LinuxCNC on Linux Mint 20 quick and nearly easy install
6 years 6 days ago #187297 by shortcircuit48
Unfortunately I have hit a dead end and not sure which way to turn. Over the last few months I have been changing my desktop around which resulted in me to quiet frequently reload Linuxcnc into Mint 20 all with no problems. For some reason CNC has disappeared from the Mint menu so now have no access to create/edit HAL files etc. I can launch Linuxcnc by using the "Find Application" but that is all.
I have cleaned out all reference to Linuxcnc within the Synaptic package manager and reloaded following the exact procedure in this listing to no avail. I can look into the "Menu Editor" which does contain the CNC folder with two entries being Documentation and G-Code quick reference.
My next option is to reinstall Mint however if anybody has a suggestion I could try before doing that.
Thanks in advance
6 years 6 days ago #187305 by shortcircuit48
Thanks. I have tried that and every other combination of , recently used, all applications, accessories but nothing points to Linuxcnc. Only can load as previously described.
It is no big deal to wipe my drive and start afresh but just wonder why and if it will resolve.
6 years 6 days ago #187306 by Aciera
I have no idea as to why this happened but you can easily create your own starter icon on the desktop that executes a terminal command to start linuxcnc.
6 years 6 days ago #187309 by shortcircuit48
Thanks, I have found the application and launched with a desktop icon created, however no access to HAL etc
6 years 6 days ago #187311 by Aciera
You mean you can't find the INI and HAL files or the configuration folder?
Time to create page: 0.393 seconds
