Buildbot repositories down?
5 years 11 months ago #189593 by tommylight
Works here on 3 PC's.
5 years 11 months ago - 5 years 11 months ago #189603 by Vescovo
Replied by Vescovo on topic Buildbot repositories down?
Thanks tommylight, I will rebuild from scratch.
The installation from CD has some issues. This is the CD
Debian GNU/Linux 9.8.0 "Stretch" - Official i386 xfce-CD Binary-1 20190216-12:51
1) After log-in as userName and setting userName as a member of sudo the instruction sudo was not found.
2) Log-in as root with rootPW if set. I always set it!
su root rootPW adduser userName sudo # Install the sudo executable apt install sudo su userName # Now sudo works but breaks Thunar's ability to view exfat USB drives # Correct the issue with exfat USB drives sudo apt-get install exfat-fuse exfat-utils # Install key for buildbot sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E # Add the following to for the Synaptic Package Manager echo deb http://buildbot.linux.org/ stretch 2.8-rtpreempt >>/etc/apt/sources.list echo deb-src http://buildbot.linux.org/ stretch 2.8-rtpreempt >>/etc/apt/sources.list # You should now be able to download the 2.8 version of LinuxCNC without errors
Very nice work you guys!
Last edit: 5 years 11 months ago by Vescovo.
5 years 11 months ago #189604 by tommylight
Should not be required, just do and update again.
sudo apt-get update
5 years 11 months ago #189624 by Vescovo
But sudo was not working so "sudo apt-get update" didn't work? What did I miss?
5 years 11 months ago #189628 by tommylight
OoooK,
If installing Debian, if it asks for a ROOT password = do not enter anything, press next.
