i5-8250U laptop for Linuxcnc with ethernet
28 Apr 2020 23:41 - 28 Apr 2020 23:42 #166036 by taloot
i have this laptop and i will use it as cnc controller.
its fast,, and i will use mesa via ethernet,, but i have some red number in the latency histogram, letency about 30 usec.. but im worry about the red numbers, off chart bin ct
is it safe to use this laptop? with mesa ethernet
Last edit: 28 Apr 2020 23:42 by taloot.
29 Apr 2020 00:00 #166038 by tommylight
Replied by tommylight on topic i5-8250U laptop for Linuxcnc with ethernet
Open terminal, type:
latency-histogram --nobase
Get us a screenshot.
29 Apr 2020 00:27 #166040 by taloot
Replied by taloot on topic i5-8250U laptop for Linuxcnc with ethernet
29 Apr 2020 00:48 #166041 by tommylight
That looks very promising.
While doing that latency test, open more glxgears, like 5 or 10 and maximise and minimise one of the glxgears screens, play a HD youtube video and also maximise and minimise it, copy some files from one folder to another. Do that for at least 15 to 30 minutes and leave the test going for at least an hour.
If the numbers do not jump much, it should be OK.
Do you have a Mesa ethernet board ?
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
29 Apr 2020 01:03 #166045 by BeagleBrainz
Replied by BeagleBrainz on topic i5-8250U laptop for Linuxcnc with ethernet
Just make sure that the cores you isolate share the same cache. And disable hyperthreading which appears you have enabled.
29 Apr 2020 16:42 #166099 by taloot
its about 15 us now
yes i have mesa ethernet board
29 Apr 2020 16:45 #166100 by taloot
i want hyperthreading ,, i will use external motion controller,,, so i assume no need to isolcpus, but i was testing,,,
the most effective tweak,, was set fixed cpu speed + performance governor
if i have low latency + externel motion controller, do i benfit?
29 Apr 2020 16:49 - 29 Apr 2020 16:51 #166102 by taloot
this is the best result i have with hyperthreading + no isolcpus
Last edit: 29 Apr 2020 16:51 by taloot.
  • BeagleBrainz
  • Visitor
  • Visitor
29 Apr 2020 17:01 #166105 by BeagleBrainz
The current theory is that hyper threading is not a good idea with real time. Most of the recommendations for good latency is to disable hyperthreading.
Maybe one of the kernel guys will chime in and give the current thinking.
29 Apr 2020 17:22 - 29 Apr 2020 17:29 #166111 by taloot
i agre with u if i use LPT... but with external motion controller,,, i think my current results is so good and enought,,,
no more gain i will get if i disable the HT
also my client using very large decorative gcode,, i want fast machine
with isolcpus,, i decide where the money goes,, to intel or to mesa,
Last edit: 29 Apr 2020 17:29 by taloot.
Time to create page: 2.461 seconds
