new install, now cant import tkinter
6 years 4 months ago #170115 by tommylight
Replied by tommylight on topic new install, now cant import tkinter
Ran into the same issue yesterday, updater only affected.
Thank you.
6 years 4 months ago #170299 by Marcodi
Replied by Marcodi on topic new install, now cant import tkinter
I ran into the same issue 10 days ago, apparently now there is a proposed solution for it.
I couldn't solve it and I downgraded to 2.8.0 again
6 years 4 months ago - 6 years 4 months ago #170305 by phillc54
Replied by phillc54 on topic new install, now cant import tkinter
It is probably worthwhile opening an issue here github.com/LinuxCNC/linuxcnc/issues
A quick look doesn't show anything similar.
Last edit: 6 years 4 months ago by phillc54.
The following user(s) said Thank You: arvidb
6 years 4 months ago #170378 by arvidb
Replied by arvidb on topic new install, now cant import tkinter
Yes, good advice. I've opened an issue now: github.com/LinuxCNC/linuxcnc/issues/881
6 years 4 months ago #170412 by rodw
Replied by rodw on topic new install, now cant import tkinter
I installed Beagle's Mint ISO build master from source yesterday and this was one missing dependency which stalled me. I think
sudo apt-get install python3-tk
sudo apt-get install python-tk
Fixed it.
Just not sure on the second one. It might have been python2-tk. I just guessed we'd need to do something for python2 as well.
So I guessed the dependency.
Not related but the only problem I have is the linuxcnc chooser it too hard to read with squashed up text It would be nice if the column was resizable.
3 years 2 months ago - 3 years 2 months ago #278804 by tjtr33
Replied by tjtr33 on topic new install, now cant import tkinter
Update: 26 Aug 2023
Phill Carter proved it works in 2.9.0-pre mumble
Thanks Phill
Hello, on linuxcnc 2.8.4 ,
I cannot load Jepler's teachin.py
and
reloading python3-tk then puthon-tk did not get rid of 'no module anemd tkinter'
both modules show up to date
"python3-tk is already the newest version (3.7.3-1)."
"python-tk is already the newest version (2.7.16-2)."
yet jeplers teachin.py gets error
"Traceback (most recent call last):
File "/home/tomp/linuxcnc/nc_files/teachin.py", line 27, in <module>
import tkinter
ImportError: No module named tkinter
TomP 22Aug2023
EDIT:
this is a bitch
python 2.nnn uses Tkinter
python 3.nnn uses tkinter
note the capital T vs lowercase t
also, most of the calls are different in format
and if you try to search  Tkinter vs tkinter,
the web will pften hand you the wrong info despite quotes
Here is a good reference for python 2.nn's Tkinter
www.geeksforgeeks.org/create-first-gui-a...sing-python-tkinter/
but beware opf 'signup' nagging
To learn more on your own...
run      python2.nnn ( likely default for Linuxcnc users )
then    import Tkinter
then   print(dir(Tkinter))        to get a list of all the keywords in he lib
then   help(Tkinter.wordofinterest))        to learn more about a function
Be very wary of any code on web untill you can recognize which T/t kinter is used
HTH tomp
Last edit: 3 years 2 months ago by tjtr33. Reason: update
Time to create page: 2.565 seconds
