BeagleBrainz wrote: Did you attempt to run the commands I suggest ?
This will let me know if eifvars has been mounted.
What wifi adapter are you using ?
Best option is to reboot, open a terminal and run lsusb
or runcopy the file, attach it here and I'll have look, it maybe just a case of rebuilding the ISO with the correct driver & firmware in there.Code:sudo dmesg > dmesg.txt
