Yes you can safely install that package and check if you can make the wifi work, although i would just ditch the wifi, but since the new installation procedure (if anything goes wrong) is short, give it a try.franstrein wrote: Maybe I found the answer....
Should I install this package:
packages.debian.org/stretch/kernel/linux...rs-4.9.0-13-rt-amd64
Will try this tonight..
Frans
