Master on Debian Buster
16 Nov 2019 19:56 #150492 by YRCNC
Master on Debian Buster was created by YRCNC
I am trying to install Master on Buster. I followed this guide without any luck:
Debian 10 LinuxCNC
Everything looks like it ran through fine, but when I run Linuxcnc I get the following error:
LINUXCNC - 2.9.0~pre0
Error in startup script: couldn't read file "/usr/lib/tcltk/linuxcnc/bin/pickconfig.tcl": no such file or directory
I am running this is a virtual box.
Help, please
thanks
Ruben
17 Nov 2019 00:54 #150500 by phillc54
The following user(s) said Thank You: YRCNC
20 Nov 2019 13:10 #150751 by andypugh
Replied by andypugh on topic Master on Debian Buster
If you compiled from source you are probably running a "run in place (RIP)" system, ie all the executable files are in ~/linuxcnc-dev rather than in /usr/
In a terminal window try
cd linuxcnc-dev
. ./scripts/rip-environment
linuxcnc
(Yes, that really is dot - space - dot - slash )
20 Nov 2019 19:31 #150784 by YRCNC
Replied by YRCNC on topic Master on Debian Buster
Phil / Andy
Not sure what I have done, I followed all the steps in the post Phil did not seem to work. Andy, tried to run the script, just told me I am not running RIP, then I was scratching around and found the DEB files in the home dir for Linuxcnc. I installed that via GDebi and work 100%.
Thanks for the help, It might have been me being dumb... coming from windows for way to long, still wrapping my mind around Linux.
Will redo from scratch to see what i did wrong..
Thanks Gents!
Time to create page: 0.105 seconds
