Installing Wheezy on OSX
- tymcat
14 Sep 2019 14:27 #145133
by tymcat
Installing Wheezy on OSX was created by tymcat
I try to install LinuxCNC via Virtualbox under OS X Mojave on my Macbook Pro.
I downloaded the linuxcnc-2.7.14-wheezy.iso, checked the SHA256 value. I downloaded it several times, last time someone did it for me via zsync, so it should be right.
When trying to mount, I get a "keine aktivierbaren Dateisysteme" - "no accessible file systems". I cannot open it and burning it via balenaEtcher results in a non readable USB stick.
Any idea?
Any idea?
- pl7i92
- Thank you received: 358
14 Sep 2019 17:04 #145148
by pl7i92
Replied by pl7i92 on topic Installing Wheezy on OSX
Linuxcnc is a REALTIME OS so it will nor run under VirtualBOX invirerment
you realy need to get a STANDalone Main Real System if you want to drive a ,mashine
it can bi installed as a simulation only
see the wikipedia on this
- tymcat
14 Sep 2019 17:21 #145154
by tymcat
Replied by tymcat on topic Installing Wheezy on OSX
LinuxCNC doesn't appear under www.realtimelinuxfoundation.org/
and I don't grasp what this has to do with being able to install or not.
It doesn't matter if I install it straight on the Mac, via Parallels or Virtual Machine - reaction time will differ, so what.
I need it for CAM: G-code production and simulation, not for running a CNC mill.
But I am happy to get any hint how to circumnavigate the expensive gap between CAD and the CNC mill. The least costly extension I found so far is MeshCAM, but still it is a bold investment for a few hobby related projects.
- Clive S
- Thank you received: 486
14 Sep 2019 17:31 #145156
by Clive S
Replied by Clive S on topic Installing Wheezy on OSX
Fusion360 is free for hobby use it will do cad and cam
The following user(s) said Thank You: tymcat
- tymcat
14 Sep 2019 17:40 #145159
by tymcat
but still I wonder why someone made this huge effort to create a Mac version which cannot be mounted nor installed ... :-/
- Thank you received: 4151
14 Sep 2019 22:14 #145181
Replied by rodw on topic Installing Wheezy on OSX
Not sure if this helps you on a mac but I found the only reliable way to create a bootable USB was to use win32diskimager
- Thank you received: 7490
14 Sep 2019 23:38 #145187
Replied by tommylight on topic Installing Wheezy on OSX
I use DD on Linux and it always works.
It is normal that you can not read the USB with the Wheezy image on it, but it will boot and work.
- phillc54
- Thank you received: 2100
15 Sep 2019 01:59 - 15 Sep 2019 02:19 #145195
by phillc54
Replied by phillc54 on topic Installing Wheezy on OSX
I have installed the LinuxCNC Wheezy ISO and the LinuxCNC Stretch ISO as VirtualBox guests and VMware guests on my Macs without any problems.
Edit: I just downloaded the Wheezy ISO and created a new guest with the wheezy ISO image directly attached to the guests cdrom and it works flawlessly. This is with VirtualBox Version 6.0.12 r133076 on Mojave Version 10.14.6
Last edit: 15 Sep 2019 02:19 by phillc54.
- tymcat
15 Sep 2019 08:05 #145213
by tymcat
I cannot choose it during startup, hence I cannot boot into Linux.
- tymcat
15 Sep 2019 08:07 #145214
by tymcat
I'd have to first install a WIN version. Probably not the intention of the creator(s) of LinuxCNC
Time to create page: 0.156 seconds
