     ATA      Hitachi HDS72168 AB6A PQ: 0 ANSI: 5
[    2.352743] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    2.389096] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[    2.389100] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.389538] hub 1-1:1.0: USB hub found
[    2.389708] hub 1-1:1.0: 6 ports detected
[    2.400705] scsi 2:0:0:0: CD-ROM            hp       DVD A  DH16ACSH  JHD5 PQ: 0 ANSI: 5
[    2.431424] sd 0:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.9 GiB)
[    2.431600] sd 0:0:0:0: [sda] Write Protect is off
[    2.431603] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.431657] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.433206] sd 1:0:0:0: [sdb] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[    2.433315] sd 1:0:0:0: [sdb] Write Protect is off
[    2.433318] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.433358] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.435344]  sda: sda1 sda2
[    2.436269] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.447667] sr 2:0:0:0: [sr0] scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.447668] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.447853] sr 2:0:0:0: Attached scsi CD-ROM sr0
[    2.462175]  sdb: sdb1
[    2.462892] sd 1:0:0:0: [sdb] Attached SCSI disk
[    2.501091] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[    2.501094] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.501471] hub 2-1:1.0: USB hub found
[    2.501539] hub 2-1:1.0: 8 ports detected
[    2.606346] random: fast init done
[    2.680716] usb 1-1.1: new high-speed USB device number 3 using ehci-pci
[    2.726470] device-mapper: uevent: version 1.0.3
[    2.726634] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.788710] usb 2-1.5: new low-speed USB device number 3 using ehci-pci
[    2.799733] usb 1-1.1: New USB device found, idVendor=2001, idProduct=4a00
[    2.799736] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.799738] usb 1-1.1: Product: D-Link DUB-1312
[    2.799739] usb 1-1.1: Manufacturer: D-Link Elec. Corp.
[    2.799741] usb 1-1.1: SerialNumber: 000000000016AD
[    2.901483] usb 2-1.5: New USB device found, idVendor=045e, idProduct=00cb
[    2.901486] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.901488] usb 2-1.5: Product: Microsoft USB Optical Mouse
[    2.901490] usb 2-1.5: Manufacturer: PixArt
[    2.904571] hidraw: raw HID events driver (C) Jiri Kosina
[    2.907213] usbcore: registered new interface driver usbhid
[    2.907214] usbhid: USB HID core driver
[    2.908085] input: PixArt Microsoft USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:045E:00CB.0001/input/input5
[    2.908185] hid-generic 0003:045E:00CB.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Microsoft USB Optical Mouse] on usb-0000:00:1d.0-1.5/input0
[    2.940679] raid6: sse2x1   gen()  5836 MB/s
[    2.980685] usb 2-1.8: new low-speed USB device number 4 using ehci-pci
[    3.008679] raid6: sse2x1   xor()  5803 MB/s
[    3.076696] raid6: sse2x2   gen() 10842 MB/s
[    3.098865] usb 2-1.8: New USB device found, idVendor=1a2c, idProduct=2124
[    3.098868] usb 2-1.8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.098870] usb 2-1.8: Product: USB Keyboard
[    3.098872] usb 2-1.8: Manufacturer: SEM
[    3.102055] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.0/0003:1A2C:2124.0002/input/input6
[    3.144697] raid6: sse2x2   xor()  4742 MB/s
[    3.212673] raid6: sse2x4   gen() 10685 MB/s
[    3.212678] clocksource: Switched to clocksource tsc
[    3.212844] hid-generic 0003:1A2C:2124.0002: input,hidraw1: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-0000:00:1d.0-1.8/input0
[    3.216180] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.1/0003:1A2C:2124.0003/input/input7
[    3.272789] hid-generic 0003:1A2C:2124.0003: input,hidraw2: USB HID v1.10 Device [SEM USB Keyboard] on usb-0000:00:1d.0-1.8/input1
[    3.280665] raid6: sse2x4   xor()  9491 MB/s
[    3.280666] raid6: using algorithm sse2x2 gen() 10842 MB/s
[    3.280667] raid6: .... xor() 4742 MB/s, rmw enabled
[    3.280668] raid6: using ssse3x2 recovery algorithm
[    3.281063] xor: automatically using best checksumming function   avx
[    3.286203] Btrfs loaded, crc32c=crc32c-intel
[    3.442236] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[    3.563003] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.597446] efivars: duplicate variable: SlotPresent-ec87d643-eba4-4bb5-a1e5-3f3e36b20da9
[    3.601669] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    3.601844] systemd[1]: Detected architecture x86-64.
[    3.602002] systemd[1]: Set hostname to <plasma>.
[    3.668387] systemd[1]: Listening on Syslog Socket.
[    3.668477] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    3.668523] systemd[1]: Listening on Journal Socket.
[    3.668580] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.668756] systemd[1]: Created slice User and Session Slice.
[    3.668770] systemd[1]: Reached target Swap.
[    3.668809] systemd[1]: Listening on LVM2 metadata daemon socket.
[    3.684425] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[    3.691066] lp: driver loaded but no devices found
[    3.696722] ppdev: user-space parallel port driver
[    3.720963] Key type encrypted registered
[    3.831255] systemd-journald[312]: Received request to flush runtime journal from PID 1
[    3.957779] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    3.994528] snd_hda_intel 0000:00:1b.0: enabling device (0100 -> 0102)
[    4.040781] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    4.041300] EFI Variables Facility v0.08 2004-May-17
[    4.042528] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    4.044508] sr 2:0:0:0: Attached scsi generic sg2 type 5
[    4.047071] input: PC Speaker as /devices/platform/pcspkr/input/input8
[    4.052785] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC662 rev1: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    4.052787] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=1 (0x15/0x0/0x0/0x0/0x0)
[    4.052788] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    4.052790] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    4.052791] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    4.052792] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[    4.052793] snd_hda_codec_realtek hdaudioC0D0:      Line=0x18
[    4.084040] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    4.115300] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    4.120317] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[    4.120318] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[    4.120319] RAPL PMU: hw unit of domain package 2^-16 Joules
[    4.120319] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[    4.120862] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    4.125833] efivars: duplicate variable: SlotPresent-ec87d643-eba4-4bb5-a1e5-3f3e36b20da9
[    4.126414] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    4.129369] pstore: using zlib compression
[    4.129379] pstore: Registered efi as persistent store backend
[    4.129940] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    4.133631] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[    4.230597] intel_rapl: Found RAPL domain package
[    4.230599] intel_rapl: Found RAPL domain core
[    4.230600] intel_rapl: Found RAPL domain uncore
[    4.230605] intel_rapl: RAPL package 0 domain package locked by BIOS
[    4.231184] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    4.271090] iTCO_vendor_support: vendor-support=0
[    4.286774] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    4.287020] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[    4.290228] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    4.610002] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: errors=remount-ro
[    4.628942] input: HP WMI hotkeys as /devices/virtual/input/input14
[    4.796185] ax88179_178a 1-1.1:1.0 eth0: register 'ax88179_178a' at usb-0000:00:1a.0-1.1, D-Link DUB-1312 USB 3.0 to Gigabit Ethernet Adapter, 18:0f:76:01:24:ea
[    4.796215] usbcore: registered new interface driver ax88179_178a
[    4.800258] ax88179_178a 1-1.1:1.0 enx180f760124ea: renamed from eth0
[    4.839369] random: crng init done
[    4.839372] random: 7 urandom warning(s) missed due to ratelimiting
[    5.153087] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[    5.382769] input: BRLTTY 5.4 Linux Screen Driver Keyboard as /devices/virtual/input/input15
[    5.386828] IPv6: ADDRCONF(NETDEV_UP): enx180f760124ea: link is not ready
[    5.722888] IPv6: ADDRCONF(NETDEV_UP): enx180f760124ea: link is not ready
[    6.682668] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[    6.682672] e1000e 0000:00:19.0 eno1: 10/100 speed: disabling TSO
[    6.682713] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[    6.860620] fuse init (API version 7.26)
[    8.811698] ax88179_178a 1-1.1:1.0 enx180f760124ea: ax88179 - Link status is: 1
[    8.819052] IPv6: ADDRCONF(NETDEV_CHANGE): enx180f760124ea: link becomes ready
Info report created by linuxcnc_info:
The file:    /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
     http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
                Date: Wed 19 Jun 11:49:22 AEST 2019
            UTC Date: Wed 19 Jun 01:49:22 UTC 2019
        this program: /home/plasma/plasmac/scripts/linuxcnc_info
              uptime: 11:49:22 up 0 min, 1 user, load average: 1.37, 0.32, 0.11
     lsb_release -sa: LinuxMint LMDE 3 Cindy 3 cindy
      which linuxcnc: /home/plasma/plasmac/scripts/linuxcnc
                 pwd: /home/plasma/linuxcnc/configs/SWS_Plasma
                USER: plasma
             LOGNAME: plasma
                HOME: /home/plasma
              EDITOR:
              VISUAL:
            LANGUAGE:
                TERM: dumb
           COLORTERM:
             DISPLAY: :0
             DESKTOP: cinnamon
        display size: 1920x1080 pixels (508x285 millimeters)
                PATH: /home/plasma/plasmac/bin:/home/plasma/linuxcnc/configs/SWS_Plasma/bin:/home/plasma/plasmac/scripts:/home/plasma/plasmac/bin:/home/plasma/plasmac/bin:/home/plasma/plasmac/scripts:/home/plasma/plasmac/tcl:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/usr/local/sbin:/usr/sbin:/sbin
uname items:
         nodename -n: plasma
      kernel-name -s: Linux
      kernel-vers -v: #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u2 (2018-08-13)
          machine -m: x86_64
        processor -p: unknown
         platform -i: unknown
      oper system -o: GNU/Linux
/proc items:
             cmdline: BOOT_IMAGE=/boot/vmlinuz-4.9.0-7-rt-amd64 root=UUID=de4746eb-d690-4a1e-af7b-1ffe032038bf ro quiet splash
          model name: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
               cores: 4
             cpu MHz: 1897.766
             parport:
              serial: 0000-0000 : serial
Versions:
                 gcc: gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
              python: Python 2.7.13
                 git: git version 2.11.0
          git commit: 520a30d94
                 tcl: 8.6
                  tk: 8.6
               glade: not_in_PATH
          glade-gtk2: not_in_PATH
linuxcnc_var all:
     LINUXCNCVERSION: 2.9.0~pre0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
            REALTIME: /home/plasma/plasmac/scripts/realtime
                 RTS: uspace
          HALLIB_DIR: /home/plasma/plasmac/lib/hallib
dpkg -l '*linuxcnc*':
dpkg-query: no packages found matching *linuxcnc*
Any Idea on what is causing the problem?
Last edit: 20 Jun 2019 00:57 by andypugh.
19 Jun 2019 07:10 - 19 Jun 2019 07:11 #137271 by pl7i92
why dident you go with the standard mint 19.1 and mate as it is recommended
linuxcnc
you need to get the latest from here
buildbot.linuxcnc.org/
use the master stretch
Last edit: 19 Jun 2019 07:11 by pl7i92.
19 Jun 2019 08:52 - 19 Jun 2019 08:52 #137272 by rodw
In your errors, this is likely what caused it
Can you run a SIM without error?
You need to share your hal and ini files but it seems line 128 of your hal file is where to start looking.
Last edit: 19 Jun 2019 08:52 by rodw.
  • thefabricator03
  • Visitor
  • Visitor
19 Jun 2019 11:25 #137280 by thefabricator03
Replied by thefabricator03 on topic Cannot get Linuxcnc to run Mint LMDE 3 Cindy
Rod,
Yes I can run the Plasmac sims fine,
Please see attached for the hal and ini.
19 Jun 2019 13:02 - 19 Jun 2019 13:03 #137285 by rodw
IN your HAL, Try changing
loadrt pid names=pid.x,pid.y,pid.z,pid.s
to
loadrt pid names=pid.x,pid.y,pid.y1,pid.z,pid.s
For some reason you are missing a pid setting.for y1
EDIT: All I did was look at line 128 and then have a think about what was going on.
Last edit: 19 Jun 2019 13:03 by rodw.
20 Jun 2019 00:58 #137325 by andypugh
Replied by andypugh on topic Cannot get Linuxcnc to run Mint LMDE 3 Cindy
Yes this looks like a simple HAL error.
20 Jun 2019 01:07 #137328 by rodw
But the real question is it a user error or is Pncconf doing the wrong thing?
I still think pncconf and possibly stepconf are doing this the wrong way for independent joints. There should be no mention of axes in the config. It all should be joints and the only thing about axes should be in the ini file.
coordinates=XYYZ
I'm sure this will be a source of confusion as 2.8 goes mainstream
eg the hal should be more like
loadrt pid names=pid.0,pid.1,pid.2,pid.3 pid.s
You could achieve this by allowing a string to enter the Coordinates value eg XYYZ in this instance. I don't think the devs really want to tackle it as its a lot of work.....
20 Jun 2019 01:32 #137333 by bevins
pncconf knows about two motors on one axis? I dont think it does it right.
I would do a pncconf with three axis machine then modify configs for the gantry.
20 Jun 2019 01:35 - 20 Jun 2019 01:44 #137334 by AgentWD40
Replied by AgentWD40 on topic Cannot get Linuxcnc to run Mint LMDE 3 Cindy
My setup is a xyyzz configuration. I have been setting up my motors in pncconf in the IO Connector 1 tab like so Axis > Main Axis > x y or z axis stepgen and then set up the second motor for a 2 motor axis like Axis > Tandem Axis > y or z stepgen. I must have used pncconf this way over a dozen times these last few weeks in my testing and I've never had an issue here.
Playing with pncconf just now I see that when you setup two motors as main axis > y for example it will not generate a pid.y2 or any of the other y2 hal settings. But if you use the tandem axis option it will creates those hal configs. (and they work)
So thefabricator03, did you select a main y with a tandem y or two main y's?
[edit]
FWIW that would make more sense to me too
Last edit: 20 Jun 2019 01:44 by AgentWD40.
  • thefabricator03
  • Visitor
  • Visitor
20 Jun 2019 02:18 #137335 by thefabricator03
Thanks for the help guys,
What Rod suggested was correct except I had a few more errors as well to do with setting up the duel Y axis. I modified the HAL and now it starts.
Time to create page: 0.361 seconds
