Testers Needed for New RTAI Packages
  • Bari
  • Bari's Avatar Topic Author
  • Platinum Member
  • Platinum Member
19 Nov 2019 14:15 #150677 by Bari
Replied by Bari on topic Testers Needed for New RTAI Packages
www.forum.linuxcnc.org/9-installing-linu...debian-buster#141671
"The dependency on python-vte was removed a month ago (nothing used it). " 08 Aug 2019
"Actually Gscreen does use it - though I believe i made it not crash if it's missing."
19 Nov 2019 14:34 #150678 by andypugh
Replied by andypugh on topic Testers Needed for New RTAI Packages
The packages there were made before I checked the dependencies (ie, they are what the debian control files say are needed, rather than what are definitely required.)
Unfortunately the Mac with my definitive list on has just gone back for repair.....
  • Bari
  • Platinum Member
  • Platinum Member
22 Nov 2019 19:57 #150997 by Bari
- screen resolution is still 1024x768 on intel gpu.
The i915 driver has been disabled in the kernel Kconfig as this driver is known to cause latency problems. If the distribution was properly built, you can use vesa or fbdev and have 1080p or 4K resolution. The i915 KMS DRM driver is not required for high resolutions. Unless you are playing video games on it, llvmpipe with fbdev will be fine.
  • twoflowers
  • twoflowers's Avatar
  • Visitor
  • Visitor
27 Nov 2019 14:21 #151389 by twoflowers
Replied by twoflowers on topic Testers Needed for New RTAI Packages
Well, it might be that the driver causes latency problems, but not on all devices. And this particular hardware does not give any resolution higher than 1024x846 with vesa (fbdev and modeselect fail).
This is what lspci -v says:
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02) (prog-if 00 [VGA controller])
	Subsystem: Hewlett-Packard Company Core Processor Integrated Graphics Controller
	Flags: bus master, fast devsel, latency 0, IRQ 5
	Memory at f0000000 (64-bit, non-prefetchable) [size=4M]
	Memory at e0000000 (64-bit, prefetchable) [size=256M]
	I/O ports at 1170 [size=8]
	[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
	Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
	Capabilities: [d0] Power Management version 2
	Capabilities: [a4] PCI Advanced Features
27 Nov 2019 14:34 #151391 by andypugh
I have had problems like this a few times, especially running Virtual Machines on my Mac. (5880x2440 screen)
Google searches tend to suggest xrandr but alll I have had much success with is creating an Xorg.conf file and forcing a resolution the old school way.
30 Dec 2019 01:12 - 30 Dec 2019 01:13 #153541 by MDM3D
Replied by MDM3D on topic Testers Needed for New RTAI Packages
Hello guys I attempted to follow Andy's advice to tommylight on installing the rtai files in www.linuxcnc.org/temp on mint 19.2.
If I run the latency test after a reboot the graphical window comes up but the displayed numbers stay at 0.
If I run the stepconfig wizard for a 4 axis setup using the defaults I get the following error report.
Warning: Spoiler!
Any tips for why the configuration has an error?
Last edit: 30 Dec 2019 01:13 by MDM3D.
  • twoflowers
  • Visitor
  • Visitor
04 Jan 2020 07:57 - 04 Jan 2020 07:58 #153988 by twoflowers
Some update on my screen reolution issue: If you have the same problem - stuck to 1024x768 - it's sufficient to create this monitor definition and restart Xorg (adjust the "Virtual ..." to your needs):
# /etc/X11/xorg.conf.d/10-monitor.conf
Section "Monitor"
	Identifier   "Monitor0"
	VendorName   "Monitor Vendor"
	ModelName    "Monitor Model"
	HorizSync       28.0 - 60.0
    	VertRefresh     43.0 - 72.0
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	SubSection "Display"
		Viewport   0 0
		Depth     24
		Virtual 1280 1024
	EndSubSection
EndSection
Other thing I want to mention: "stepconf" needs "gir1.2-gtk-3.0", which is not in the dependencies of the linuxcnc *.deb-file. If it's not installed, you get a cryptic error message.
Will there be some a new version for testing?
Last edit: 04 Jan 2020 07:58 by twoflowers.
04 Jan 2020 15:34 #154030 by JohnnyCNC
Replied by JohnnyCNC on topic Testers Needed for New RTAI Packages
I followed these instructions on a debian 10 system.
github.com/andypugh/RTAI/releases
uname -a shows this:
Linux X3CNC 4.14.132-rtai-amd64 #1 SMP PREEMPT Mon Jul 8 23:47:38 BST 2019 x86_64 GNU/Linux
Should this still be showing PREEMPT?
I did not successfully install 28. I got a bunch of dependency issues.
sudo dpkg --install linuxcnc_2.8.0.pre1.4891.gadf1eff73_amd64.deb
04 Jan 2020 19:43 #154059 by phillc54
Replied by phillc54 on topic Testers Needed for New RTAI Packages
Unfortunately this doesn't work on my machine with i915 graphics. :(
  • Moderator
  • Moderator
04 Jan 2020 19:53 #154063 by tommylight
Replied by tommylight on topic Testers Needed for New RTAI Packages
You have to enable "source code" repositories in the "software sources" from the main menu>administration.
Time to create page: 0.289 seconds
