UEFI boot
- stevebowen
- Thank you received: 3
18 Nov 2019 16:19 #150586
by stevebowen
UEFI boot was created by stevebowen
I purchased an ASROCK Q1900M motherboard. Its new but has a built in parallel port.
I can't get burned ISO files on either DVD or usb sticks to boot on this board.
They will boot on my son's computer
but not on another minix system that I have
This occurs when I try to use linuxcnc wheezy iso file.
I can boot windows 10 CD and was also able to burn Ubuntu 18.04 Bionic Beaver.
This with the live cd and installs fine.
I,ve tried various efi bios boot options.
tried both efi and plain boot choices and they dont work.
I have legacy support enabled in boot as well as CMS enabled.
apparently if the disk does not have an efi partition it wont boot
I have not tried the stretch ISO but suspect that it might work as debian indicates that both live and install efi are on the stretch release.
I do have a good working Ubuntu 18.04 install but alas without linuxCNC
I'm not very versed on linux so im relucant to try buildbot to install a system that way.
any help would be greatly appreciated.
- Thank you received: 1476
18 Nov 2019 17:17 #150587
Replied by Todd Zuercher on topic UEFI boot
Sorry not much help here, I don't recall having any trouble booting or installing on either of the two Asrock Q1900M-pro motherboards I have used (other than some minor video issues). But it has been some time ago and I may not be remembering all the details. Although I have seen stability issues with certain kernels, on the one machine, but it isn't running Linuxcnc, (it is my Mythtv computer at home.)
- Thank you received: 7485
18 Nov 2019 23:57 #150602
Replied by tommylight on topic UEFI boot
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
That should work on 18.04 as Mint 19 is based on that version.
- stevebowen
19 Nov 2019 21:33 #150680
by stevebowen
Replied by stevebowen on topic UEFI boot
I have managed to get a bootable iso onto usb stick for ubuntu 18.04 now
and a bootable iso onto dvd for the linuxcnc stretch version.
I've ran that livecd and gotten latency down to around 25 to 36 uSec.
I would really love to get ubuntu 18.04 bionic beaver working with linuxcnc 2.8
but it seems a bit advanced for me just right now.
I would also like to be able to at least try out wheezy and be able to use the RTAI
kernel because i think it might lower latency.
I need to try some more to get latency down.
I havent fully worked with ACPI, sound, isolcpus, IRQs etc
also
im just using one bank of DDR3 so im wondering if 2 banks would
help. I have a pico power supply and the plug out would let me get the memory into the other bank unless i modify the plug.
Also wondering if messing around with cpu voltages would make improvements.
also
20 Nov 2019 01:20 #150706
My q1900m-pro running the Wheezy RTAI iso has about 8000ns latency
- stevebowen
22 Nov 2019 21:17 #150973
by stevebowen
i managed to get wheezy loaded by loading ubuntu 18.04 beside it so now ubuntu grub2 boots but now other issues
If i run the latency test all works ok and it appears to have pretty good latency.
but if i try to run latency-histogram it doesnt nun
and also if i try to run linuxcnc config that doesnt run either
it ran in live cd mode but not once loaded
22 Nov 2019 21:39 #150976
If you are trying to run more than one of those at a time, it won't work.
Other wise not sure why they won't start.
- stevebowen
23 Nov 2019 00:33 #150994
by stevebowen
No just one at a time
Its frustrating because I finally got wheezy to run
and was able to run latency test fine
and got pretty good latency figures <34
but then when I tried to do config it wont run
it does look like it actually is running to tell the truth
because it will tell me a desktop icon is being created
and the splash screen is display but thats it
then if i open a terminal
it freezes after i type two characters
The following user(s) said Thank You: Todd Zuercher, Leon82
- stevebowen
23 Nov 2019 15:13 #151050
by stevebowen
Okay I did just fine for the first part
downloaded and installed
linux-headers-4.16.12-rt5-kona-rt_amd64.deb
and
linux-image-4.16.12-rt5-kona-rt_amd64.deb
Restart, hold down shift and ctrl to show grub2 menu, choose the above kernel
did uname -r and correct kernel is running
but the last part i have trouble with selecting the file i need
buildbot.linuxcnc.org/~buildmaster/dists/stretch/
has directories for 2.7 and 2.8
inside these are directories for binaries and source
now i dont know what to choose
inside amd64 binaries and source are entries for packages .bz2, .gz, and what looks like hundreds of revisions.
I dont know what to choose
and
23 Nov 2019 16:19 #151059
Choose the version you want:
2.8 is the latest stable release
2.9 is master or still under development but it has the latest features
choose amd64
download the last one with this name
linuxcnc-uspace_2.9.0~pre0.814.gb39c7ba5e_amd64.deb
for 2.9
or
linuxcnc-uspace_2.8.0~pre1.5313.geec284094_amd64.deb
for 2.8
install with gdebi by double clicking on it.
Done.
choose amd64
for 2.9
or
for 2.8
Done.
Time to create page: 0.126 seconds
