LinuxCNC on Linux Mint 19.2
- Thank you received: 4151
21 Oct 2019 21:04 #148491
That looks like the PDF is being opened with a program called see (/usr/bin/see) rather than allowing it to be opened with the default application. I don't know that command. I wonder if man see or see --help or see /h will give more info? Sounds like there is a config file somewhere to point a file type to the right application
Replied by rodw on topic LinuxCNC on Linux Mint 19.2
Thanks for the comments, and the solution.
In the Linux Mint menu, the LinuxCNC documents are called like:
/usr/bin/see /usr/share/doc/linuxcnc/LinuxCNC_integrator.pdf
But in Linux Mint, 'see' does not follow the default setting for *.pdf
and opens gimp ('see' has its own defaults). So setting the default did not help.
Replacing this with
/usr/bin/xreader /usr/share/doc/linuxcnc/LinuxCNC_integrator.pdf
solved the problem.
