Testers Needed for New RTAI Packages
  • Bari
  • Bari's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Aug 2019 13:34 - 22 Mar 2020 19:46 #141283 by Bari
github.com/andypugh/RTAI/releases
New forked and working RTAI 5.2 from a couple of weeks ago. Works on Debian Stretch.
Howto build from source: wiki.linuxcnc.org/cgi-bin/wiki.pl?Building_RTAI_5.2_Packages
Now in www.linuxcnc.org/temp
Last edit: 22 Mar 2020 19:46 by andypugh.
The following user(s) said Thank You: nkp, Grotius
03 Aug 2019 13:54 #141286 by Grotius
Replied by Grotius on topic Testers Needed for New RTAI Packages
Hi Bari,
I mentioned that the displayport is not working on debian stretch with a intel onboard chip.
Had to install a backported kernel following this solution :
unix.stackexchange.com/questions/420678/...bian-9/420682#420682
Does RTAI5.2 has a displayport driver inside?
  • Bari
  • Platinum Member
  • Platinum Member
03 Aug 2019 14:07 #141289 by Bari
Replied by Bari on topic Testers Needed for New RTAI Packages
RTAI just patches the kernel. We only test and develop on AMD cpu's. If displayport for Intel was left on in the kernel config then it's there.
You can build from source yourself if you wish and include displayport and test.
  • Bari
  • Platinum Member
  • Platinum Member
15 Aug 2019 20:26 #142301 by Bari
The working branch is here, only use master:
github.com/NTULINUX/RTAI
After the no-calibration branch is fixed someone will post new debs for testing.
Thank you all!
27 Aug 2019 02:22 #143288 by vre
Replied by vre on topic Testers Needed for New RTAI Packages
works on debian buster ?
  • Bari
  • Platinum Member
  • Platinum Member
27 Aug 2019 15:54 #143357 by Bari
It worked for several boards on Stretch. You'll have to see what it does on Buster. It's still a beta.
28 Aug 2019 23:26 #143526 by vre
My onboard gpu works with > 4.4.19 kernels this rtai witch version kernel is?
  • Bari
  • Platinum Member
  • Platinum Member
28 Aug 2019 23:48 #143528 by Bari
  • Bari
  • Platinum Member
  • Platinum Member
07 Oct 2019 19:50 #147399 by Bari
No-calibration branch is fixed. Please resume testing.
  • twoflowers
  • twoflowers's Avatar
  • Visitor
  • Visitor
08 Oct 2019 04:54 #147443 by twoflowers
Replied by twoflowers on topic Testers Needed for New RTAI Packages
This is something I was looking for :)
Is there any chance it might work on RPi, too?
Time to create page: 0.162 seconds
