reboot and select proper boot device
- Thank you received: 7490
09 Jul 2019 21:34 #138971
Replied by tommylight on topic reboot and select proper boot device
Is that new mobo made by Asus or Asrock by any chance ?
Asus makes some nice mobos, but it has by far the worst boot implementation of them all, and not remembering to boot from an USB is utterly disappointing and aggravating.
Now I have to ask, did you by any chance put that drive on a computer that also had a windoze drive in it and boot windows ?
All windows versions have a tendency to fix things that are not broken but they don't understand, usually prompting that the drive is not formated and offering to format it by a single click, sometimes even during boot procces they will write data to drives at a whim that there is something missing for the boot operation.
On older systems you might also check the bios and set the hard drives to auto detection.
There is always the possibility of restoring the drive after such mishaps by using a linux computer and testdisk, except formating that will be very hard to impposible to restore.
Another thing to check is can you hear the drive spinning up when powered on, and the heads being released from park and moving to the platers. Those are very distinct sounds and can be easily heard in a quiet room.
- johns00056
09 Jul 2019 22:23 #138972
by johns00056
Replied by johns00056 on topic reboot and select proper boot device
The new motherboard is an Asrock.
Most of my spare computers are windows. It is quite possible that I did what you said.
I don't remember every combination that I tried.
- BigJohnT
- Thank you received: 994
09 Jul 2019 22:45 #138974
by BigJohnT
Replied by BigJohnT on topic reboot and select proper boot device
John,
Send the drive back to me and I'll either reload it with LinuxCNC or replace it.
JT
JT
- johns00056
09 Jul 2019 22:52 #138975
by johns00056
Thanks a lot, I will send it back.
I am sure that it is my fault and I messed it up somehow.
- BigJohnT
09 Jul 2019 22:56 #138976
by BigJohnT
No problem, we'll get you up and running.
Which Asrock motherboard do you have?
JT
JT
- johns00056
09 Jul 2019 23:45 #138979
by johns00056
It is an Asrock H97M Pro4. Intel pentium G3258 LGA1150 processor.
Someone on this forum recommended it about 4 years ago and it has been sitting, new. in the box and unused, for that time. (I replaced the battery)
I am not opposed to buying a different one.
09 Jul 2019 23:55 #138980
Not sure, but I think I have 2 of those with celeron processors , one of them is running a bit industrial Esab plasma cutter for quite some time now using a 6i25 and a 7i77, and the other is happily mining ethereum with two Nvidia 1060 6GB cards for over 4 months now. Will check tomorrow.
- BigJohnT
10 Jul 2019 00:05 #138981
by BigJohnT
I'm sure I have a H97M Pro4 somewhere as well, it should just boot up... I know I've seen the box but which machine is it in lol.
JT
JT
- BigJohnT
16 Jul 2019 22:50 #139633
by BigJohnT
Your hard drive was here when I returned home from a short vacation and sure enough it won't boot up. Well stranger than that my master hard drive won't boot up either for Debian 9 64bit so now I'm wondering if my new disk copy device has messed them both up??? In any case I'll make sure you have a drive that boots up and get that back to you ASAP.
JT
JT
- Grotius
- Thank you received: 2349
16 Jul 2019 22:59 #139635
by Grotius
Replied by Grotius on topic reboot and select proper boot device
JT,
Do you use clonezilla? Then you don't need a device to copy it.
Time to create page: 0.121 seconds
