Buildbot & RTAI ?
03 Aug 2020 22:15 #177116 by tommylight
Replied by tommylight on topic Buildbot & RTAI ?
There was no cheaper times for CNC in the history of human kind, so there are no excuses not to dive in, head first. ! :)
For anything from 100$ and up one can coble together a working machine.
I like the idea of teaching young generations about everything, especially for tech stuff, so do not hesitate to ask, we will gladly help.
04 Aug 2020 03:23 #177166 by phillc54
Replied by phillc54 on topic Buildbot & RTAI ?
There is RTAI experimental kernel available here:
linuxcnc.org/docs/2.8/html/getting-start...#cha:Installing-RTAI
04 Aug 2020 12:15 #177224 by tommylight
The one in the temp should be new, but do not take my word for it as i did not check the docs in a long while.
12 Aug 2020 20:43 #178055 by lrak
Replied by lrak on topic Buildbot & RTAI ?
You might try in /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet text isolcpus=2,3"
Then run :
$update grub
Reboot and see what happens. It helped on the HP8300 I'm using - even with youtube playing a video it wasn't bad.
My understanding - which might be wrong - is that RTAI is married to an old kernel, updating it so it works with current versions is a HUGE task that takes developers away from improving other parts of linuxcnc. At some point, with hardware Ethernet cards, that are quite inexpensive in the bigger picture, should/will replace the old parallel port bit-banging approach. Mesa with a standard RT-kernel is what I am doing. Using Ethernet I/O also gives you a lot of noise immunity for free - should be a much more reliable system.
I used to sell and support a PP EPROM programmer with tight real time timing requirement - once we upgraded to USB - with an embedded processor (similar to using modern Ethernet boards) most support issues disappeared. What the developers did here - tweaking a kernel - training elephants to dance - was extremely impressive, but the effort required to keep RTAI going with newer kernels would consume vast amounts of time.
The following user(s) said Thank You: rodw, anfänger
Time to create page: 0.087 seconds
