Re:Intel D945GCLF2
5 years 9 months ago #196346 by tommylight
Replied by tommylight on topic Re:Intel D945GCLF2
sudo lspci -v | grep par
in a terminal ?
ASUS ROG Crosshair VIII Impact - AMD X570
5 years 9 months ago #196358 by jarcysgru
Replied by jarcysgru on topic Re:Intel D945GCLF2
j@j:~$ sudo lspci -v | grep par
[sudo] password for j:
00:00.0 Host bridge: Intel Corporation 82945G/GZ/P/PL Memory Controller Hub (rev 02)
Subsystem: Intel Corporation Device 464c
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=09 <?>
Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation 82945G/GZ Integrated Graphics Controller (rev 02) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at 90200000 (32-bit, non-prefetchable) [size=512K]
I/O ports at 20e0
Memory at 80000000 (32-bit, prefetchable) [size=256M]
Memory at 90280000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at <unassigned> [disabled]
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Kernel driver in use: i915
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
Subsystem: Intel Corporation Device d604
Flags: bus master, fast devsel, latency 0, IRQ 22
Memory at 902c0000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 90100000-901fffff
Prefetchable memory behind bridge: 0000000090000000-00000000900fffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Device 0000:0000
Capabilities: [a0] Power Management version 2
Capabilities: [180] Root Complex Link
Kernel driver in use: pcieport
00:1c.2 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 3 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: 90300000-904fffff
Prefetchable memory behind bridge: 0000000090500000-00000000906fffff
00:1c.3 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 4 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00004000-00004fff
Memory behind bridge: 90700000-908fffff
Prefetchable memory behind bridge: 0000000090900000-0000000090afffff
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at 2080
Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at 2060
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at 2040
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at 2020
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01) (prog-if 20 [EHCI])
Memory at 902c4000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [58] Debug port: BAR=1 offset=00a0
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
Capabilities: [50] Subsystem: Intel Corporation Device 464c
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01) (prog-if 8a [Master SecP PriP])
I/O ports at 01f0
I/O ports at 03f4
I/O ports at 0170
I/O ports at 0374
I/O ports at 20b0
Kernel driver in use: ata_piix
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01) (prog-if 8f [Master SecP SecO PriP PriO])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at 20c8
I/O ports at 20ec
I/O ports at 20c0
I/O ports at 20e8
I/O ports at 20a0
Capabilities: [70] Power Management version 2
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
Flags: medium devsel, IRQ 19
I/O ports at 2000
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
Subsystem: Intel Corporation Device 0001
I/O ports at 1000
Memory at 90100000 (64-bit, non-prefetchable) [size=4K]
Memory at 90000000 (64-bit, prefetchable) [size=64K]
Expansion ROM at 90020000 [disabled] [size=128K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=2 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
Kernel driver in use: r8169
j@j:~$
Nie widzę portu LPT
5 years 9 months ago - 5 years 9 months ago #196361 by jarcysgru
Czy to jest port LPT I/O ports at 20e0.
Ja wisywałem 0x378
Last edit: 5 years 9 months ago by jarcysgru.
5 years 9 months ago #196362 by andypugh
Replied by andypugh on topic Re:Intel D945GCLF2
tommylight wrote: sudo lspci -v | grep par
in a terminal ?
lspci won't show onboard ports, and 0x378 is often an onboard port.
what do you get with:
cat /proc/ioports
5 years 9 months ago - 5 years 9 months ago #196409 by jarcysgru
j@j:~$ cat/proc/ioports
bash: cat/proc/ioports: Nie ma takiego pliku ani katalogu
j@j:~$ cat /proc/ioports
0000-0cf7 : PCI Bus 0000:00
0000-001f : dma1
0020-0021 : pic1
0040-0043 : timer0
0050-0053 : timer1
0060-0060 : keyboard
0064-0064 : keyboard
0070-0071 : rtc0
0080-008f : dma page reg
00a0-00a1 : pic2
00c0-00df : dma2
00f0-00ff : fpu
0170-0177 : 0000:00:1f.1
0170-0177 : ata_piix
01f0-01f7 : 0000:00:1f.1
01f0-01f7 : ata_piix
0376-0376 : 0000:00:1f.1
0376-0376 : ata_piix
0378-037a : parport0
037b-037f : parport0
03c0-03df : vga+
03f6-03f6 : 0000:00:1f.1
03f6-03f6 : ata_piix
03f8-03ff : serial
0400-047f : pnp 00:06
0400-0403 : ACPI PM1a_EVT_BLK
0404-0405 : ACPI PM1a_CNT_BLK
0408-040b : ACPI PM_TMR
0420-0420 : ACPI PM2_CNT_BLK
0428-042f : ACPI GPE0_BLK
0430-0433 : iTCO_wdt
0460-047f : iTCO_wdt
0500-053f : pnp 00:06
0680-06ff : pnp 00:06
0cf8-0cff : PCI conf1
0d00-ffff : PCI Bus 0000:00
1000-1fff : PCI Bus 0000:01
1000-10ff : 0000:01:00.0
1000-10ff : r8169
2000-201f : 0000:00:1f.3
2020-203f : 0000:00:1d.3
2020-203f : uhci_hcd
2040-205f : 0000:00:1d.2
2040-205f : uhci_hcd
2060-207f : 0000:00:1d.1
2060-207f : uhci_hcd
2080-209f : 0000:00:1d.0
2080-209f : uhci_hcd
20a0-20af : 0000:00:1f.2
20a0-20af : ata_piix
20b0-20bf : 0000:00:1f.1
20b0-20bf : ata_piix
20c0-20c7 : 0000:00:1f.2
20c0-20c7 : ata_piix
20c8-20cf : 0000:00:1f.2
20c8-20cf : ata_piix
20e0-20e7 : 0000:00:02.0
20e8-20eb : 0000:00:1f.2
20e8-20eb : ata_piix
20ec-20ef : 0000:00:1f.2
20ec-20ef : ata_piix
3000-3fff : PCI Bus 0000:02
4000-4fff : PCI Bus 0000:03
j@j:~$
So I have 378 what these entries mean 037a 037b 037f?
0378-037a: parport0
037b-037f: parport0
5 years 9 months ago #196411 by andypugh
Well, there it is, at 0x378.
Time to create page: 0.487 seconds
