Plenty of ideas, but start LinuxCNC from the terminal and check if it says:dvn4life1972 wrote: Hey Tommy, I tried this on my Gigabyte BRIX S with the 4.9 kernel. uname -a shows the kernel is up. I can't get Linuxcnc to run outside of simulation though, it worked on 19.3. Any ideas?
Using Posix RealTime
If it does say that everything is fine regarding the kernel and LinuxCNC, so the issue would be with the config.
I already started down the path Beagle recommended with 19.3. Maybe it'll work right this go-round?
