Installing Wheezy on OSX
- phillc54
- Thank you received: 2100
15 Sep 2019 08:15 #145215
by phillc54
Replied by phillc54 on topic Installing Wheezy on OSX
- tymcat
15 Sep 2019 08:43 - 15 Sep 2019 08:45 #145218
by tymcat
Replied by tymcat on topic Installing Wheezy on OSX
If only I knew the difference between our configurations, mine is identical afaics...
MBP 10.1 Retina, 2,6GHz, Mojave 10.14.6, VB 6.0.12 r133076, 16GB RAM
- so you can open the ISO somehow? Burn it?
As a last resort I consider to reinstall OSX. I wanted to boot from OSX from USB, but there is no Finder, just the installation app.
I know I am taking the long way, but I want it to work and make sure everybody can repeat it.
I found a hint in a forum request from 2010 that a fresh installation of OSX solved the same problem for someone, still under Leopard.
Getting me closest to my goal seems the Terminal approach, just that I do not know the fitting Unix commands to separately mount the main partition without the boot section.
See: discussions.apple.com/thread/7290705?ans...19723022#30019723022
Under the following link is explained how to use DD - but I am NOT comfortable with the command line and already managed to shrink the linuxcnc.iso to 468kb xD - which was little damage as I simply downloaded it again.
osxdaily.com/2015/06/05/copy-iso-to-usb-drive-mac-os-x-command/
Last edit: 15 Sep 2019 08:45 by tymcat.
- phillc54
15 Sep 2019 08:47 - 15 Sep 2019 08:48 #145219
by phillc54
If you create a linux machine, after it is created you can access settings for the machine.
You don't need to burn the ISO, use the file downloaded from the LinuxCNC site.
You cannot install directly to macos, just a virtualbox guest.
Last edit: 15 Sep 2019 08:48 by phillc54.
Time to create page: 0.105 seconds
