RPI4 Raspbian 64 bit & LinuxCNC
3 years 8 months ago #264139 by beaker152
As a first step, can you try with rx-usecs set to 0?
this might've done the trick--i've run the gcode through 3 times in a row without the "error finishing read" popping up again, although i did have a couple of following errors show up...
i'll run it a few more times, but this seems to have been a big improvement, thank you!
well, i ran it one more time and got the "error finishing read" problem again, so it seems that there is still an issue.
is it correct that this indicates a 5.x kernel?
linuxcnc@raspberrypi:~ $ uname -a
Linux raspberrypi 5.15.65-rt49-v8+ #1 SMP PREEMPT_RT Tue Sep 6 18:12:35 BST 2022 aarch64 GNU/Linux
i inferred there may be some concern about 5.x on another thread:
forum.linuxcnc.org/27-driver-boards/4691...error-finishing-read
do we know if anyone has tried a 6.x kernel build on a raspberry pi?
3 years 8 months ago #264143 by elovalvo
I'm currently experimenting on a Raspberry Pi 400 with a version of linux 6.0.15-rt14-v8+ compiled by me.
The Debian release is this
$lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux bookworm/sid Releases: n/a Codename: bookworm
was obtained by upgrading the RaspiOS bullseye to bookworm
The LinuxCNC version is 2.10.0pre, also compiled by me.
In this configuration, contrary to the one present on Debian ( raspi.debian.net/daily-images/ ), the hal_pi_gio module works properly.
I don't have Mesa cards so I can't tell you if it works with this one.
The results look interesting
3 years 8 months ago #264145 by beaker152
can anyone tell me how to set the rpi 4 to allow both wifi and ethernet simultaneously?
thanks!
www.raspberrypi.com/documentation/comput...nfiguring-networking
forums.raspberrypi.com/viewtopic.php?t=329164
i see that my wifi router Default Gateway is 10.0.0.1 and my Mesa 7i96s is set up with IP address of 10.10.10.10...   is that a conflict that must be resolved to have wifi on while being actively connected to the Mesa card?
3 years 8 months ago #264147 by beaker152
is there a way to replace the 5.x kernel i have currently with that 6.0.15 kernel? or would i have to recompile/rebuild the whole thing from scratch?
i found some build instructions here:
forum.linuxcnc.org/9-installing-linuxcnc...mpt-rt-kernel#259347
and tried it the other day, but it seems that script didn't run to completion for me as written and i didn't have enough time to sort out all the edits required to get the last 2% working...
cheers!
3 years 8 months ago - 3 years 8 months ago #264148 by PCW
Replied by PCW on topic RPI4 Raspbian 64 bit & LinuxCNC
thanks!
It could be a conflict if you did not configure the host netmask to a /24 mask (so LinuxCNC ends up routing packets out the wifi interface)
Last edit: 3 years 8 months ago by PCW.
3 years 8 months ago #264151 by tommylight
The default subnet for 10.n.n.n is /8, so PCW's advice to set it to /24 is very good.
There might be an issue if you are using WiCD to configure and connect to networks as it does not allow 2 connections at the same time, so removing WiCD and installing network-manager should fix that.
Time to create page: 0.105 seconds
