Please help the stupid
17 Apr 2020 20:12 #164316 by wbest
Please help the stupid was created by wbest
All,
I been lurking about for a while now. I had Debian 7 and LinuxCnc installed.
However, I had to upgrade some hardware and I need the latest version of LinuxCnc.
So, from what I can tell I need Debian 9.9 and LinuxCnc 2.7.14?
What I can't find if where to get all of this. Everything links back to the Debian 7 Wheezy files - Which have been EOL'ed.
Can someone point me in the right direction?
Is there an ISO that has Debian 9.9 /w LinuxCnc installed etc that I can simply download and put on a bootable USB stick to install?
Thanks,
WTB
  • Moderator
  • Moderator
17 Apr 2020 22:16 #164342 by tommylight
Replied by tommylight on topic Please help the stupid
linuxcnc.org/downloads
There is Debian 9 or Stretch version there, the the upgrade how to is
buildbot.linuxcnc.org
Or you can install on Debian 10,
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
Or Linux Mint
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Both links use Mate desktop, but it should work with any other desktop.
18 Apr 2020 00:50 #164371 by wbest
Replied by wbest on topic Please help the stupid
So I went and downloaded:
linuxcnc-stretch-uspace-i386-r13 (1).iso
I updated my Rufus and wrote to USB Stick using both the regular and the DD mode.
I stick it into the computer, power up and it says non-bootable disk.
This is the same stick I used to installed Debian 7. I just wiped it and started over. I also tried a new usb and it failed the same way.
Thoughts?
WTB
  • Moderator
  • Moderator
18 Apr 2020 10:59 #164440 by tommylight
Did you check the md5sum of the downloaded ISO ?
18 Apr 2020 12:36 #164448 by wbest
I came in this morning. Turned it on....and it started wrking. Wierdest thing I've ever seen.
Now, I got to figure out the 7i96 configuration.
Thanks.
WTB
18 Apr 2020 12:52 #164453 by bbsr_5a
Replied by bbsr_5a on topic Please help the stupid
did you install it to harddrive or still on USB
sometimes the USB Stick is regionized by Bios at the second boot
i did discover this also therfor i use DVD preferd
23 Apr 2020 22:14 #165317 by rac552
Replied by rac552 on topic Please help the stupid
I have similar problems with my usb install. my machine would not find the usb or the dvd of linuxcnc install. someone mentioned legacy boot option in the bios. I enabled legacy boot and move the usb boot option to the top and it found my usb. This is a newer machine so there must be something different in the boot option for the newer bios. hope this helps
