Auto login
  • macsddau
  • macsddau's Avatar Topic Author
  • Junior Member
  • Junior Member
11 Oct 2019 10:33 - 13 Oct 2019 08:52 #147689 by macsddau
SOLVED : Auto login was created by macsddau
I have made LinuxCNC to start at login and now I want to login automatically to my user account at PC startup.
I haven't seen tool in the menu to do that.
How to make it possible ?
Last edit: 13 Oct 2019 08:52 by macsddau.
11 Oct 2019 11:28 - 11 Oct 2019 11:31 #147691 by Clive S
Replied by Clive S on topic Auto login
You will need to edit the lightdm.conf file
sudo nano /etc/lightdm/lightdm.conf
nano being a test editor
find the line with autologin-user and uncomment it
then change autologin-user = to your username
Last edit: 11 Oct 2019 11:31 by Clive S.
The following user(s) said Thank You: macsddau
  • macsddau
  • Junior Member
  • Junior Member
11 Oct 2019 11:40 #147692 by macsddau
Replied by macsddau on topic Auto login
It don’t works.
11 Oct 2019 11:56 #147693 by Clive S
It don’t works.
What flavour of linuxcnc are you using
What dose not work. Did you save the file
  • macsddau
  • Junior Member
  • Junior Member
11 Oct 2019 12:00 #147694 by macsddau
LinuxCNC 2.7.14
Yes
11 Oct 2019 12:04 #147695 by Clive S
LinuxCNC 2.7.14
Yes
I have just tried it and it works for me
When saving you have to press exit then Y to save
  • Moderator
  • Moderator
11 Oct 2019 12:39 #147697 by tommylight
Replied by tommylight on topic Auto login
The above has to be changed somewhere below the "seat".
Long time, just recall that it has to be there.
11 Oct 2019 13:03 #147700 by Clive S
Yes Tommy for the avoidance of doubt:
  • Moderator
  • Moderator
11 Oct 2019 14:39 #147704 by tommylight
Yup, that should do it. Also the delay has to be active, set to 0.
  • macsddau
  • Junior Member
  • Junior Member
13 Oct 2019 06:21 #147793 by macsddau
Hi
It doesn't works
something is strange
/etc/lightdm.conf seen with Mousepad on the left , with vi (or similar) on the right:
the 2 editors don't display the same thing.
Time to create page: 0.134 seconds
