UEFI boot
- stevebowen
- Thank you received: 3
26 Nov 2019 10:28 #151288
by stevebowen
Replied by stevebowen on topic UEFI boot
Really sorry I not very versed on Linux or any of it really.
I did not set the source code repositories flag in software sources nor did I
add the stanza lines from buildbot instructions.
- stevebowen
26 Nov 2019 12:34 #151292
by stevebowen
set source code flag in software sources and that made some improvement but still some issues with packages some are saying ubuntu is using an earlier version
im getting fix broken package remarks also
i probably can figure this out
26 Nov 2019 14:27 #151298
You shouldn't need to do either of those at this point.
If you get LinuxCNC working then you will need gtksourceview, and that is most easily obtained from the Sid repo, but that still lies in the future....
bwidget should be available, as should boost-python.
A useful command is "apt-cache search". For example "apt-cache search boost"
Replied by andypugh on topic UEFI boot
Time to create page: 0.073 seconds
