LinuxCNC on Linux Mint 20 quick and nearly easy install
6 years 3 months ago - 5 years 4 months ago #175816 by tommylight
Please use the official release found here:
linuxcnc.org/downloads/
Use this tutorial only if you have issues with dirvers, be it WiFi or graphic or else, ..
To install LinuxCNC and the real time kernel on Linux Mint 20 with Mate of XFCE desktop environment ( should also work for Ubuntu 20.4 ) some packages from the official Debian repositories have to be downloaded and installed, as follows:
- Download Linux Mint ISO from here:
https://www.linuxmint.com/download.php
- Write the ISO to a USB drive using win32imager on windows or DD on Linux
- Boot the PC from the USB, make sure that is set in BIOS or press F8 or F9 or F11 or F12 when booting and choose USB
- Install Linux Mint to the HDD or SSD
- Reboot
- Open a terminal from the menu or on the lower left side of the panel
- Copy and paste the following lines, one by one
wget http://ftp.us.debian.org/debian/pool/main/l/linux/linux-image-4.9.0-13-rt-amd64_4.9.228-1_amd64.deb wget http://ftp.us.debian.org/debian/pool/main/b/boost1.62/libboost-python1.62.0_1.62.0+dfsg-4_amd64.deb wget http://ftp.us.debian.org/debian/pool/main/p/pygtk/python-glade2_2.24.0-5.1_amd64.deb wget http://ftp.us.debian.org/debian/pool/main/p/pygtksourceview/python-gtksourceview2_2.10.1-3_amd64.deb wget http://ftp.us.debian.org/debian/pool/main/p/pygtk/python-gtk2_2.24.0-5.1_amd64.deb wget http://ftp.us.debian.org/debian/pool/main/p/python-gtkglext1/python-gtkglext1_1.1.0-9.1_amd64.deb wget http://ftp.us.debian.org/debian/pool/main/g/gst-python1.0/python-gst-1.0_1.10.4-1_amd64.deb wget http://ftp.us.debian.org/debian/pool/main/c/configobj/python-configobj_5.0.6-2_all.deb
sudo gdebi linux-image-4.9.0-13-rt-amd64_4.9.228-1_amd64.deb sudo gdebi libboost-python1.62.0_1.62.0+dfsg-4_amd64.deb sudo gdebi python-gtk2_2.24.0-5.1_amd64.deb sudo gdebi python-glade2_2.24.0-5.1_amd64.deb sudo gdebi python-gtksourceview2_2.10.1-3_amd64.deb sudo gdebi python-gtkglext1_1.1.0-9.1_amd64.deb sudo gdebi python-gst-1.0_1.10.4-1_amd64.deb sudo gdebi python-configobj_5.0.6-2_all.deb
sudo apt-key adv --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E - -For Master version, unstable, still under development sudo apt-add-repository 'deb http://buildbot.linuxcnc.org/ stretch master-rtpreempt' -OR, not both. -For 2.8 version, stable, to be current release sudo apt-add-repository 'deb http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt' - sudo apt-get update - sudo apt-get -y install linuxcnc-uspace
If the above keyserver does not work, try these:
sudo apt-key adv --keyserver hkp://keys.openpgp.org --recv-key EF1B07FEE0EE663E
OR
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com --recv-key EF1B07FEE0EE663E
OR
sudo apt-key adv --keyserver hkp://pgpkeys.eu --recv-key EF1B07FEE0EE663E
Editing the GRUB menu
sudo add-apt-repository ppa:danielrichter2007/grub-customizer sudo apt-get update sudo apt-get install grub-customizer
How to use:
itsfoss.com/grub-customizer-ubuntu/
It is for Ubuntu, same applies for Mint.
WARNING : DO NOT INSTALL THIS!!!
ONLY In case you need to build other kernel modules the installation of the below listed packages is required.
After download, double click on each of the files and install as usual with Gdebi. The order of links might be off, so try the next and the next and.....
Last edit: 5 years 4 months ago by tommylight. Reason: More info
The following user(s) said Thank You: beatnic, akb1212, elovalvo, rodw, anfänger, riversvic, RoberCNC, hilo90mhz
  • BeagleBrainz
  • New Member
  • New Member
6 years 3 months ago #175845 by BeagleBrainz
Jolly good show Old bean, a Tip O' The Hat to you.
How long did you spend working it out ?
Sorry I've been a bit quiet of late, been into another couple of projects.
6 years 3 months ago #175860 by Clive S
BeagleBrainz wrote: Jolly good show Old bean, a Tip O' The Hat to you.
Now all you have to do is work your magic and turn it into an ISO :)
6 years 3 months ago #175872 by tommylight
In total about 4 hours plus upgrade from beta, so not bad at all.
Will add the 5.4 kernel and try to do a script as soon as i can.
The following user(s) said Thank You: zack
6 years 2 months ago - 6 years 2 months ago #177096 by rootboy
Thanks! I had a few hiccups, but it is running on both of my PCs.
I first installed it on my home PC (no mill attached to it) and ran into three problems. I just finished installing it on my friend's PC and had the first and last problem (the last not really being a problem so much as a requirement).
Installing python-gtk2 failed with a "Dependency is not satisfiable" error. This was fixed by going to pkgs.org/download/python-gtk2 and downloading the "Debian 9 (Stretch)" version. Installing the newer version will not work.
Download the file, let the installer do its thing including installing extra files that it requires to complete the installation.
Don't forget to run (or re-run) the "sudo gdebi python-glade2..." command.
This could probably be avoided by installing the python-gtk2 package first. But if not, this is how I fixed it.
I also had a "multiarch-support" issue with my Ryzen processor, but not with the Intel i5 on the target PC. I fixed this by installing multiarch-support_2.24-11+deb9... on my Ryzen PC.
And this is not a bug, just a friendly reminder. If your apt-get update fails on LinuxCNC buildbot, go to: buildbot.linuxcnc.org and add the signing key to your apt keychain.
Last edit: 6 years 2 months ago by rootboy. Reason: Missing punctuation
6 years 2 months ago #177104 by tommylight
rootboy wrote: If your apt-get update fails on LinuxCNC buildbot, go to: buildbot.linuxcnc.org and add the signing key to your apt keychain.
Dang, i forgot to add that, will remedy immediately !
Thanks for the report.
Time to create page: 0.460 seconds
