Testers Needed for New RTAI Packages
- Bari
- Thank you received: 234
03 Aug 2019 18:34 - 23 Mar 2020 00:46 #141283
by Bari
github.com/andypugh/RTAI/releases
New forked and working RTAI 5.2 from a couple of weeks ago. Works on Debian Stretch.
Howto build from source: wiki.linuxcnc.org/cgi-bin/wiki.pl?Building_RTAI_5.2_Packages
Now in www.linuxcnc.org/temp
Testers Needed for New RTAI Packages was created by Bari
Last edit: 23 Mar 2020 00:46 by andypugh.
The following user(s) said Thank You: nkp, Grotius
- Grotius
- Thank you received: 2349
03 Aug 2019 18:54 #141286
by Grotius
Replied by Grotius on topic Testers Needed for New RTAI Packages
Hi Bari,
I mentioned that the displayport is not working on debian stretch with a intel onboard chip.
Had to install a backported kernel following this solution :
unix.stackexchange.com/questions/420678/...bian-9/420682#420682
Does RTAI5.2 has a displayport driver inside?
- Bari
03 Aug 2019 19:07 #141289
by Bari
Replied by Bari on topic Testers Needed for New RTAI Packages
RTAI just patches the kernel. We only test and develop on AMD cpu's. If displayport for Intel was left on in the kernel config then it's there.
You can build from source yourself if you wish and include displayport and test.
- Bari
16 Aug 2019 01:26 #142301
by Bari
The working branch is here, only use master:
github.com/NTULINUX/RTAI
After the no-calibration branch is fixed someone will post new debs for testing.
Thank you all!
Thank you all!
- vre
- Thank you received: 17
27 Aug 2019 07:22 #143288
by vre
Replied by vre on topic Testers Needed for New RTAI Packages
works on debian buster ?
- Bari
27 Aug 2019 20:54 #143357
by Bari
It worked for several boards on Stretch. You'll have to see what it does on Buster. It's still a beta.
- vre
29 Aug 2019 04:26 #143526
by vre
My onboard gpu works with > 4.4.19 kernels this rtai witch version kernel is?
- Bari
29 Aug 2019 04:48 #143528
by Bari
- Bari
08 Oct 2019 00:50 #147399
by Bari
No-calibration branch is fixed. Please resume testing.
- twoflowers
- Visitor
08 Oct 2019 09:54 #147443
by twoflowers
Replied by twoflowers on topic Testers Needed for New RTAI Packages
This is something I was looking for
Is there any chance it might work on RPi, too?
Time to create page: 1.257 seconds
