having trouble flashing my mesa 7i92...
- P.J.B.C
08 Apr 2020 00:06 - 22 Apr 2020 03:58 #163129
by P.J.B.C
having trouble configuring my mesa 7i92...jethornton's configuration tool.. was created by P.J.B.C
I've got a mesa 7i92 and a Gecko G540 combination and i am following Jethornton's guide on installing the configuration tool on debian 9. However I've hit snag where i can't flash the card, (I've got the required ping from the card and the configuration tool is fully populated) but I get an error message when i go to open the ini.file (there is a error message to the tune of {Note: Using POSIX realtime}), also in the configuration tool when i go to flash the card there is an error message (can't find file /home/usr/.local/lib/python3.5/site-packages/m7i92/7i92_G540x2D.bit).
I am sure that this is just a step i have missed, so I thought i would ask the forums.
Also i am using python version 2.7.13 (not sure if this is the problem)
also i have changed the deb repositories to the rtpreempt buildbot repositories.
any help is greatly appreciated...
Last edit: 22 Apr 2020 03:58 by P.J.B.C.
- bbsr_5a
- Thank you received: 106
08 Apr 2020 06:21 #163156
by bbsr_5a
Replied by bbsr_5a on topic having trouble flashing my mesa 7i92...
the ini file got nothing to do with the flash of the 7i92
hat does the pin reread get you
then look in the test.pin what file is loaded and haow the pins are named
You can use pncconf to get your mashine running not a ready made INI this might fail
the posx saying your Kernel may have a issue
mesaflash --device 7i92 --addr 10.10.10.10 --readhmid > test.pin then look in the test.pin what file is loaded and haow the pins are named
- BeagleBrainz
- Visitor
08 Apr 2020 06:51 #163164
by BeagleBrainz
Replied by BeagleBrainz on topic having trouble flashing my mesa 7i92...
I have you checked that folder to see if the firmware is there ?
If not you have to download the bit file. PCW may have the download link.
- Thank you received: 5334
08 Apr 2020 13:11 #163196
Replied by PCW on topic having trouble flashing my mesa 7i92...
The firmware files are in this zip archive:
www.mesanet.com/software/parallel/7i92.zip
(in configs/hostmot2)
Before attempting to update the firmware, you should verify you
are connected to the 7i92 with bbsr_5a's example or just:
(if the 7I92 is at its default 192.168.1.121 address)
or
(if the 7I92 is set to use its EEPROM address of 10.10.10.10)
When actually writing the firmware, its probably easiest to run mesaflash
from the directory containing the .bit file:
mesaflash --device 7i92 --write 7i92_G540x2D.bit
or
mesaflash --device 7i92 --addr 10.10.10.10 --write 7i92_G540x2D.bit
or
or
The following user(s) said Thank You: BeagleBrainz
- P.J.B.C
10 Apr 2020 06:02 #163450
by P.J.B.C
Replied by P.J.B.C on topic having trouble flashing my mesa 7i92...
I think my title is a little misleading, I actually think i am having trouble with creating the folder that the .bit file goes in.. I'm a bit confused to the actual meaning of step:3 of this page: jethornton.github.io/7i92/install.html
I've not used linux much and i don't know how to insert the string into the folder, I've watch a couple video's and they got me confused..
I haven't gotten to the flashing yet...
10 Apr 2020 06:33 #163452
That page refers to installing the configuration tool
not flashing the 7I92 with new firmware
To flash the card, refer to my previous post, first
downloading 7i92.zip and unzipping it into your
home directory:
unzip 7i92.zip
cd configs
cd hostmot2
then follow the instructions above
home directory:
unzip 7i92.zip
cd configs
cd hostmot2
- P.J.B.C
21 Apr 2020 09:06 #164932
by P.J.B.C
That helped a lot thanks...!
However i now can't open the configuration tool
When i go to open the previous configuration i made it send s the error it can't find a custom Hal file....
So I think i got something wrong with the files.. can you explain..
21 Apr 2020 15:23 #164970
Can you copy/paste the actual error here?
- P.J.B.C
22 Apr 2020 03:37 - 22 Apr 2020 03:39 #165034
by P.J.B.C
I managed to re-open the configuration tool( i just needed to rename the .xsessionrc file). However I still can't open the ini.file (the line reads: cannot find file for:custom.hal).
So I suppose i still need to create a custom hal file... Any clues..?
Last edit: 22 Apr 2020 03:39 by P.J.B.C.
22 Apr 2020 03:38 #165035
What configuration tool are you using?
