2.8 RTAI as productive system
- DomCa
- Thank you received: 6
05 Dec 2019 09:50 #152053
by DomCa
2.8 RTAI as productive system was created by DomCa
Hi all,
I am running my CNC with a 2.7.14 install with RTAI. For me RTAI is a must because I run with ParPort.
I would now like to play with Gmoccapy and QTPYVCP. I already did a quick test install of this: forum.linuxcnc.org/9-installing-linuxcnc...or-new-rtai-packages
Is 2.8pre in a state to use it as replacement for my 2.7.14?
If I now set up a 2.8pre system, will I be able to upgrad to release 2.8?
Thanks for the help!
DomCa
DomCa
- Leon82
- Thank you received: 79
05 Dec 2019 23:33 - 05 Dec 2019 23:44 #152120
by Leon82
Replied by Leon82 on topic 2.8 RTAI as productive system
Ive been running the pre and 2.8 on my paraport on stretch fine. Qtpyvcp also
Save a copy the config. When you run it will update it to 2.8 config and save a back up
Jitter was a little higher on stretch
Last edit: 05 Dec 2019 23:44 by Leon82.
Time to create page: 0.182 seconds
