new install, now cant import tkinter
6 years 5 months ago #166558 by phillc54
Replied by phillc54 on topic new install, now cant import tkinter
Could be something to do with the Python3 work being done on master, I would stick with 2.8 at this stage unless there is something specific you need from master.
  • BeagleBrainz
  • Visitor
  • Visitor
6 years 5 months ago #166563 by BeagleBrainz
Replied by BeagleBrainz on topic new install, now cant import tkinter
Try
sudo apt-get install python3-tk
6 years 5 months ago #166585 by bbsr_5a
Replied by bbsr_5a on topic new install, now cant import tkinter
someone shoudt update the install process on UPDATE to Master
to get the python3-tk ito depencies needed
6 years 5 months ago #166592 by rodw
Replied by rodw on topic new install, now cant import tkinter
bbsr_5a wrote: someone shoudt update the install process on UPDATE to Master
To be fair Python3, is stilla work in progress for LInuxcnc and a lot of PR's were pushed to master bracnh over the last few days.... It would be best to log an issue in git hub.
6 years 5 months ago #166614 by owhite
Replied by owhite on topic new install, now cant import tkinter
just following up in case anyone else follows this thread - unfortunately I was not able to fix it until I did a reinstall from here:
forum.linuxcnc.org/9-installing-linuxcnc...onic-beaver-mint-iso
...which is a great iso
6 years 4 months ago - 6 years 4 months ago #170114 by arvidb
Replied by arvidb on topic new install, now cant import tkinter
I just ran into this as well. The problem seems to be that /usr/bin/update_ini has been (partially) updated for python-3, but is still set to use python-2.7. I modified the file and got it working again. See the attached patch file.
Edit: Apply like this:
cd /usr/bin sudo patch -N < path/to/update_ini.patch
Last edit: 6 years 4 months ago by arvidb.
Time to create page: 2.777 seconds
