Cannot get Linuxcnc to run Mint LMDE 3 Cindy
- thefabricator03
- Visitor
20 Jun 2019 02:24 #137336
by thefabricator03
I selected one Y main and modified the HAL as per the thread linked in the readme file of Plasmac.
Replied by thefabricator03 on topic Cannot get Linuxcnc to run Mint LMDE 3 Cindy
So thefabricator03, did you select a main y with a tandem y or two main y's?
- Thank you received: 4151
20 Jun 2019 02:31 #137337
I did publish an example here of a hal file done this way. 18 months ago....
forum.linuxcnc.org/47-hal-examples/34072...ranch-gantry-example
Now the multi spindle means the example needs a tweak to the spindle config. It only needs one line changed.
Replied by rodw on topic Cannot get Linuxcnc to run Mint LMDE 3 Cindy
FWIW that would make more sense to me tooeg the hal should be more like
loadrt pid names=pid.0,pid.1,pid.2,pid.3 pid.s
- AgentWD40
- Thank you received: 96
20 Jun 2019 02:45 #137338
by AgentWD40
Ah, I went and had a look at that. It looks like it's from 2 yrs ago so maybe they've updated pncconf to better handle this since then. For future reference in my experience using pncconf to setup a main y and a tandem y should get you jogging motors right out of the gate.
Replied by AgentWD40 on topic Cannot get Linuxcnc to run Mint LMDE 3 Cindy
20 Jun 2019 03:30 #137340
I think it must have been user error as I tested pncconf's 7i76e support for Chris Morley aboujt when I made that other post in Feb last year. Which is why I did up that example in the first place.
- pl7i92
- Thank you received: 358
20 Jun 2019 07:15 #137350
by pl7i92
Replied by pl7i92 on topic Cannot get Linuxcnc to run Mint LMDE 3 Cindy
the older docs are realy a problem now
and as i did yesterday a conversion of a 4th axis to 2.9 stretch i did struggel even with 8month of near dayly hal ini work
there shoudt be a advice
that the translater 2.7 to 2.9 needts to be run more then once
so if it errors on the first startup
start again
and again
and for me again
the 4th startup did a real good and stable configuration
as it added lines on every start
coudt not beleve the vfd did change 3 times
start again
and again
and for me again
20 Jun 2019 10:23 #137359
It shouldn't.
Can you zip and attach the unmodified config which caused the problem? I will try to make it work.
Note that the update_ini script was itself updated last night, and should now work better for tandem axes and missing axes (eg lathes)
Replied by andypugh on topic Cannot get Linuxcnc to run Mint LMDE 3 Cindy
It shouldn't.
Time to create page: 0.302 seconds
