RPI4 Raspbian 64 bit & LinuxCNC
3 years 8 months ago - 3 years 8 months ago #264073 by beaker152
try isolcpus=2,3 as well
when i run cat /sys/devices/system/cpu/isolated
it returns: 1-3
should it be changed to 2-3?
newbie question: where/how does one change that setting?
Last edit: 3 years 8 months ago by beaker152.
3 years 8 months ago #264074 by beaker152
elovalvo, please see the attachments for the hal and ini files
thanks!
3 years 8 months ago #264093 by beaker152
As a first step, can you try with rx-usecs set to 0?
this might've done the trick--i've run the gcode through 3 times in a row without the "error finishing read" popping up again, although i did have a couple of following errors show up...
i'll run it a few more times, but this seems to have been a big improvement, thank you!
3 years 8 months ago #264095 by PCW
Replied by PCW on topic RPI4 Raspbian 64 bit & LinuxCNC
You might check this for following errors:
3 years 8 months ago #264100 by beaker152
interesting--so, for reasons i don't understand, my rpi 4 doesn't seem to find my mesa board when wifi is on, so i have to disable it when
running linuxcnc, so any of the following errors have been happening when disconnected from the internet...
that being said, i did the ntp install and verified its running and will run my gcode again (without internet)...
can anyone tell me how to set the rpi 4 to allow both wifi and ethernet simultaneously?
thanks!
3 years 8 months ago #264122 by elovalvo
thanks!
www.raspberrypi.com/documentation/comput...nfiguring-networking
forums.raspberrypi.com/viewtopic.php?t=329164
Time to create page: 0.400 seconds
