- LinuxCNC
- Installing LinuxCNC
- Problems installing Linuxcnc on Debian 9.8.0+nonfree (amd64 / iso-dvd) >>
- denhen89
- Thank you received: 27
15 May 2020 09:48 #167828
by denhen89
Problems installing Linuxcnc on Debian 9.8.0+nonfree (amd64 / iso-dvd) >> was created by denhen89
Hello Guys,
yesterday i have got my 7i76E, so i made a fresh install of Linuxcnc, then later a Debian version without linuxcnc and now i found video on youtube where "talla83" explained how to use the Mesa 7i76E on Debian 9.8.0+nonfree version. (the video tutorial: )
I have made a fresh install and installed the linux image 4.9.0.8-rt-amd64 (preempt_rt) as shown in the videos. Restarted the pc and everything was exactly as shown in the video.
Then i wanted to install Linuxcnc 2.7 stable version so i used those lines in the terminal:
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
sudo add-apt-repository "deb linuxcnc.org/ strech base 2.7-uspace"
then this: sudo apt-get update
and i get this:
I am not sure what i am doing wrong, but i did everything 100% exactly as it was shown in the youtube video tutorial.
Yesterday i tried a wheezy version, then Debian 10 (if i remember correctly), but followed always what was written here in the forum or on the "gnipsel.com" page. I always had problems with updates or installing linuxcnc. Always some missing files or releases. Until now i am working on it for 12h. I hope you understand that i really need your help.
Couple days ago i installed the standard wheezy version, because i wanted to test a MPG manual handwheel with a cheap BOB. Installed 2.9 and everything seemed to work fine, but right now all steps i need to do to get the MESA 7i76E to work are not working for me.
Please help me out guys.
and i get this:
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://ftp.de.debian.org/debian stretch InRelease
Hit:3 http://ftp.de.debian.org/debian stretch-updates InRelease
Hit:4 http://ftp.de.debian.org/debian stretch Release
Ign:6 http://linuxcnc.org strech InRelease
Ign:7 http://linuxcnc.org strech Release
Ign:8 http://linuxcnc.org strech/2.7-uspace all Packages
Ign:9 http://linuxcnc.org strech/2.7-uspace amd64 Packages
Ign:10 http://linuxcnc.org strech/2.7-uspace Translation-en_GB
Ign:11 http://linuxcnc.org strech/2.7-uspace Translation-en
Ign:12 http://linuxcnc.org strech/base amd64 Packages
Ign:13 http://linuxcnc.org strech/base all Packages
Ign:14 http://linuxcnc.org strech/base Translation-en_GB
Ign:15 http://linuxcnc.org strech/base Translation-en
Err:9 http://linuxcnc.org strech/2.7-uspace amd64 Packages
404 Not Found
Reading package lists... Done
W: The repository 'http://linuxcnc.org strech Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://linuxcnc.org/dists/strech/2.7-uspace/binary-amd64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.I am not sure what i am doing wrong, but i did everything 100% exactly as it was shown in the youtube video tutorial.
- denhen89
15 May 2020 10:13 #167829
by denhen89
Replied by denhen89 on topic Problems installing Linuxcnc on Debian 9.8.0+nonfree (amd64 / iso-dvd) >>
UPDATE: Linuxcnc is installed
Important for beginners with similar problems:
I found that topic: forum.linuxcnc.org/9-installing-linuxcnc...er-on-debian-9-error
I downloaded GDEBI as tommylight wrote and then installed all needed files from this page: buildbot.linuxcnc.org/dists/stretch/2.7-rtpreempt/binary-amd64/
1. step: download and install:
linuxcnc-uspace_2.7.15.8.gf38f9c3f5_amd64.deb
2. step: download and install: linuxcnc-uspace-dev_2.7.15.8.gf38f9c3f5_amd64.deb
3. step: download and install: linuxcnc-uspace-dbgsym_2.7.15.8.gf38f9c3f5_amd64.deb
Linuxcnc is installed and it seems that i can continue with the next steps, but havent made any more steps, so i cant tell if it will also work as it should
- BeagleBrainz
- Visitor
15 May 2020 10:15 - 15 May 2020 10:15 #167830
by BeagleBrainz
Replied by BeagleBrainz on topic Problems installing Linuxcnc on Debian 9.8.0+nonfree (amd64 / iso-dvd) >>
try stretch instead of strech
Last edit: 15 May 2020 10:15 by BeagleBrainz.
- denhen89
15 May 2020 10:22 - 15 May 2020 10:22 #167831
by denhen89
Oh, that might have been the problem
I entered those lines by hand without copy paste..
Thanks for the info.
Last edit: 15 May 2020 10:22 by denhen89.
The following user(s) said Thank You: BeagleBrainz
- LinuxCNC
Time to create page: 0.229 seconds
