LinuxCNC on Linux Mint 20 quick and nearly easy install
6 years 2 months ago #177691 by Tady
No problems on 19 also. Only 20 didn't work.
6 years 2 months ago #177787 by rootboy
I had an error about not being able to modify "iptables", which made sense since it wasn't included in Mint 20. Adding a blank "iptables" file fixed this.
6 years 2 months ago - 6 years 2 months ago #179092 by EisbaerLars
Installed that yesterday along your guide and it went like a charm!
Thank you so much - you made my day!!!
Only thing I couldn't achieve (but that's not tied in the installation) is to get the RT Kernel line as the one in the main Grub window instead of the one with the original kernel - maybe someone can tell how to achieve this.
Update: Found the grub customizer - easy to install and does exactly what I wanted
Last edit: 6 years 2 months ago by EisbaerLars.
6 years 2 months ago #179097 by pinsyd1
Worked flawlessly for me with Ver 2.8.
Thank you for this!
6 years 2 months ago #179111 by tommylight
You are both welcomed, always.
Grub customizer is a helpful tool but it messes to much with the grub stuff, never had issues with it though.
That can also be done by editing grub and updating it, but that also has it's risks as any typo will render the PC non bootable.
  • BeagleBrainz
  • New Member
  • New Member
6 years 2 months ago #179158 by BeagleBrainz
See this article regarding saving your last choice, ie you boot, xyz isn't your default, choose xyz and next boot xyz will be automatically selected.
www.maketecheasier.com/set-grub-remember-last-selection/
Time to create page: 0.440 seconds
