LinuxCNC on Linux Mint 20 quick and nearly easy install
5 years 4 weeks ago #222080 by tommylight
5 years 4 weeks ago #222086 by hottabich
sudo apt update
sudo apt dist-upgrade
And how does it help me?
5 years 4 weeks ago #222095 by BigJohnT
Hello! Please tell me how to update linuxcnc2.9pre.0.
Assuming you currently have 2.9 Tommy's reply was correct.
JT
5 years 4 weeks ago #222097 by tommylight
If you are using Mint 20 installed with this howto all you need to do is those two lines, it will update to the latest build of master.
5 years 4 weeks ago #222098 by tommylight
Ooops, this was made for the stretch version and that is not built anymore ! :(
Change the repo to Buster :
 sudo apt-add-repository 'deb buildbot.linuxcnc.org/ buster master-rtpreempt'
and manually disable or delete the stretch repo entry in "software sources", then update and dist-upgrade.
Sorry for missing that.
The following user(s) said Thank You: seuchato, hottabich
5 years 4 weeks ago #222103 by Clive S
sudo apt update
The above needs to be typed in a terminal
Time to create page: 0.476 seconds
